Receiver Hitch Rust
Discussion in 'Everything Else (off topic)' started by thewoodlands, Mar 14, 2016.
  1. Will C
    Will C
    New York
    I tried everything but heat when I traded trucks 11 years ago-ended up just leaving it and buying another insert. I got smart-my new insert is stainless steel and I take it out every winter when I don't tow.
  2. yooperdave
    I knew before I had entered a bid on my truck that it would be a problem, but with the warmer weather coming son, I'll find out just how much of a problem it will be!
  3. Canadian border VT
    I take mine out only because you knee knock those things and it starts a little! :bug::doh:
  4. yooperdave
    I would always take mine out on my old truck, also. Nobody needs those knee-knockers!
  5. thewoodlands
    thewoodlands
    The old 2 inch ball on the old hitch doesn't want to come off, I've used PB Blaster, WD40 and a some heat but the bast--- won't come off.
    I went into town today and bought a Reese Interlock Hitch Draw Bar with a new 2 inch Interlock Ball.
    I did get the receiver cleaned out real good and before I put the new Draw Bar I grease it all.
    I bought the Draw Bar with a 2 inch drop and flipped it, it's interlocked on both sides. That nut should come off easier being the ball assembly interlocks.
    Both are rated for 6000 pounds. I did spray the threads down with WD40 before I put it on.
    This will come off when I'm not using it.
    [​IMG][​IMG]
  6. HDRock
    Well, you're not alone I have had a couple of balls I could not get off even with a big giant wrench and a 6 foot bar on it.
    Looks like your Going to be all set now though
  7. thewoodlands
    thewoodlands
    I had the wife out there yesterday, we had some pipe wrenches on it and I had the sledgehammer going, it still wouldn't budge.
    Backwoods Savage and HDRock like this.
  8. HDRock
    if you wanted to save the draw bar you could take it to a welding shop and have them cut the nut off with the torch
  9. thewoodlands
    thewoodlands
    I promise you that I'll get it off before the end of summer.
  10. HDRock
    Air chisel might do it too, I never thought of that before:)
    When I worked repair at Buick we had a great big air chisel, I know would have cut that sucker off
  11. chris
    chris
    SE WI
    Heck I have put a wrench on them and then backed ( carefully) up into a tree to bust it loose.
  12. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Wanna borrow my 1" impact ?:D
    Gary
  13. HDRock
    That might work too, that nut laughed at the half inch I have
  14. yooperdave
    Must resist....the urge....to comment....:whistle:
  15. HDRock
    Note to self, remember this idea
  16. HDRock
    :rofl: :lol: Oh boy
    yooperdave likes this.
  17. thewoodlands
    thewoodlands
    I'll see if I have a big pipe hanging around, I might try this.
  18. brenndatomu
    If you have access to an acetylene torch, heat that nut red hot, it will come off with a big wrench, maybe even a regular size wrench
  19. HDRock
    That's what I did, didn't work but it might for you.
    Hook a winch or Come Along on that bar and get the hell out of the way:D
    Hack That might even work with just the pipe wrench
  20. thewoodlands
    thewoodlands
    The bars out, it's the ball I want off. I'm soaking the nut on the threads of the ball in White Vinegar, I'll give it another try after we bake some bread tomorrow.
