Rebuilding a crushed MS 260 Pro
Discussion in 'Chainsaws and Power Equipment' started by Bret Hart, Feb 7, 2016.
  1. Bret Hart
    Bret Hart
    Central NY
    It was a long friendly conversation.
  2. crzybowhntr
    crzybowhntr
    WV
    Just curious as to why you would put muriatic acid on a cylinder you're going to scrap?
    clemsonfor likes this.
  3. MarylandGuy
    MarylandGuy
    Maryland
    Sorry, my writing skills leave a lot to be desired. What I meant to say was you may not want to break down and use acid unless there is no other way of saving the cylinder. That way if you do mess up and leave the acid on too long and damage the nikasel coating, you don't feel as bad if the cylinder has to be tossed.
    There are a lot of guys who have great success using acid. It loosens up the aluminum transfer from the piston to a point where it can be wiped away with a cloth. But some people have been known to leave it on a little too long and the nikasel coating is damaged. It's best to apply it in stages, instead of trying to do it all at once. In other words, apply the acid, let it sit for a few minutes and them wipe it away. If the results were poor, the next application leave it on for a few more minutes.
    Probably the safest way would be to get most of the transfer off with acid, then insert the sanding drum/scotchbrite pad to finish the job up.
    These methods really do work, but it can be time consuming depending on the amount of transfer. But it's well worth it considering the cost of an OEM cylinder.
  4. MasterMech
    Often, heavy transfer can damage the plating in a small area underneath. The acid doesn't usually damage the plating but those itty bitty pin holes let it leak through and start eating the cylinder. Sanding the transfer off won't do that. I don't do acid anymore.
    Kyle Mulligan likes this.
  5. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    Yeah. I stopped doing acid when I was a teenager.:doh:
