Real world cat life, Woodstock
Discussion in 'Modern EPA Stoves and Fireplaces' started by BigPapi, Jul 15, 2018.
  1. BigPapi
    BigPapi
    The hills of Western MA
    Hi Earl,
    The deed says 1850, which fits with the history as I understand it. I have the Boston and Albany railroad running very close by, and the homes around this stretch of town they call "the valley" were built by and for the men who dealt with the railroad either in construction or supply.
    I have yet to find anything original other than the foundation and the beams resting on it, which, while punky in a seldom few spots, seem quite stout despite holding up this place over a wet dirt floor basement for almost 170 years. The house has been "updated" at least twice as far as I can tell, once in the 50s and once by the woman who sold it to us in the 2000s.
    Mrs Papi recently got me a metal detector, so I'm eager to see what turns up around the place. There have been people here for quite a while, hopefully dropping some interesting stuff. ☺
    Camber, OhioStihl, Chaz and 2 others like this.
  2. gmule
    gmule
    Conifer Colorado
    I have experienced the same results with my Woodstock Fire view
  3. rdust
    rdust
    SE, Michigan
    With my BK princess my original cat made it through 5 seasons. The 5th season it was lazy, I should’ve replaced it after the 4th. The replacement has 2 seasons on it but I’ll be happy if it makes it 3 seasons. I was getting some smokey burns with it near the end of last season.
  4. gmule
    gmule
    Conifer Colorado
    It probably wouldn’t be a bad idea to buy another cat to have on the shelf. That way you would have a buffer if shipping times were long or there was an issue with the supply
  5. BDF
    BDF
    That is fine but the warranty period starts from the time you buy the combustor, not the time you install it. So if you buy a new one, and it sits on a shelf for three years, when you first install it in the stove the free replacement warranty is already used up (in the case of Woodstock combustors: 3 years outright replacement, three more years pro- rated warranty). Something to think about if buying a combustor for some future use.
    Brian
  6. gmule
    gmule
    Conifer Colorado
    That is a great point. I never even knew the cats had a warranty on them
  7. BDF
    BDF
    Yeah, and it varies from manufacturer to manufacturer but usually, there is an outright replacement time followed by a pro- rated replacement time. Woodstock Soapstone warranties theirs for three years outright replacement and my first replacement (at under 2 years) was free to me. So it does make a significant difference in cat. cost over, say, ten years for example. The pro- rated part is not great but can still be useful although it works on full manufacture cat. cost and often an aftermarket cat. can be had for significantly less than from the mfg. so the end of the pro- rated period is often useless IMO.
    But waiting for the cat. to really get sluggish can bite a stove user too- last time I tried to buy a new cat., Woodstock was having supplier trouble and they were out of stock for a couple of months. So one sitting on the shelf would have been a nice touch and at that point, I was near the end of the whole warranty anyway so it would not have made much difference in cost to me.
    Brian
  8. Rearscreen
    Rearscreen
    I've run my Progress Cat for 4 years and it still fires off. I've heard that boiling the cat in distilled water/vinegar does a nice deep clean. I sourced a perfect size stainless pan to accommodate. I'm going to give that a whirl.
    Yup, I was at a Woodstock picnic and a used Progress was all apart. The owner ran it without the cat and warped it.
    jo191145, Maina, Chaz and 2 others like this.
  9. Backwoods Savage
    If you don't want to mess with the boiling, many of us have had good results just spraying the cat. I usually mix about a quart or I think the bottle might be 28 oz to 50/50 vinegar and distilled water. Then put all distilled water in the spray bottle and spray the cat with that for the rinse. Seems to work good. I think it was Lewis who came up with this idea first.
    jo191145, Maina, Chaz and 1 other person like this.
  10. MikeInMa
    What is used to determine the need to replace the cat?
    A - Elapsed time?
    B - Number of burn hours?
    C - Temps? Measured how?
    D - all the above
    E - none of the above
  11. Canadian border VT
    MikeInMa basically the cat will start to be sluggish. Not fire off at correct temps and not throw correct heat.. Its a slow process so its hard to notice at first, then you clean it works again. Then you need to clean it more and more frequently.. Til you buy a new one and wonder why you waited Soo long..
    Maina, gmule, Chaz and 3 others like this.
  12. MikeInMa
    How does one know if/when it has fired off?
    Mine is located under the top of the stove, with 4 corner screws holding the top in place.
    Excellent thread, BTW.:thumbs:
  13. Canadian border VT
    With thermostats..Stack temp drops and stove top temp increases ..
    Maina, BigPapi, Chaz and 1 other person like this.
  14. Unhdsm
    Unhdsm
    Bradford, Vermont
    Also look at what is coming out of the chimney when it is engaged. You shouldn't be seeing much smoke.
    jo191145, BigPapi, Chaz and 2 others like this.
  15. MikeInMa
    I think I know when it's time to replace my cat. Now
    The thing is crumbling
    two6's, papadave, Maina and 5 others like this.
  16. MikeInMa
    I'm replacing it with a stainless steel cat from Condar. The original is ceramic.
    Chimney sweep shows up next Thursday. I'll have the top removed for a good vacuuming.
    I should be good to go for the heating season, after this tune-up.
    **edit** Sorry to have run this thread a bit off its wheels.
  17. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I never thought of the warranty aspect. I was thinking I'd pick one up before this winter to have on the shelf, but being only one season old, I'll wait until next summer.
  18. Backwoods Savage
    Mike you will no doubt notice a difference in the cats. I think steel cats light off quicker than the ceramic but the ceramic might get hotter. Steel should last a bit longer too.
    Maina, BigPapi, Camber and 1 other person like this.
  19. Unhdsm
    Unhdsm
    Bradford, Vermont
    That'll buff right out.
    papadave, OhioStihl, jo191145 and 6 others like this.
  20. Flamestead
    Flamestead
    Windsor County, VT
    One advantage to owning two cats is to be able to do a swap in the dead of the winter and clean without stopping. This can make the long tail end of cat life a bit more bearable.
    Maina, BigPapi, Camber and 2 others like this.
