Re-purpose a water pressure tank
Discussion in 'The DIY Room' started by Beetle-Kill, Apr 12, 2015.
  1. basod
    basod
    Mount Cheaha AL
    add a pressure relief device - just like a water tank.
    It's unlikely the failure would be catastrophic weld seam failure anyways, pin hole or split yeah. Just have the tanks secured to a wall with strapping so they don't decide to fly around;)
    I've been in close proximity to a 1600psi 1100F steam drum door letting go - and yeah that is where you don't want to be
    Beetle-Kill and Eric VW like this.
  2. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Just judging by the exterior, I'd not have a problem with running them up to 100- 125 psi. Welds are good, no exterior corrosion anywhere. Interior may be a completely different story. Keep you posted when I tear into one.
    basod and Eric VW like this.
  3. jetjr
    jetjr
    Pa/Md line
    I am thinking of making a small forge with mine. Cut the bottom 1/4 or so off and it already has a stand and pipe for air inlet.
    Eric VW likes this.
  4. Mag Craft
    Mag Craft
    South East Wyoming
    Is the inside of these tanks galvanized or coated with some kind of anti corrosion material. If so I would be carful about cooking food with them.
    Eric VW likes this.
  5. jetjr
    jetjr
    Pa/Md line
    I don't know if they are galvanized but mine had a lot of corrosion in it. Haven't cut it open yet to see. One of those projects that doesn't take precident.
