Ranking wood
Discussion in 'The Wood Pile' started by MHL68, Feb 21, 2025.
  1. buZZsaw BRAD
    Years back when Midwinter was active I believe she scrounged some from the dump. Obviously not a big wood but it was very dense she stated.
    JDU, Cash Larue, metalcuttr and 2 others like this.
  2. Canadian border VT
    I had 8” diameter lilac, so i split it; it was dense. Dry it burned well.
    MHL68 just curious why you put ash in different category than maple?
    JDU, Cash Larue, metalcuttr and 5 others like this.
  3. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I would rank free firewood as the best.
    Dok440, jrider, Cash Larue and 8 others like this.
  4. brenndatomu
    Best answer! :thumbs:
  5. The Wood Wolverine
    What if it was willow?
  6. brenndatomu
    Burns better than snowballs!
    That said, free willow firewood is best if already cut/split :D
    Bill2, jrider, JimBear and 5 others like this.
  7. buZZsaw BRAD
    Me too!
  8. Eckie
    Eckie
    There is ZERO DOUBT that a question like this will get opinions on here!
    But it's one of those somewhat volatile questions, like which make or style of vehicle is best, which brand or size of saw is best, what gun is best etc etc.
    How does the "other site" define "quality"? Is it based on just btus given, or is it a combination of factors like btu, drying time, ease to split, how long it lasts in a given storage condition etc etc...the list goes on. It all depends on context. A pi to station wagon may be perfect for your needs, while I really need something like an F450 flatbed.
    Some folks say hedge, black locust or shagbark hickory is the best (based mainly on btus). For me, that'd likely make my heating application go nuclear. So I'm learning that I like a mix of oak, ash, maple, elm, hackberry etc. But if one has no firewood, anything burns better than a snowball....
    In my opinion, it all depends on how a person defines "quality"....
  9. Canadian border VT
    I think it was Paul bunion who said all dry firewood had same BTUs per pound; this was fascinating to me. Changed my hoarding pattern
  10. brenndatomu
    That's basically true...but many softwoods actually have a slight advantage, per pound.
    8600 BTUs/lb is the commonly used average number...
  11. JD Guy
    JD Guy
    Upstate SC
    Nope, no such thing! Remember there’s a plethora of wood users (hoarders) here and many will have different opinions on “best” firewood ranking..The best wood is usually what you can source close and is free:yes:
  12. MHL68
    MHL68
    Southern MN
    Certainly not my list...just something I found on-the-line. It was just a basic generic list I found and was looking for what opinions here would be on a list like this. I knew it would not be agreed upon across the board. Just wondering what the opinions here would be on how WAY off base it was or how semi, in a general basis, it may be relevant.
  13. Elm-er Fudd
    Elm-er Fudd
    Kansas
    For me locust is almost useless when burned by itself during very cold weather. Fills the stove with coals and doesn’t throw much heat. Works pretty well to stuff the stove for an overnight burn if you are home the next day to feed the fire with pine or cottonwood to burn the coals out. Have had the same problem with apple wood. I think they both work better for shoulder season than during the bitter cold times. YMMV.
  14. BuckeyeFootball
    BuckeyeFootball
    I tend to agree although I wouldnt call it shoulder season wood Id be cooked out. For me all the black locust goes nuclear off gassing for the first hour or 2 then yeah its just a giant lingering coal. So maybe 2 splits at most at a time usually just one though. Im sitting on a cord of it trying to figure out the best way to work it in. Mixing a piece of pine with the hardwoods will give a quick burst of heat nearly as good and not leave me with a stove full of coals.
    Cash Larue, metalcuttr, Eckie and 3 others like this.
  15. theburtman
    theburtman
    I usually put one BL split in an overnight load mixed with other hardwoods.
  16. brenndatomu
    Totally agree.
    I have actually started using high coaling woods (what most would consider "the good stuff") for shoulder season fuel...I find it off gasses good for an hour or two (which provides the temp increase for the house) then the long lasting coals provide the low level heat needed to maintain that temp long term, without driving the house temp up a lot more.
    During the cold snap we just came through on n off over the last month or so I found myself loading pine and other low coaling woods when the house temp was dropping and the Kuuma had a belly full o coals...had I been around the house to reload more throughout the day, I would have been using all, or at least mostly, "shoulder season" woods on the coldest days to keep the BTUs pumping into the house...less peaks and valleys in the house temp that way.
    I know, I know, that totally goes against traditional wood heat thinking, but with modern EPA stoves, it's true.
    I have no doubt though that an old school stove could/would be red hot burning locust, hickory, Osage, etc...
  17. Elm-er Fudd
    Elm-er Fudd
    Kansas
    Completely agree. The locust and apple work great in the old smoke dragon out in the shop…not so much in the NC30 in the house. Dead standing barkless Siberian elm seems to give me the best balance of heat output, burn time, and coaling in the NC30. A little locust, apple, or mulberry mixed in works pretty good, but I always bring up a decent pile of pine when forecast is 10 degrees or less.
  18. Jeffrey Svoboda
    Jeffrey Svoboda
    From what i gather in the last 2 posts. EPA: taking great firewood and making it almost useless. :sherlock:
  19. brenndatomu
    Nope, just needs to be used differently.
  20. Jeffrey Svoboda
    Jeffrey Svoboda
    Yeah it's still usable but not in the great heating capacity it was intended or capable of. I'm just trying to dig on the EPA man. :p
    Truthfully i had that problem with my "old black box" until i made my splits smaller. That was somewhat due to my wood not being totally dry also. Now that my wood is dry I'm gonna have to make my splits bigger so that i don't have so many restarts. Seams like it's always a balancing act.
