Raker height
Discussion in 'Chainsaws and Power Equipment' started by Kg461, Sep 11, 2014.
  1. mdavlee
    mdavlee
    File lower into the straps when round filing. For square get more forward lean on the side plate. Get more towards 85° or 5° forward lean on the side plate. I can't tell you what angle for the underneath top plate since I don't have a grinder to check off of.
    SquareFile and Kg461 like this.
  2. Kg461
    Kg461
    Provencal, La.
    Filed stihl rsc full comp at 35° and rakers at .040. Sucked it right into the spikes!! Self fed nicely though.
    basod and mdavlee like this.
  3. mdavlee
    mdavlee
    That will do it.
    Kg461 likes this.
  4. Kg461
    Kg461
    Provencal, La.
    .040 pulls too much for me. Is there a big difference between .030 and .040?
    SquareFile likes this.
  5. SquareFile
    SquareFile
    somewhere
    yeah .010" :rofl: :lol:
    I think you will like .03 better, you wont have to have such a light hand :yes:
  6. mdavlee
    mdavlee
    Yeah they'll be a big difference in it.
  7. Kg461
    Kg461
    Provencal, La.
    Ill just cut with it at .040 for several sharpenings and work my way back. It has enough power to pull against the spikes no problem. I filed at 35°and dropped my hand down toward floor about 10° as that looked to be the upward angle the Stihl RSC came with? What does the 10° drop affect?
  8. mdavlee
    mdavlee
    It makes the point thinner to cut a little bit faster but won't hold the point so long.
    cgraham1 and basod like this.
  9. Kg461
    Kg461
    Provencal, La.
    Ya I noticed the point getting close to square chisel. Do u like the 10° drop Mike?
  10. Kg461
    Kg461
    Provencal, La.
    Im likin round filed at 35° and a 10° drop and rakers probably at about .025
    Moparmyway and SquareFile like this.
  11. SquareFile
    SquareFile
    somewhere
    Sound like a good plan. :yes:
    I'm glad you got it figured out :dennis:
  12. Kg461
    Kg461
    Provencal, La.
    Ive been putting lots of effort in chain as I know it makes the biggest performance differences. Im seeing that one has to build chain around each saw and its performance
    Pallet Pete likes this.
  13. mdavlee
    mdavlee
    No I don't do the 10 degree drop when round filing. Square should have more support in the corner than round.
    cgraham1 and Kg461 like this.
  14. cnice_37
    cnice_37
    So how are you all measuring raker height? I file mostly by eye and the rakers just get a swipe or three every other filing. Very scientific, especially after several beers.
  15. basod
    basod
    Mount Cheaha AL
    I will second the 10deg drop angle - the chain will cut faster, but loses the point quicker.
    Using a file-n-joint type sharpener makes it easy to get a consistent angle in both planes. 3 swipes seems to do the trick
    Use feeler gauges with a straight edge every 2-3 sharpening's how ever many passes to get .025
  16. trx250r180
    trx250r180
    If you need .035 to make your chain work ,it is not sharp in my opinion
    Hi Phil :picard:
  17. Moparmyway
    Moparmyway
    New York
    I second this ............ .030 max for nice feeding and good speed without extra effort to keep off the spikes
    .025 is a great height with a sharp chain for a steady - smoothe cut, although your Monkeyed 461 might want the .030
    DexterDay and Kg461 like this.
