Rail rack re-load + addition
Discussion in 'The Wood Pile' started by Ashwatcher, Feb 12, 2017.
  1. yooperdave
    Nice setup once again.
    I too, will have help with the splitter as you had. I am convinced that no one can run it better than 99 does!
  2. basod
    basod
    Mount Cheaha AL
    Glad your cinder block is holding up buddy:thumbs:
    Those are some clean purty stacks and the woodshed? must've missed the build? Sweet:yes:
    FYI - the moisture meter needs to parallel the wood grain - I don't own one but measuring across growth rings causes resistance variables;)
  3. Eric VW
    Ah Ha!
  4. Eric VW
    Oh boy....:whistle:
    :popcorn:
  5. Ashwatcher
    Ashwatcher
    West By God Viginia
    Hey thanks basod and also for the info but those end grain growth ring crayon markings are recorded for time comparison and represent what/when they were when c/s/s-Readings are taken parallel with the splits upon re-split-Shed was built in 2010
  6. basod
    basod
    Mount Cheaha AL
    I guess so we're on the same page:loco: :crazy:
    the cross grain measurements are from before you knew how to use the moisture meter?
    future measurements have the pins measuring the same grain i.e. parallel
    Backwoods Savage and Eric VW like this.
  7. Ashwatcher
    Ashwatcher
    West By God Viginia
    All readings are taken parallel to the grain, before and after-I just write the initial, fresh cut MC/Month/Year on the end for reference-and I stick it both ways in the grain along the fresh split side and see no discernible difference in the reading but will note for future reference/readings the 4 pins are as near perfectly parallel to the grain as possible with the meter flat in hand-Thx again for pointing that out though :yes:
  8. Backwoods Savage
    The last time I said that I got torn apart!!! So I guess some say yes and some say it doesn't matter. Just one more reason I'm not hot on MM. I don't need one.
  9. The Wood Wolverine
  10. Felter
    Felter Banned
    chicago
    awesome pics. I like the stacks on the rails. :yes:but I gotta ask, why do you cover your stacks?? the wood will season better if you let it get rained on.
    also, your splitter operator is beautiful. and turning that cinder block so thats the holes are vertical is a much stronger.
  11. Oldman47
    Oldman47
    Illinois
    Felter, are you trying to start something? That is the subject of lots of threads here and there really is no definitive answer.
    Lone_Gun, Horkn, yooperdave and 2 others like this.
  12. Ashwatcher
    Ashwatcher
    West By God Viginia
    Thank you Felter for your kind comments-and I agree along with my friend Backwoods Savage there is no harm in leaving that wood on the rail rack exposed to all elements if properly positioned yet covering it 6-8 mos before going to the shed is just the final step of the process-when you achieve the 3yr plan it really becomes quite easy and thoughtless...its like icing on the cake-the wood is ready, you cut when you want to, covering just extracts the last bit of lingering moisture, especially baking in the proper fashion-off the ground, facing south and the black rubber roofing I will be using will draw up the moisture in the exposed splits like a sponge in the southern sun...take care my friend :salute:
  13. Felter
    Felter Banned
    chicago
    awesome job on getting 3 years ahead. nice looking shed too. :thumbs::handshake:
  14. Felter
    Felter Banned
    chicago
    oh is it?? sorry I'm new here, :picard: I haven't been around for any discussions on this issue. sorry for the attempted hijack.
  15. Eric VW
    Hijack all you need to Felter .....
    Ashwatcher can take it:thumbs:
  16. Felter
    Felter Banned
    chicago
    eric you crack me up. every post. :rofl: :lol:
  17. Eric VW
    I'm here all week...
    Don't forget to tip your waiter.....
    yooperdave is her his name....:whistle:
    Lone_Gun, Horkn, yooperdave and 5 others like this.
  18. Ashwatcher
    Ashwatcher
    West By God Viginia
    I respectfully disagree-I think Oldman47 served up the beach ball here to be knocked outa the park...and for our new friend Felter , he's referring to the debate on to cover or not to cover-I say its a blend of both...but you are correct in that my neighbor to the south will seize every opp to stir the pot:whistle:
  19. Eric VW
    :picard:
  20. yooperdave
    Her? :picard:
    Just because I'm a brow beaten hen pecked old man doesn't give you the right to assume I always wear that apron.....
