R4's or turf tires for mowing and plowing?
Discussion in 'Chainsaws and Power Equipment' started by Trilifter7, Dec 11, 2014.
  1. Sunfish
    Sunfish
    Success Mo
    Xskier is here?
    It sucks that we have to put up with her crap here also...:popcorn:
  2. Freakingstang
    Freakingstang
    Good to know. I hadn't priced them through whole goods. I was going to change out the turfs on my stock rims and have them filled. Was going to be twice that..
  3. Trilifter7
    Trilifter7
    Waynesville, OH
    Yea I was more stating for my situation. Being that you do fine with R1 ag tires then I'm sure I'll do fine with the R4's
    Sunfish likes this.
  4. Sunfish
    Sunfish
    Success Mo
    Gotcha... R4s' are fine unless the ground get a little slimy and they suck in mud. Otherwise work pretty good.
  5. Freakingstang
    Freakingstang
    Well turf tires really suck in the mud or wet/slick grass and they won't clean out. Mowing my ditch is impossible with turfs.
    Trilifter7 likes this.
  6. Trilifter7
    Trilifter7
    Waynesville, OH
    Would you recommend R4's over the turf tires then? My work consists of mowing 1.5 acres of manicured yard in the summer and clearing a 200' concrete drive and a 300' gravel drive in the winter. I do some work every once in a while in a field and digging dirt for projects around the house. I currently have no issues with the turf tires on my 445 but would like R4's on the next one as long as they don't tear up the yard too bad and do okay in the winter
  7. lukem
    Is your driveway pretty flat? Is your yard pretty well-drained?
  8. Hedgerow
    Hedgerow
    SW Missouri
    Troll alert...
    Although I am a deere fan...
    Why do I feel dirty now??
    cnice_37 and Sunfish like this.
  9. Hedgerow
    Hedgerow
    SW Missouri
    I take it you're referring to what I'd call industrial tires vs AG tires?
    Ag tires will get down and dig, but I've toyed with the idea of switching over the 65 to industrials for load capacity and better wear.
    Am I amiss on this Idea?
  10. Sunfish
    Sunfish
    Success Mo
    Orange saws & orange tractors bro! :dex:
    Freakingstang, 94BULLITT and Hedgerow like this.
  11. Sunfish
    Sunfish
    Success Mo
    Yes, R1s' are ag tires & R4s' are industrials. R4s will have better load capacity, especially on the front for loader work. But not near as good for traction in wet conditions.
    Hedgerow likes this.
  12. Hedgerow
    Hedgerow
    SW Missouri
    You didn't get to run the DK65S when you were over did ya..
    She just rolled 1600 hours.
  13. Hedgerow
    Hedgerow
    SW Missouri
    I need more load capacity.. I run way over on tire pressure, but still manage to squish the tires out..
  14. lukem
    Foam them. Best thing we ever did for the skidsteer. If the ones you have are in decent shape its cheaper than buying new.
  15. Hedgerow
    Hedgerow
    SW Missouri
    Any drawbacks to that?
    I have considered it..
  16. Sunfish
    Sunfish
    Success Mo
    No, but I sure starred at her a lot. Nice rig!!!
  17. Sunfish
    Sunfish
    Success Mo
    R4 industrials are what ya need, bud...
  18. lukem
    None that I can see, other than you usually have to ship them off for a few days which will put you down.
    I don't know if, on paper, it helps your capacity, but in "real life" it does.
  19. Sunfish
    Sunfish
    Success Mo
    Will ride a little rougher & will need to be cut off when time to replace. But never another flat!
    Hedgerow and lukem like this.
  20. 94BULLITT
    94BULLITT
    Frederick County, VA
    It is a good idea to move the width of the tires everytime you mow so you are in a different set of tracks. Just normal mowing will cause compaction. It is also a good idea to mow on different direction (instead of going north and south, go east and west) every 3 mowings.
    Have you thought about looking at a small compact? They are not much more money than SCUT but they are more tractor. They have more ground clearance, better loader and 3 point hitch lift capacity. Some brands also have a 3 range hydro. They do weigh a little more than a SCUT but they have wider tires so compaction may actually be lower.
    Some manufacters (Bobcat) say not to run foam filled tires in the front. If you have R1s now you will probably have to buy 4 new wheels and tires tomrun r4s. I'd look for some ags with more plys in the sidewall.
