Questions about my Oiler on my Stihl 461
Discussion in 'Chainsaws and Power Equipment' started by Lastmohecken, May 10, 2021.
  1. MAF143
    MAF143
    North Central OH
    Stihl 044 Oiler Mod
    This link will show the internal parts and the part that is just turning now is the one with the two O-rings on it.
    huskihl and Lastmohecken like this.
  2. MAF143
    MAF143
    North Central OH
    Even if you broke that corner stop piece off, that shouldn't affect operation. Just find the spot where it uses the most oil for a tank of gas. If you can't get it to use more than half a tank of oil per tank of gas, you may want to modify it like huskihl shows in that post. I did my 362 and now it oils a 32" bar just fine.
  3. SAWMIKAZE
    SAWMIKAZE
    PGH
    I think I paid around 20 bucks for the bolt and piston out of R model pumps and it works just fine, took about 15 minutes. I've done it for people who buy the half wrap models and wanna run a longer bar.
    Lastmohecken, huskihl and MAF143 like this.
  4. Lastmohecken
    Lastmohecken
    Arkansas
    You're right! I went and looked again. What I thought was the pin, was the stop shoulder as best I can tell trying to shine a light and look through the hole in the bottom of the saw.
    Whether I have done more damage then that, I am not sure. Hopefully not and just need to turn it back to it's highest output. Hopefully, I haven't cracked the pump housing. I don't think I have. Does the R model have a higher output pump then the standard 461?
    MAF143 and SAWMIKAZE like this.
  5. SAWMIKAZE
    SAWMIKAZE
    PGH
    Yep. The R model pump flows more oil, but to upgrade all you need to buy is the bolt and piston out of the R model pump and put it in yours. It's easy.
    MAF143 and Lastmohecken like this.
  6. Lastmohecken
    Lastmohecken
    Arkansas
    So, looking at your picture of the pump set on max, if I just turn the slot for the screwdriver cross wise at a 90 degree the length of the saw, I should be there, I am pretty sure.
    MAF143 likes this.
  7. SAWMIKAZE
    SAWMIKAZE
    PGH
    Sounds right, run it and find out.
    MAF143 likes this.
  8. SAWMIKAZE
    SAWMIKAZE
    PGH
    If you wanna upgrade your pump to the HO parts all you need is
    Piston - 1128-647-0602
    Bolt - 1128-647-4803
    Redfin, MAF143, huskihl and 1 other person like this.
  9. Lastmohecken
    Lastmohecken
    Arkansas
    Thanks, I may need to join that site so I blow up those pictures a little bit. But I read it, and get the idea.
    MAF143 likes this.
  10. Lastmohecken
    Lastmohecken
    Arkansas
    Thanks, will that same piston and bolt work in the 362 and the 462?
    MAF143 likes this.
  11. Lastmohecken
    Lastmohecken
    Arkansas
    Thanks guys, for helping to clear that up.
    MAF143 and huskihl like this.
  12. huskihl
    huskihl
    I bought a used 461 that had that ear broken off just like yours. I located the control bolt in the same position Ryan posted above and left it. You just need to make sure you’re not 180° off
    The 462 is different. The 462, 500, and the 661 have the pin you can drive in. But I believe the 361, 362, and 461 are the same. They may not be the same exact pump, but the 461 pump fits the 361 and 362
  13. SAWMIKAZE
    SAWMIKAZE
    PGH
    362 yes.
    462 no.
    But a 462 pumps a good bit on max so it wouldn't be needed anyway.
    Lastmohecken and MAF143 like this.
  14. Lastmohecken
    Lastmohecken
    Arkansas
    Your right, I don't think I have my 462 set on max, I had to back it off a little bit.
    I think maybe my 461 is oiling enough, maybe. However, I went to the Stihl dealer today with the numbers for the parts, but they were not much help on ordering parts. I wonder if the bunch I talked to knew half as much as I do.
    MAF143 likes this.
  15. Lastmohecken
    Lastmohecken
    Arkansas
    Yes, I believe I have it on max now, so will just leave it that way, until I determine if I need to increase oil flow with new parts or mods for sure.
    MAF143, Mag Craft and huskihl like this.
  16. Lastmohecken
    Lastmohecken
    Arkansas
    Maybe I am ok on the 461 and 32" bar. I ran a tank of fuel through it, today, and used nearly a tank of bar oil, and the chain looks wet. I believe I was just borrowing trouble. I thought I was seeing a pin like on my 462 and wanted to get max flow for the longer bar, but I guess I already had max flow for the stock pump. Another lesson learned.
    However, I really do need to consider a mod to the 362 as it's always been stingy with the bar oil. I have been running a thinner mix in it, all winter, which helps but it's more expensive, since I have been using a winter grade bar oil.
    MAF143 likes this.
  17. Mag Craft
    Mag Craft
    South East Wyoming
    If you want to get max bar life make sure you always have a sharp chain and that the rakers are set to the correct level.
    Lastmohecken likes this.
  18. Lastmohecken
    Lastmohecken
    Arkansas
    Yes, good point. I am pretty good at sharpening a chain, at this point. And I always do the rakers after every sharpening, to keep them at the best level.
    Mag Craft likes this.
  19. Lastmohecken
    Lastmohecken
    Arkansas
    Well, following up, I decided to leave my 461 as is, and decided to install the new pump, (Thank You, Sawmikaze) into my 362 which has always been very stingy with oil. All went well on the swap, in the end. I did run into a couple of issues, not the fault of the new pump. I took every thing out, and cleaned everything up good, bolted the new pump in, no problem, until I tried to install the clutch drum. I was struggling to get in on, and I knew to make sure I was getting the notch located over the arm on the screw drive, and finally figured it out, that I had accidentally engaged the brake, so I got past that and got down to the installing the little E-clip. And I discovered that it was very tight, like everything was too high by a few thousands, not leaving me the full groove to install the clip.
    I took every thing apart down to the pump a couple of times, trying to figure out if I was doing anything wrong, and confirmed that the new pump was not the problem. It's just that when everything stacked up, I was a few thousands tall, crowding the E-clip. And frankly, trying to remember back when I first took it apart, I think the E-clip was very tight to start with, unlike my other saws. So, in the end, I decided to take a few thousands off of the clutch drum, and I also thinned the washer just slightly, to gain a little there, and was able to gain enough room to install the E-Clip.
    I figured the parts I modified were not probably that expensive, so went that way. I think the E-Clip was tight to start with. Anyway, I fired it up, and the pump was pumping oil really good, so I cleaned the bar and put bar and chain back on. The saw works great. I went and burnt up a tank of gas, cleaning out fence rows, and felled about 20 trees with some limbing including, also. I kept an eye on the oil tank and the saw used almost a full tank of oil on one tank of gas. And it's oiling the bar like never before. Probably oiling a little more then needed, so I think I will back the adjustment off of max, just a little, and see how it does. But it looks like it's going to be just fine, and a whole lot better then stock.
    SAWMIKAZE, MAF143 and huskihl like this.
  20. SAWMIKAZE
    SAWMIKAZE
    PGH
    I'm glad you got it in buddy.
    Your bar and chain won't complain they have too much oil...
    MAF143, huskihl and Lastmohecken like this.
