question, where is your wood burning threshold?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Blue Vomit, Jan 2, 2014.
  1. swags
    swags Moderator
    The last three years I never ran a furnace, didn't even have it hooked up. But with the new (very old) house I can't do that. No insulation yet and very very leaky. Have the tstat set at 65 and it runs a little. But our gas bills are very low, without the wood stove I'm thinking they would be at least a few hundred a month to keep this house warm. Will be adding a second stove when I remodel the kitchen so planning on going back to all wood heat next year.
    Chvymn99, Trilifter7 and Gark like this.
  2. NortheastAl
    NortheastAl
    Putnam County NY
    Yup, me too. I leave the oil burner set at 68 on nights like we're having the next few days. -9° they're calling for now on Friday night. A high of only 10° tomorrow is gonna have the wood stove and oil burner taking turns. The 25 mph winds suck the heat right out of this house, and I don't want an outside wall pipe to burst.
    Gark likes this.
  3. Grizzly Adam
    Grizzly Adam Guest
    That's where we are at too. About 17 windows and a new door away from not needing the furnace to run in our absense during sub-zero temperatures.
    Gark likes this.
  4. swags
    swags Moderator
    I replaced all the windows here, but this place has 3 front doors! What the heck do I need 3 front doors for? And 2 of them are side by side but go into different rooms. They all leak like crazy too, will be replacing them but entry doors are crazy expensive if you want a nice one. And this house was built in 1880 so I want to keep the vintage look, my budget just isn't getting along with what I want to do with it.
    Gark likes this.
  5. rdust
    rdust
    SE, Michigan
    A pipe on the outside wall in a climate like NY sounds like a bad idea from the start.
    Gark likes this.
  6. NortheastAl
    NortheastAl
    Putnam County NY
    It is a dumb idea, but the good news during the daylight is they are on a south facing wall. The bathroom was remodeled and enlarged before we bought the house, and the plumbing for the tub wound up on an outside wall.
    rdust likes this.
  7. Grizzly Adam
    Grizzly Adam Guest
    1890s here, replaced the back door with a budget model, the old one was on the verge of falling apart. For the front one I want a steel door with a wood grain finish.
    swags likes this.
  8. Locust Post
    NG boiler which was brand new 2 years ago has 2 zones. One on the end of the house where the insert is and the other in our bedroom/back end of the house. I keep it on 68 and it kicks on some at night. I rarely ever got up to feed the old stove unless it was wicked cold. I doubt I will at all with the new stove because I have barely got it out of 2nd gear yet to keep us warm.
    Gark and concretegrazer like this.
  9. fox9988
    fox9988
    NW Arkansas 72717
    I've got no furnace. Luckily it's rarely below zero, but regardless it's wood vs. mother nature. If I'm home I'll reload as often as necessary, if not, I know the pipes won't freeze so I'm not worried. But if it came down to it, 60F is about at cold as I'd live (temporarily). I'd either buy more heat or a different house, which ever where cheaper.
    Gark likes this.
  10. rdust
    rdust
    SE, Michigan
    I'm cheating tonight, closed the living room doors! :emb:
    It's even cold enough tonight that I have the diesel plugged in and looking like a hybrid. :rofl: :lol:
  11. fox9988
    fox9988
    NW Arkansas 72717
    I'm too tight for that also.
  12. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Shots fired!
    Seriously, though, It's 85 in the room with the 30 right now. Just sealed up the attic window. Have the third stove going and it is 69 in the master bedroom, which was unheard of before this year. My process is evolving every year. Right now, I have more than enough heating capacity to handle any expected weather in this area. There is no oil in the oil tank, so I am working without a net. Going forward it is all about control and extended burn times.
    I have been burning pine all season to increase my hardwood inventory as I am trying to get four years ahead. Just switched to hard wood to increase my burn times and to make morning restarts easier.
  13. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Hi, and welcome to the old leaky home club. Pull up a chair and a blanket.
    papadave, swags, Gark and 1 other person like this.
  14. rdust
    rdust
    SE, Michigan
    First time I've plugged it in, I'm curious if it works.
    fox9988 likes this.
  15. Paul bunion
    Paul bunion
    The thermostats are set at 62 work/night and for 70 morning/evening. NG hot water baseboard heat kicks in every morning upstairs. I can pretty much keep it from turning on in the downstairs zone. Normally I set the walkout basement zone to 50 and it never runs. When it is to be in the single digits I turn it up as I have had the pipe freeze (but not burst) where it goes up to the kitchen. Gas bill is at most $100 in the coldest month compared to summertime when it is about $35 for hot water. I can live with that.
    Gark likes this.
  16. concretegrazer
    concretegrazer
    Southwest MO
    I have 3 plugged in tonight.
  17. DexterDay
    DexterDay Administrator
    Northeast Oh
    My furnace has been running for several days. Anytime it's below 30*, I run it...
    The Pellet furnace that is ;)
    Pellet furnace is my best investment to date. So far I have emptied the ash pan once and just filled the hopper every day or two. ;) I know wood is nice, but pellets are convenient. It's about 73* inside 11* outside. 30-NC and Furnace are purr'ing right along.
    Many say that pellet stoves use to much electric (less than $15 a month), to much maintenance (I go a month or longer before I touch them. Even then it takes less than 10-15 min), or don't throw enough heat ?? (both of my pellet units are 50,000 BTU and will heat a house much larger than mine (2,180 upstairs if using the stove upstairs or about 3,000 if using the furnace).
    Gark likes this.
  18. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    A pellet add-on boiler is probably in my future, still. Need to swap out the stoves I have first.
    Gark and DexterDay like this.
  19. Gark
    Gark
    SW Michigan
    This is a great post/thread. It's cool reading how inventive and innovative that members are with their particular situations. There is so much dedication here whether burning hardcore nothing-but wood or part time with backup. At our house we keep the propain furnace from running about 65% of the time because we all work away from home and our stove is not trustworthy enough to burn with nobody home to babysit it. I am watching closely the posts on the Woodstock Real Steel beta unit and with luck the demand for that stove won't so far lead availability that we can have one for next winter.
  20. mattjm1017
    mattjm1017
    The nearest airport is Norfolk VA. You buy the ticket and Ill pick you up heck Ill even spring for a beer:drunk:
