Quality Tarp
Discussion in 'The Wood Pile' started by Frank and Beans, Apr 2, 2015.
  1. wildwest
    Maybe Backwoods Savage can chime in tomorrow, he's and expert and in MI too. We have never needed top covers out west.
  2. Frank and Beans
    Frank and Beans
    Tnt blaster uncovers stacks till fall. I think that Backwoods Savage does, as well. Is that what most people do? Also, wouldnt Harbor Freight be HF instead of HB? Just sayin.
    NH mountain man and wildwest like this.
  3. oldspark
    oldspark
    NW Iowa
    Single rows do not need to be covered when seasoning (think about it just not needed on single rows) but if you stack in cubes or multiple rows best to top cover. When the wood is seasoned then you can cover it as needed for that winter of burning.
  4. DexterDay
    DexterDay Administrator
    Northeast Oh
  5. oldspark
    oldspark
    NW Iowa
    BWS has his stacks covered because they are cubes.
  6. Paul bunion
    Paul bunion
    The only way to know for sure is to take a scale and track the weight of pieces of wood stacked tarped and untarped in your yard. The amount of full sun you get and overall rain figures into it in a large way. I did it and figured out what worked best under the conditions in my yard. (Not to be biased but tarping won by a huge margin). So my advice is only as good as the next guys. We both have vent holes on our back sides.
    Lumber-Jack and Fanatical1 like this.
  7. Paul bunion
    Paul bunion
    Stinny likes this.
  8. Woodrat1276
    Woodrat1276
    Ky
    I single row stack mine I leave about 18-20 inches between rows. I even went as far as to put a small piece of plastic inbetween one row hanging to see if it really was getting good air flow.
    I won't cover mine over till November or until the first snow is coming
    Besides as crooked as I stack they should have been enough pitch to shed water pretty well ugh
    Thor and NH mountain man like this.
  9. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    About 2 years ago I picked up some 12' x 16' dark brown on one side and dark blue on the other from Costco. Good Price and really good quality. Don't try walking on the blue side when wet they are slippery. Brown side not so bad. But, for cover tarps heavy duty IMO.
    Chvymn99 likes this.
  10. Backwoods Savage
    Usually best Frank. Especially in MI. But some areas, esepcially out east and the south get so much rain that it pays to top cover as soon as it is stacked. It will still dry. Then there is the Pacific NW. Nasty drying wood out there.
  11. Backwoods Savage
    That depends upon location. It will work well in your area.
    Frank and Beans likes this.
  12. Backwoods Savage
    Wrong!
  13. oldspark
    oldspark
    NW Iowa
    Why, if you stack in cubes or multiple rows then top cover is important due to the lack of air movement, single rows have much more air movement so top covering is not necessary.
  14. oldspark
    oldspark
    NW Iowa
    So single rows do not work in all areas?
  15. KaptJaq
    KaptJaq
    Long Island, NY
    I stack in "cubes" with about 6" between rows in the cube. Rows are 10' long and there are 12 in a cube. I top cover just before the leaves start to fall. I uncover just after the pollen season in spring. Late spring to late fall they remain uncovered.
    The reason I top cover is to keep the leaves, snow, and other garbage out from between the rows. Once they fill up there is little or no air flow and the wood takes forever to dry...
    KaptJaq
    NH mountain man likes this.
  16. oldspark
    oldspark
    NW Iowa
    Exactly what I am getting at, with the wood close like that the air circulation is reduced so top covering is necessary compared to single rows.
  17. Paul bunion
    Paul bunion
    I need to update my review on the Yuma Trading Greenhouse tarps. I have now had one in service for two summers and it is failing. The plastic/vinyl has become quite brittle. It is starting to crack where stressed. I can run my finger down against it and crack it between every reinforcing thread.
    So these tarps let the light through so the sun hits your stacks (Where it isn't blocked by the plywood scraps) and are sold in many sizes you aren't limited to 6x8 or 10x12. They also are less ugly than most other tarps. Blue ones are hideous, the silver/brown ones aren't so bad and these are even less visually offensive IMHO. But the their service life is the same as any other tarp that is readily available. Good or bad that's what they are. A little different but nothing special.
    Looking up from under you can see where only the threads are left
  18. Locust Post
    Well now......I guess its too late to heed your review, I have 2 soon to be delivered. I only get one year out of standard tarps and just can't seem to get a shed built so as the saying goes I guess.....it is what it is.
    Stinny, Chvymn99 and wildwest like this.
  19. NYCountry
    NYCountry
    Mohegan Lake NY
  20. Chvymn99
    Thanks for the heads up. Looks like I'll still be looking for rubber roofing material for long term, :confused: in the mean while.
    Bad link? Just get the regular page. I tried looking it up but still couldn't find it.
    Stinny likes this.
