Quadrafire CB1200 not starting - Control Box Amber light Blinks 3 times not feeding pellets
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Oct 1, 2016.
  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Got to run the leaf blower next,hey Don, I finally put that burn pot in the stove. I also managed to get a 40lb bag from the garage into the burn room.
    Russell and slvrblkk like this.
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Hi Kap.
    kappel15, Russell and slvrblkk like this.
  3. don2222
    don2222
    Salem NH
    Good d
    Good Deal Smokey
    Here is a great deal for your Twin cheap - name your price! It also has the snorkel set up, I installed it. :)
    Pellet stove
  4. Russell
    Russell
    South Coast , Massachusetts
    I have a CB 1200 and had the same issue , call light on but no fire . The thermocouple wire was not pushed all the way into the ceramic tube .
    SmokeyTheBear, slvrblkk and don2222 like this.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    Twisting the wire together is a temporary fix.
    If you kink a thermocouple, it will start to read at the kink and not at the end. They are very sensitive Don.
    As Jay said, it's a lesson learned. When they are gone? They are gone and need replaced.
    Russell likes this.
  6. don2222
    don2222
    Salem NH
    Good point about not reading at the very end unless it is welded at the tip!
    Thanks Dexter!
    DexterDay and Russell like this.
  7. don2222
    don2222
    Salem NH
    Here is a new one. :)
  8. kappel15
    kappel15
    Hey Smoke. Long time no hear
    jtakeman and slvrblkk like this.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    'bout time.
    jtakeman, slvrblkk and badbob like this.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Trying to be a good bear.
  11. kappel15
    kappel15
    Besides all of the above, you are into fairy tales too eh?:D
    jtakeman, slvrblkk and SmokeyTheBear like this.
  12. don2222
    don2222
    Salem NH
    Hello
    So I put the new one in and started the stove. Stove lights and fire dies out!!!
    The thermocouple wire is color coded with a Red & Yellow wire that goes to a terminal block just outside the control box. There is also a green ground wire from ground to one of the wires so I attached it to the yellow wire.
    There is no instructions anywhere showing which wire should be grounded???
    Luckily I had a new control box and it came with a green wire attached to a red wire!
    Finally I switched the yellow and red wire so the Red wire is attached to the Green ground wire and bingo the stove kept on going!!! WTF!!!
    Red to ground and no instructions stating that is correct???
    Can anyone verify this please?
    Russell likes this.
  13. jtakeman
    Ohhh boyzie.......... Did not the pellet stove master mark wire locations before removal of old??? :eek:
    Lemme look in the manual. Should be a wiring diagram................... :whistle:
    If I gotz to keep telling ya howz to fix it, Ize gonna wanna cut of da profitz!! :p
    :cheers: :beerbbq: :drunk:
    DexterDay, kappel15, Russell and 2 others like this.
  14. don2222
    don2222
    Salem NH
    Thanks Jay
    You know I did figure it out and electrically speaking nowadays a red wire would never be grounded!
    You can work with me anytime. :)
    There is only 2 screws and 2 wires on the terminal block no orange wire so:
    Where was that diagram?
    See attached Aladin CB1200 Wire Diagram I was working on with No Green Ground Wire. ???
    See red arrow
  15. Rich250
    Rich250
    Berks County PA.
    Man your tough Jt :bug:
    Russell, slvrblkk and jtakeman like this.
  16. jtakeman
    Is the replacement OEM or an aftermarket? I'd assume the oem would include a wire diagram if they changed something. But then again it could be in the service manual which IIRC is only available to tech's.
    Diagram I snipped came from the manual of Quads website. I got a few service manuals and some of the service bulletins/updates in a file at home somewhere. I'll dig through when I get a minute to see if they passed anything on to the tech's. Otherwise kappel15 would be they guy to contact?
    He's the master after all.... :p
    We be just stove nerds and deserve to be comped if we help........
    Russell, Rich250 and slvrblkk like this.
  17. don2222
    don2222
    Salem NH
    Hi Jay
    The Thermocouple is the OEM part you can see the packaging in my pic with the HHT part #
    I also have the OEM replacement control box and there is no wire diagram like that in either one.
    The cb1200 manual did not show it, so it looks like your diagram is for a different model.
    Not that it does not apply just curious which model stove?
    Thanks I appreciate your help.
  18. jtakeman
    slvrblkk likes this.
  19. don2222
    don2222
    Salem NH
    Hi Jay
    Thanks Again
    Look what I found! See attached file.
    Where is this stuff when you are in the field and looking at what else may be causing the issue? LOL
    Page 2 of 2 -- Quadrafire Thermocouple Grounding Kit for All Pellet Appliances.
    Russell, Rich250 and jtakeman like this.
  20. jtakeman
    Hearth and home website?
    slvrblkk and Russell like this.
