Quadrafire Castile random shutdowns
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Cash Larue, Jan 21, 2021.
  1. Cash Larue
    Cash Larue
    Pine, CO
    It’s been replaced twice and adjusted multiple times.
    ivanhoe, imacman and Russell like this.
  2. CleanFire
    CleanFire
    Greeting Cash, nice stove you got there!
    If not the vacuum switch: then would suspect an issue w/ the motor on the pellet auger.
    * Runs for (x) minutes.. then stops, as it heats up. (If the auger motor is original, I'd be checking this while running, monitoring w/ an IR thermometer, if here.)
    Jumpering the vacuum switch wires together, while running a fully attended test: would give you better info.
    Hope the feedback helps.
  3. Cash Larue
    Cash Larue
    Pine, CO
    Thank you for the feedback. I'll definitely try that if the vacuum switch doesn't fix it. I really appreciate the helpful advice from you. I also appreciate your help Russell!
    CleanFire, imacman and ivanhoe like this.
  4. Cash Larue
    Cash Larue
    Pine, CO
    ivanhoe SmokeyTheBear Russell Camber slvrblkk imacman unbidden CleanFire
    So - I got the new vacuum switch and hose in the mail last night. I installed the new switch and hose before dawn this morning and let er’ rip. I’ve started and intentionally shut the stove down three times. Each time, it starts up and continues to run now. So far, no unwanted shut downs have occurred. It’s blazing as we speak. Seems like the vacuum switch and hose may have done the trick. It’s funny, even the owner’s manual doesn’t even suggest the vacuum switch as a cause for nuisance shut downs. Thanks for all of your help with this. You guys have been great. I believe it was slvrblkk that suggested the vacuum switch. This is why I am a part of this prestigious club. So much great advice and thoughtful opinions.
    I’ll keep y’all updated if anything changes.
    Thanks again!
    schoondog, imacman, eatonpcat and 5 others like this.
  5. Russell
    Russell
    South Coast , Massachusetts
    That’s awesome. It was great for me as well to know more about the QuadraFire
    imacman, slvrblkk, Cash Larue and 2 others like this.
  6. ivanhoe
    ivanhoe
    Northern Ontario
    Write some valuable notes in your manual for future references :smoke:
    Glad everything work out for you :thumbs:
    schoondog, imacman, Russell and 2 others like this.
  7. eatonpcat
    Just proves that even the blind squirrel...
    imacman, jtakeman, Russell and 3 others like this.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    :D
    Ssyko, ivanhoe, schoondog and 5 others like this.
  9. jtakeman
  10. imacman
    imacman
    Denver, NC
    Is he related to the blind chicken that finds a kernal of corn occasionally?
    ivanhoe, jtakeman, Cash Larue and 2 others like this.
  11. eatonpcat
    Yes sir, we call the blind chicken Will, he can't find a kernel of corn, but if you send him out into the woods in any direction he always comes back with a 30 box of Blue Smoothies!!! I luv that little fukker!
  12. slvrblkk
    slvrblkk
    Northampton, PA
  13. imacman
    imacman
    Denver, NC
    jtakeman, ivanhoe, eatonpcat and 3 others like this.
