Quadra fire 1200 newbie
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by tammysteve1971, Sep 3, 2017.
  1. tammysteve1971
    tammysteve1971
    Ok
    Sent from my SM-S820L using Tapatalk
    IHATEPROPANE likes this.
  2. imacman
    imacman
    Denver, NC
    Get that cleanout panel off that Don2222 mentioned....I'm guessing a LOT of ash in there. As I said earlier, don't believe what people will tell you about how they did a "complete" cleaning..... :picard:
  3. tammysteve1971
    tammysteve1971
    Where is that. I'm doing a cleaning today
    IHATEPROPANE, slvrblkk and Russell like this.
  4. tammysteve1971
    tammysteve1971
    It is dirty but we need to get a vacuum for it.Can I use a shop vac
    IHATEPROPANE, Russell and slvrblkk like this.
  5. Russell
    Russell
    South Coast , Massachusetts
    It should be on the bottom right , a little rectangular panel with 4 screws .
    IHATEPROPANE and imacman like this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    Ash collects in that area. When you take the cover off you will know if they "cleaned" that stove regularly or not. There should be ash in there obviously but not filled up with it.
    You'll need to take both blowers out and clean them. You'll need a replacement gasket for the combustion blower though.
    IHATEPROPANE, imacman and Russell like this.
  7. slvrblkk
    slvrblkk
    Northampton, PA
    You can but you'll need to get a drywall filter or something of that sorts for it or you'll be blowing ash out the exhaust of the vacuum. The regular filter isn't fine enough to stop the ash from passing through it.
  8. tammysteve1971
    tammysteve1971
    These are the pictures. It is a little rusty and the pot is alot of rusty. Hopefully the rust is not going to be a problem [​IMG][​IMG][​IMG][​IMG]
  9. tammysteve1971
    tammysteve1971
    It definitely needs a good cleaning today
  10. tammysteve1971
    tammysteve1971
    We are painting it
  11. slvrblkk
    slvrblkk
    Northampton, PA
    A little elbow grease and a lot of that will clean up. That must be an older one, does it have the gold "Quad" logo on the front glass? They also changed to a stainless steel hopper too in the midish 2000's I believe. You'll want to get the hopper bottom as smooth as possible so the pellets "slide" and don't hang up on the rust.
    IHATEPROPANE, Russell and jtakeman like this.
  12. tammysteve1971
    tammysteve1971
    It's packed where the pellets go down.
  13. tammysteve1971
    tammysteve1971
    Are the switches for off and on
  14. slvrblkk
    slvrblkk
    Northampton, PA
    Off the top of my head a few things you should replace right off the bat is the door gasket (it's 7/8"), all of the door glass gasket (tadpole gasket), ashpan gasket, igniter, burnpot gasket. You should fully pull the burnpot and make sure all or the holes are open on it. Some holes on the bottom of the pot could have gotten clogged over the years if the stove wasn't properly maintained.
    IHATEPROPANE and Russell like this.
  15. slvrblkk
    slvrblkk
    Northampton, PA
    One switch is hi/low and the other it fan speed. There's no on/off switch, that is controlled by the thermostat.
  16. tammysteve1971
    tammysteve1971
    Lots of work. I'm hoping we didn't get scammed
    IHATEPROPANE and slvrblkk like this.
  17. tammysteve1971
    tammysteve1971
    Ok
  18. slvrblkk
    slvrblkk
    Northampton, PA
    When you say "packed" are the pellets still whole of like wet/mushy?
  19. tammysteve1971
    tammysteve1971
    No
  20. tammysteve1971
    tammysteve1971
    They are dry
