Quadra fire 1200 newbie
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by tammysteve1971, Sep 3, 2017.
  1. imacman
    imacman
    Denver, NC
    A plugged exhaust system will cause the same problem too.
    Russell and IHATEPROPANE like this.
  2. tammysteve1971
    tammysteve1971
    Well the motor is shot
    Sent from my SM-S820L using Tapatalk
    IHATEPROPANE likes this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    You should not be able to turn the motor by hand.
  4. will711
    will711
    Pocono Mts.
    That's too bad :(
  5. slvrblkk
    slvrblkk
    Northampton, PA
    The other thing, unless you have the terminals jumped for the thermostat, it will not be calling for pellets thus the auger won't be turning either.
    Russell, IHATEPROPANE and jtakeman like this.
  6. tammysteve1971
    tammysteve1971
    We are going to replace the motor. Just frustrated about it
  7. slvrblkk
    slvrblkk
    Northampton, PA
    IMO....before you start throwing parts at that thing, get everything thoroughly cleaned and replaced (glass, gaskets) and get it all put back together and see what happens. You may be spending money you don't need to spend.
    IHATEPROPANE, imacman and Russell like this.
  8. tammysteve1971
    tammysteve1971
    We are thank you
  9. imacman
    imacman
    Denver, NC
    Here's hoping that they didn't try turning the shaft, and just put 120 v to it. The gear case can be opened up too, IIRC......maybe solid, old caked up grease in there stopping things from moving???
    IHATEPROPANE and Russell like this.
  10. tammysteve1971
    tammysteve1971
    We didn't turn it.
  11. tammysteve1971
    tammysteve1971
    Our friend is very good when it comes to checking things. It won't run . No hum no nothing
    Russell, IHATEPROPANE and imacman like this.
  12. imacman
    imacman
    Denver, NC
    Keep us up-to-date on your progress, and keep the pics coming (hint: we love stove pics, burning or not). We love seeing a stove brought back from the dead. :fire:
  13. tammysteve1971
    tammysteve1971
  14. Russell
    Russell
    South Coast , Massachusetts
    Seeing I'm in there here's a pic of the igniter and the bottom of the burn pot .[​IMG]
    Sent from my Moto G (4) using Tapatalk
    IHATEPROPANE, imacman and slvrblkk like this.
  15. tammysteve1971
    tammysteve1971
    That's good on it. It's the auger motor we have to order
  16. tammysteve1971
    tammysteve1971
    We desided that we are using the wood stove again this year. Due to finances.
  17. tammysteve1971
    tammysteve1971
    We will be using the wood stove again this year. Financially we can't get everything it needs to work
  18. jtakeman
    tammysteve1971 something just dawned on me, That auger motor may not be bad. The stove will not make enough vacuum to pull in the vac switch without glass installed.
    So don't give up on that yet. Jump the vac switch(connect the 2 wires together) to test the auger.
  19. tammysteve1971
    tammysteve1971
    We will see in the spring. It's in storage now . May just sell it for what we paid for it .
    imacman, Russell and IHATEPROPANE like this.
  20. tammysteve1971
    tammysteve1971
    Husband said in the spring or tax time we will get one that we know works.
