Punk oak?
Discussion in 'The Wood Pile' started by North woods, Nov 29, 2014.
  1. oldspark
    oldspark
    NW Iowa
    I cut Bur Oak all the time that has a layer of punk on the out side and do not cover my wood, stacked in single rows it sits for 2 to 4 years (even more in some cases) and the punk migrates very slowly if at all to the center of the splits and or rounds.
    The key is the wood not staying wet, if it drys out quickly it will not rot, here in Iowa with the winds we have the single rows take care of that.
    Backwoods Savage, jetjr and papadave like this.
  2. papadave
    Mine dries gooder all summer, then over the fall, winter, spring cycle, it gets wet and slightly punkier. Slow process.
    I'm slowly working on moving into the shed the last of some Oak I finished from a log load back in November of '11, and it's starting to get a little worse.
  3. jetjr
    jetjr
    Pa/Md line
    Man those are some nice deer. If those are in the basement what are you hiding upstairs?
  4. Fanatical1
    Fanatical1
    Nice looking stacks NW! :yes: Your starting to develop a serious hoarding problem... :whistle:
    Nothing wrong with that punk ring, and yes, that oak will still need to dry for several years. I try to keep any of the punky stuff topcovered and as dry as possible and when its seasoned, bring it undercover a little longer than normal to dry out that punky stuff out real gooder. ;)
    papadave and Backwoods Savage like this.
  5. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    At first I thought Punk Oak was a different kind of oak I didn't know about.:D
    Fanatical1 and papadave like this.
  6. Backwoods Savage
    Worry not North Woods. That inch of punk around oak is very common and will do no harm so long as it is kept dry. Just so you know it has to be kept dry you'll be fine and no harm done in the stove either.
    Now about those bucks! Those are some dandies indeed. Are they Wisconsin deer?
    Fanatical1 likes this.
  7. bogydave
    Nice stack & racks :yes:
    Your in trouble, the wood addiction has you! LOL
    It's real bad too. :)
    You will have no problem getting ahead now.
  8. North woods
    North woods
    Wisconsin
    All my mounts in the new house are in the basement (my man cave area) except a 1/2 mount bear that is still at myarents and a pronghorn that is at the taxidermy shop yet. They are wisconsin deer I have deer mounted all have been officially scored 126", 154", 159", and a 174" non typical those are all net scores.
    Backwoods Savage and jetjr like this.
  9. Backwoods Savage
    I do not doubt for a minute that those are net scores. Congratulations.
  10. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I had a load of white oak that had VERY soft and punky sapwood. If you keep it dry, itll be fine. When it gets rained on, it soaks up water like a sponge and dries slower than a normal split. Id top cover any punky stuff for sure, or at least plan to let it dry inside or in a shed for a bit before using it
    jetjr likes this.
