Pulled the trigger !!
Discussion in 'OWB's and Gasification Boilers' started by JB Sawman, Sep 13, 2022.
  1. JB Sawman
    JB Sawman
    pennsylvania
    Inamed it ELMO "FEED ME ELMO" :rofl: :lol: jb
  2. JB Sawman
    JB Sawman
    pennsylvania
    Hey Just a update I do have a good coal bed now I cannot believe how little wood this boiler uses maybe 6-8 splits a day I have let it go 16 hrs between loadings It was changing the fire controller that took care of not being able to keep the fire going and the bed of coals (used some hickory and locust) makes the new splits light right up as soon as the blower kicks on JB
    Barcroftb, Chaz, yooperdave and 3 others like this.
  3. JB Sawman
    JB Sawman
    pennsylvania
    I cannot believe how many people come in my shop and when they pass the furnace on the drive their first comments are usually Hey you bought one of those outdoor stoves you can burn anything in them even pine !!!! and they tell me of somebody they know who has one and they burn their garbage, tires (They smash them in a log splitter and wire them so they will fit in the door :headbang::doh: another customer said his brother burns oil filters in his :hair: it is no wonder these boilers got a bad rep but I do feel so much better now that I can burn pine :rofl: :lol: JB
  4. lukem
    Pine will set your chimney on fire, even in an OWB. Facts.
    Barcroftb, Chaz and JB Sawman like this.
  5. brenndatomu
    You have a chimney fire with a gasser, you're doing it wrong...:rofl: :lol:
    morningwood, Barcroftb, Chaz and 2 others like this.
  6. JB Sawman
    JB Sawman
    pennsylvania
    I have never had a chimney fire in 45 years of burning wood I have burned all kinds of wood including pine if it is dry wood and you clean your chimney regularly it does not happen . Fact
    Barcroftb, Chaz, billb3 and 2 others like this.
  7. JB Sawman
    JB Sawman
    pennsylvania
    Well heating season is approaching the end I am considering keeping the boiler running to make hot water and get rid of the sawmill slabwood which has been stacking up for several years I only check it once a day now and it uses very little wood just wondering if anyone else keeps theirs running maybe pros&cons thanks JB
  8. campinspecter
    campinspecter
    I, ve run our system steady for 40+ years only burns a cord begging in May through end of September ! No condensation problems , no circulators that seize , no leaks from shrunk gaskets .
    Barcroftb, Chaz, Woodwidow and 3 others like this.
  9. Creekin
    Creekin
    Manitoba
    This year I've been making a fire in the early evening and will let it go out till the next day, like a batch burn
    Previous years kept it going due to the fact I wasn't working from home, but small loads
    Barcroftb, brenndatomu and JB Sawman like this.
  10. JB Sawman
    JB Sawman
    pennsylvania
    Thanks for the input I was kinda thinking that like anything else it is better to keep it working JB
  11. JB Sawman
    JB Sawman
    pennsylvania
    Thanks for the reply I have been checking every 24 hrs and I only have to put in a couple of small splits JB
  12. lukem
    I batch burn mine in the summer. Light it around noon, let it hit 180 and turn it off. That's plenty of hot water for showers and dishes in the evening. It gets pretty gunked up if it idles all summer.
  13. JB Sawman
    JB Sawman
    pennsylvania
    Thanks for the input!! I noticed that it is getting more residue in the firebox the reburn chamber and the rest are just grey dust still and the chimney is clean it did get cool again 30's at night so it did clean itself up some
    Barcroftb, brenndatomu and Farmchuck like this.
  14. JB Sawman
    JB Sawman
    pennsylvania
    Well getting ready to start year 3 I had a bunch of buildup in the fire box finally ended up using a needle scaler to break the worst of it up . Last month I went to the logging show and talked to the central boiler rep . The extra buildup is from me filling the firebox to much !! seems the small boiler I have needs to burn down more than I am letting it he recommended a smaller fill so I did not have such a big bed of coals so I guess I will not need as much wood !! I thought 8-10 splits in 24 hours was good !! I guess It was too much and I was overfilling :headbang: so I will give it a shot this year with less when I fire it up this season JB
  15. lukem
    I save up cardboard and burn it hotter than the blazes of hell once a week or so and it really keeps the build up to a minimum.
  16. Horkn
    Plus even not activated, those phones will still dial 911 in an emergency
    JB Sawman, brenndatomu and Barcroftb like this.
  17. JB Sawman
    JB Sawman
    pennsylvania
    Well update on the boiler I fired it up Oct 11 this year I am using a lot less wood since I am following the suggestion of the Central Boiler rep I talked to at the woodsmans field days in august . I only put what burns up in 12 hours depending on temp's usually 4 to 8 splits (avg size 5 to 6 inch splits) and make sure to mix up the coals good it has not given me any problems this year yet ( only 1 cord through it so far) and also keeping the wood centered in the firebox to keep the air moving better . I have had some nights in the teens so far and it is working great !! JB
