Pull behind wood haulers (post em here)
Discussion in 'The Wood Pile' started by Wise8706, Apr 8, 2016.
  1. LinkedXJ
    LinkedXJ
    Indiana
    I sold 2 of my jeeps yesterday, told the guy id deliver them both.
    Looked up the wheel base of a 4 door cherokee, sweet they'll fit.
    Added a few feet for bumper over hang and what not. Was still about 1.5ft short.
    So i couldnt stand my ramps up and store them for transport like they should have been, literally
    had to hold them up with straps. Well when ya do that, they are still pretty low and vulnerable
    to catching things while driving.
    I stopped for gas, had to turn around to grab a stop light to hit the highway.
    As i turned around, the rear of the trailer drug and caught the edge of some pavement.
    The ramp is what caught actually, it was violent enough to bend that solid steel 1-1.25" bar.
    Corner of the ramp is pealed up a bit but that part is easily fixable.
    This bar, if i cant heat it and bend it back, im going to have to cut the end off to slide it out
    so i can get it replaced.
    Im half temped to just take it to a localish trailer shop and have them fix it.
    Chaz, clemsonfor and bear 1998 like this.
  2. bear 1998
    bear 1998
    S.C.Pa
    Sh!t Happens.....
    Chaz, clemsonfor and LinkedXJ like this.
  3. LinkedXJ
    LinkedXJ
    Indiana
    Exactly
  4. LinkedXJ
    LinkedXJ
    Indiana
    Fixed.
    Took about half an hour.
    Had to buy a full stick of 1.5" x 12' cold rolled steel though. $127
    Stlshrk, Gasifier, Chvymn99 and 11 others like this.
  5. OhioStihl
    OhioStihl
    Southern Ohio
    Could of been worse. I’m sure you feel better having it fixed.
    LinkedXJ, bear 1998, Chaz and 2 others like this.
  6. clemsonfor
    Your luck sounds like mine.
    I do stuff twice all the time!!
  7. Midwinter
  8. MikeInMa
    Maybe at next year's GTG, bogieb's bike can be modified as and activity. A log can be had, and I'm sure there's some cutting torches and welding equipment that can be brought onsite.
  9. Midwinter
    Tough on the brake shoes!
    Winston, Dancan, brenndatomu and 3 others like this.
  10. SkidderDone
    SkidderDone
    Pollock Pines
    I'm in the middle my wood slaying chariot conversion right now. :dex: I got it when my dad passed. We used it for hauling dirtbikes. I don't ride anymore so it's being recommissioned for firewood. I torn down an iron fence last year so I repurposed the posts for side board posts and the 2x6's are going on this week. The box will end up measuring 4.5 x 3.5 x 8 so I'll be able to get just under a cord in it (if it's dry enough). I'm pretty excited about the toolbox. It'll fit my 2 saws and still have some room for odds and ends. The box locks which'll be great for stopping for after wood cutting beers. :coldone: I'll try and remember to post something when it's done. 20180812_125928.jpg
    Stlshrk, Gasifier, Dancan and 14 others like this.
  11. clemsonfor
    What size axle is on that? A green cord will weigh just under 6000 pounds. 2.9tons per cord is what we go by. And I see its single axle. Hope it's at least a 5000 pound axle so it's not like 2 times over its rating:faint:. Don't forget all that trailer, iroN you just added and all the wood weight count in that trailer axle weight limit.
    I by far am no safety police and will not say I have never hauled over loaded but can't say I haul double my limits very often...if at all.
  12. SkidderDone
    SkidderDone
    Pollock Pines
    Oh for sure thanks for the info and thank you for looking out! :thumbs: It's a 3500# axle. I burn a lot of Ponderosa Pine which according to the reference table I have has a seasoned cord weight of about 1900 - 2500#. If I was going to commit to a big load of Ponderosa I would definitely check the moisture content to guesstimate load. There is no way I can get a cord of oak it my trailer that would be :loco: :crazy:
  13. metalcuttr
    metalcuttr
    western WA
    The "Brown Beast" loaded up again with seasoned Fir. Finally got that load I was promised way back. The home owner had already rolled most of the rounds to the front yard and I helped with the last of them. The HO, a friend and I all busted the rounds to manageable size and split the wood evenly. This is 2 year down rounds that were stacked on edge against a chain link fence. Most of the bark came off fairly easily and the wood was nice and seasoned. Definitely for this years burning. The trailer is 4'-6" X 8'-6" so about 3/4 of a cord. Now I need to fire up the splitter and do the final split and stack. bonusfir.jpg
  14. Midwinter
    Nice cooperative effort, and great to have something immediately burnable.
    clemsonfor, brenndatomu, Chaz and 7 others like this.
  15. LodgedTree
    LodgedTree
    Maine
    I have been waiting for my 18 foot trailer. I thought it would show up today, but I guess not. The guy that is sawing my wood up on his Norwood Bandsaw mill used it to take some wood home and discovered a slow leak in one of the tires. He wanted to take care of it before he returned it, but I kind of need it.
    Not wood hauling, but for hay. I sold some 40 round bales to the Amish and I would like to get them over to them.
    I have no idea what I will do with it besides that. My Explorer is too small to pull this beast which was a swapsies kind of thing. It was one of those things where I weld this other 5th wheel trailer for a guy and get this flat bed trailer as payment. It works for me, I can weld and have nothing but time anyway.
    As for pulling the hay, I'll just use my tractor. A slow method, but it will work.
  16. metalcuttr
    metalcuttr
    western WA
    Got the wood split and temporary stacked. Measured at 7/8 cord +or- depending on which way you fudge. I think I may tarp this and use it for early season. wood1.jpg wood2.jpg wood3.jpg
  17. T.Jeff Veal
  18. Mag Craft
    Mag Craft
    South East Wyoming
    Looks like your ready for winter. Nice.
  19. TurboDiesel
    Size doesn't matter. Thats what I call, Beautiful BTU's ! :salute:
    Very nice, Metalcuttr!:handshake:
  20. T.Jeff Veal
    That's what she said....:rofl: :lol::rofl: :lol::rofl: :lol::picard::picard:
