Progress Hybrid rolling some awesome secondaries
Discussion in 'Modern EPA Stoves and Fireplaces' started by dirtdevil, Nov 2, 2019.
  1. Hoytman
    Hoytman
    OH
    Get this...
    Anthracite coal stoves are exempt from regulations...yet many of the stoves designed to burn anthracite will burn with blacked out glass...even with their air wash technology. Legacy stoves for example...used to be under the Harmon brand...made by Harmon. Their TL series and there Mark series all...borrowed from Harmon, under the AHS/Legacy name (Alternate Heating Systems/Legacy) have and use the most modern of Harmon/Legacy airwash designs...yet the coal...as clean as it burns...still turns the glass back. Why?
    If nothing else comes of these posts, at least you know I hate dirty glass. Might as well have a solid front stove.
  2. RGrant
    RGrant
    Connecticut
    That is a beautiful stove....
    How well does it get you through the winters?
  3. billb3
    No one promised you a rose garden.
    A dirty window just means the stove has been used in low mode, or poor fuel.
    I doubt you'll find in any user's manual a promise of a clean glass in low mode or when using poor fuel.
    Just the way it is.
    An air wash doesn't clean the window. It helps keep the window clean.
  4. dirtdevil
    dirtdevil
    Northern central Indiana
    It does really well. When it gets below 10 degrees or so I turn on a blue flame wall heater in the basement, other than that it is our only heat source in a 120 year old two story brick farmhouse.
  5. MAF143
    MAF143
    North Central OH
    dirtdevil, are those stone window sills next to the picture of the stove??? if so, I'm jealous. Nice work. When we built in 2007, my wife insisted on real window sills. Ours are stained, / poly-urathaned wood, but I'm very happy we have window sills throughout the house instead of picture frames.
  6. papadave
    If I had the money when I got my 30, I would have opted for a BK, dirty glass or not. My glass is dirty right now, but stays clean for a while once outside temps drop and I can get a better burn. Cleaning the glass isn't a day long affair. Unless I let it go way too long, I can clean the glass in less than a minute. Been burning most of the month of Oct....lots of small fires and only wiped the glass twice. Not really needed, but I was bored.
    Dry wood is key, and even with dry wood, older stoves still aren't even close to burning as cleanly as newer stoves.
    I highly doubt ANY stove will burn so cleanly as to keep the glass from getting gunked up at least partially.
    The perfect stove that always has clean glass and a perfectly clean flue system hasn't been made yet, that I'm aware of.
    Time to jump off the fence and pick one. As I said, I'd buy a BK in a heartbeat if money wasn't an issue....whichever size I needed (I know which I need/want).
    So in summary, get a new BK, burn dry wood, clean the glass every once in a while, and be warm. Done, and done.
  7. Hoytman
    Hoytman
    OH
    Going to have to wait. Here's why...
    ...I've got Hitzer 354 coal stove I'm going to try first. Got it barely used for a song... It'll burn wood, bituminous, or anthracite...which is what I'm wanting to try. If I don't like it, then I can think more about a wood stove. By then 2020 regs should be well in place and manufacturers will have plenty of more models coming by then, I am sure.
  8. papadave
    Oh yeah, I forgot about that.
    Good luck.
    I bet the glass gets dirty on all of 'em. :whistle::rofl: :lol:
  9. Hoytman
    Hoytman
    OH
    You're probably right. LOL!!!
  10. Marvin
    Marvin
    Huntingdon, Pa
    They are made every day. They just haven't left the assembly line and had a fire in them yet:rofl: :lol:
  11. papadave
    Picky, picky, picky. :picard::D
  12. dirtdevil
    dirtdevil
    Not stone, just wood that has been stripped of the paint. Need to get the rest of the trim stripped and put back on. Then get some stone laid up behind the stove. Old house, slow remodel..:makeitrain"
  13. MAF143
    MAF143
    North Central OH
    Been there, Done that... good luck and I'm sure it will come out like you have envisioned it. Nice stove for sure... Great stuff takes time.
  14. T.Jeff Veal
    Hope it will be ok to post a shot of our little Drolet Blackcomb burning secondaries on all 3 tubes...guy saw it this morning, thought I had gas in them...lol...
  15. Hoytman
    Hoytman
    OH
    Whoa! That is sweet!!!!
  16. T.Jeff Veal
    Thanks
    FatBoy85 and Chazsbetterhalf like this.
  17. papadave
    Hey look, the glass is clean. :whistle::dex:
  18. T.Jeff Veal
    Didn't have much choice, with those flames against it...:dex::dex::thumbs:
  19. Hoytman
    Hoytman
    OH
    Got me in that one papa!!!
  20. papadave
    :D
    Hoytman and FatBoy85 like this.
