professional install?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by T-BONE, Feb 7, 2015.
  1. wildwest
    I don't remember if it worked or not, someone here ended up having condensation problems. I think he insulated the OAK.
  2. T-BONE
    T-BONE
    I heard that it doesn't get condensation inside the pipe just the outside of the pipe in the house because of the warm air.
    is that true?
    should I worry about condensation on the pipe?
    wildwest and gbreda like this.
  3. will711
    will711
    Pocono Mts.
    T, I believe that is correct just put a aluminum brownie pan under the pipe to catch the water as it drips off the pipe .
  4. wildwest
    I would wait and see first, atleast its correctly connected now! I have never had any condensation. If infact your misled installers did that on purpose and you do have condensation, will's post above sounds like an easy solution :)
    eatonpcat, slvrblkk and will711 like this.
  5. T-BONE
    T-BONE
    It seems like that also fixed the woofing.
    and I called him on that a month after I got the stove.
    wants to make a sale but no good after the sale.
  6. wildwest
    :thumbs:
    :picard:
  7. subsailor
    subsailor
    Winthrop, Maine
    That's surprising with the cold temps you've had. Everytime (everyday lately) we get close to or below 0 my OAK frosts over hard. The entire length of it is white.
    eatonpcat and wildwest like this.
  8. badbob
    badbob
    My upstairs stove oak frosted over hard,first 2-3 inches,when it was -15.Just threw a rag under it.Soon as it got 0 went away.I can live with that.
    wildwest likes this.
  9. wildwest
    I am sure my situation is unique, just like everone's situation is different...(very low humidity, and OAK that feeds from an almost enclosed porch, but even at -33* I have not seen any. My OAK in insulated too. Not sure if it would have had condensation if it was not insulated with the extreme temperature differences between outside and inside? That being said I struggle to keep the humidity in here above 20%.
    Still think he should not worry until *if* it happens :)
    Sub, do you get condensation?
  10. subsailor
    subsailor
    Winthrop, Maine
    Not sure what you mean. The condensation we're all referring to is the frosting of our OAK's and yes, like mentioned above, I do get it. If you're referring to inside the pipe, I don't know, I've never checked it.
  11. wildwest
    Yes, condensation on the outside of the OAK. Like an iced tea glass in the summer dripping on the table. We are on the same page :) I just wanted to explain in my last post that we have extremely dry air inside that may reduce any condensation on the OAK :thumbs:
  12. Lousyweather
    Lousyweather
    don't think so
  13. Lousyweather
    Lousyweather
    nah, sounds like BS
    wildwest and slvrblkk like this.
  14. Lousyweather
    Lousyweather
    I like to make sure the pipe is removable so I can easily check the intake damper if problems should arise.....I like a radiator hose clamp there......don't like tape OR RTV
    wildwest and imacman like this.
  15. Lousyweather
    Lousyweather
    the Harman OAK has insulation...DO NOT insulate it......by putting insulation in there, you can obstruct the flow of intake air AND cause heat buildup. DO NOT modify the thimble.
  16. Lousyweather
    Lousyweather
    its a relative humidity thing.....since your air is so dry, takes VERY low temps to get condensation.....heck, you guys have sublimation out there....snow can go from a solid to a gaseous form without ever entering the liquid state.......something I am jealous of.
  17. subsailor
    subsailor
    Winthrop, Maine
    Well I wish the next round of 12"-20" coming Sat-Sun would sublimate.
    imacman and wildwest like this.
  18. wildwest
    I did my share of complaining about last winter, but what I have seen that you are going through this year makes my jaw drop. Hang in there!
