Production Woodstock IS
  1. BrianK
    BrianK
    West central PA
    I've never had an all steel stove. My first stove was a Woodstock Fireview. It had a 2.2 cu ft firebox. Our Beta Ideal Steel stove had a 3.2 cu ft firebox but threw out double the heat in less than half the time. I don't know if that answers your question or not but I'd assume the IS is more comparable to a steel stove.
  2. burndatwood
    burndatwood
    VT
    Welcome to the site. You've come to the right place - a lot of beta testers for the Ideal Steel here. Beautiful stove by the way, and great photo.
  3. Blue Merle
    Blue Merle
    South Jersey
    That helps. We might be looking to go a little bigger after this winter but are concerned about getting roasted out of the stove room. We like the softer heat of the soapstone, so we may need to go with the PH if we upgrade. We'll see how the improved insulation does this year before we make a decision. Thanks for the info!
  4. Blue Merle
    Blue Merle
    South Jersey
    Thanks! Nice set you have, as well!
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    I wonder if the stone inside the stove gives off the same warmth Blue Merle was describing? Despite it being a steel stove, it's kind of the best of both worlds, just that the stone is on the inside.
    Chaz likes this.
  6. burndatwood
    burndatwood
    VT
    Thanks for the compliment! We're getting the IS installed in September, and will be running the Progress Hybrid as well. I'll likely create a post with some comparisons in case you're trying to decide between the two. Our IS will have the soapstone liner, and the side panels as well. I frankly don't know if the firebrick option instead of soapstone would affect how quickly it throws off heat and retains it at the end. Gonna be an interesting winter!
    Chaz, papadave and Backwoods Savage like this.
  7. Blue Merle
    Blue Merle
    South Jersey
    Ill keep my eyes peeled for the thread on the comparisons. Thanks in advance!
    burndatwood likes this.
  8. burndatwood
    burndatwood
    VT
  9. weatherguy
    weatherguy
    central massachusetts
    I went bigger this year (PH) and would have went with the IS but it would have required some work to get it to fit. I picked my PH up yesterday and talked to the folks at Woodstock about the two stoves. The IS can be turned down lower and has a longer burn but the PH has a higher top end. The IS is a beast though I can tell you that, pictures on the web don't do it justice as to size, its one big honking steel stove, beautiful in the flesh (or steel).
  10. My IS heats my home
    My IS heats my home
    Albany, NH
    There was no way to make it (IS) fit? even bringing the legs completely to the lowest setting?
    Chaz likes this.
  11. weatherguy
    weatherguy
    no, it was still about an inch too high, its a big stove. I think having the higher top end of the PH will be better any way.
  12. burndatwood
    burndatwood
    VT
    I'll second you on the impression you get when you see this stove in person. The PH just doesn't have the same effect on me, even though it's a big stove too. "Big honking" for the IS captures it perfectly. :rofl: :lol: The only bigger stoves I've seen are old kitchen stoves. And I'm very glad to see how beautiful the various custom stoves are looking, especially since it had its detractors early on at another site especially.
  13. Blue Merle
    Blue Merle
    South Jersey
    Can anyone give me the dimension from center of the top flue outlet to the back of the stove? I have a corner install and want to see how it will sit on the hearth.
    Chaz likes this.
  14. My IS heats my home
    My IS heats my home
    Albany, NH
    for the WS IS?
    Chaz likes this.
  15. Blue Merle
    Blue Merle
    South Jersey
    Yes
    Chaz likes this.
  16. My IS heats my home
    My IS heats my home
    Albany, NH
    If You want to PM me your email address, I can send you the WS IS manual
    burndatwood and Backwoods Savage like this.
  17. Blue Merle
    Blue Merle
    South Jersey
    Perfect! Now I just need to figure out how to PM.
  18. My IS heats my home
    My IS heats my home
    Albany, NH
    I'll send you a message and you can respond with your email
    Chaz and BrianK like this.
  19. Blue Merle
    Blue Merle
    South Jersey
    Thanks!
  20. Backwoods Savage
    For future use, you "start a conversation". For example, if I wanted to start a conversation (PM) with you, I could just click the mouse on your name (right under your avatar). That brings up another window and you then choose "Start a conversation" and you can start typing.
    papadave and My IS heats my home like this.
