Production Woodstock IS
  1. Oldhippie
    Oldhippie
    Ashby Ma
    Gorgeous install! Looks Great!
  2. Oldhippie
    Oldhippie
    Ashby Ma
    WOW getting that stove down those ramps was something I wouldn't want to see... kudos that you were able to get it done.
    Chaz and Backwoods Savage like this.
  3. Unhdsm
    Unhdsm
    Bradford, Vermont
    This stove absolutely gets to temp quickly--- even with the soapstone liner. It also puts the heat out fast through the big window. There is room enough to build a small fire though if you want it to climb slowly for a break in fire.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    I thought the same thing, looks like it has no load on it at all.
  5. Beet Stix
    Beet Stix
    NW Ohio
    Ya'll are making her blush. Best purchase I have ever made. $500 on the side of the road. In line six with 190,000 miles. I have had it 18 months and only had to change the oil. Full bed that can handle a full load of wood.
    burndatwood, Todd, papadave and 3 others like this.
  6. JA600L
    JA600L
    Lancaster, Pa
    My stove is built . The picture is on their Facebook page. Log cabin with bear.
    Chaz, milleo, concretegrazer and 3 others like this.
  7. My IS heats my home
    My IS heats my home
    Albany, NH
    Congratulations...I'm still 3 weeks behind you :(
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    I just looked at it and commented. I like your design, do you come up with the idea yourself??
  9. JA600L
    JA600L
    Lancaster, Pa
    Chaz, My IS heats my home and BrianK like this.
  10. JA600L
    JA600L
    Lancaster, Pa
    Which design did you go with?
  11. My IS heats my home
    My IS heats my home
    Albany, NH
    I have a maple leaf. Fairly simple design.
    I asked them to paint the leaf a red color
    so it would standout from the charcoal.
    My build week is the 19th.
    Did WS send along a stovepipe therm in the
    firebox with the other loose parts? I questioned
    why they didn't have a probe thermometer, they
    said they didn't have a vendor yet.
  12. JA600L
    JA600L
    Lancaster, Pa
    I did not receive the stove yet.
  13. My IS heats my home
    My IS heats my home
    Albany, NH
    This is to BrianK and UNH. I know you both had betas last season and I'm not sure if BK had a thermometer port but it looks like UNH did, for the cat probe thermometer.
    When I spoke to WS they said the stoves are delivered with the port but also with a stovepipe thermometer. Something about not getting tied into a vendor for probe thermometers before the deliveries started this July.
    You guys know anything about this?
  14. BrianK
    BrianK
    West central PA
    I received a stove top/stove pipe Woodstock thermometer. My stove has the cat probe bung hole which is closed with a small bolt or screw, not sure which. I have not heard anything about them shipping a cat probe thermometer but I doubt that I'll use one.
  15. My IS heats my home
    My IS heats my home
    Albany, NH
    I was reading the manual last night and went over some things the second time this morning. The thermometers subject were worth a post IMO. I think I'd like to try the probe vs the magnetic type.
    I'll have to ask if they recommend any certain brand and model number.
    Chaz likes this.
  16. Unhdsm
    Unhdsm
    Bradford, Vermont
    The thermometer in the picture was just a stovetop one. That was the hottest spot on the stove. I will, however be using every option because I am compulsive about knowing all the different temps.
    Chaz and BrianK like this.
  17. Backwoods Savage
    I believe Woodstock ships a thermometer with every stove. We'll be going into our 8th year with the Fireview and as of last spring that thermometer was still within 20 degrees at several temperature readings vs the IR gun. We've tried some other thermometers but they were not accurate at all. I hate to say bad about companies but the Rutland (we had 2) were pure junk.
    Chaz and Slocum like this.
  18. Beet Stix
    Beet Stix
    NW Ohio
    I had been wondering about this myself. Since I have a rear vent install and a liner, I cannot get a stovepipe temperature. When Woodstock posted that they were adding a port for cat probe, folks seemed to think that would be helpful. I was surprised they didn't send one. I know Condar has several cat probes at various lengths on their website. I am sure Woodstock could recommend a length. Any thoughts on the advantages of cat probe?
    Chaz likes this.
  19. Backwoods Savage
    I could not see any advantage to it so have never concerned myself with it. If I want to know if the cat is working, I simply look at it and also the stove top temperature. Tells me what needs to be known.
    Chaz likes this.
  20. Blue Merle
    Blue Merle
    South Jersey
    Does the IS throw off heat comparable to a steel stove or soapstone stove?
    Chaz and burndatwood like this.
