Production Woodstock IS
  1. CoachSchaller
    CoachSchaller
    Southeast Michigan
    About three years or so....
  2. CoachSchaller
    CoachSchaller
    Southeast Michigan
    My Cat was not working correctly... Wife had to keep the air going quite strong to keep wood burning. It did ok when the bypass was open, but sluggish when the cat was engaged. I got to thinking, "I bet that cat is plugged" Let it cool a bit last night and sure enough it was plugged with white ash. So I put the back-up it and it worked quite well. !!!!
  3. LordOfTheFlies
    LordOfTheFlies
    NY
    What length splits are you guys using in the IS stove? I know the specs list 22" as the max....
    When I buck my own rounds I do 16" but when tree guys give me wood it's all over the place.
    chance04 and brenndatomu like this.
  4. BDF
    BDF
    The most I have ever gotten out of a combustor has been two years. Of course the combustor(s) was not outright failed at that point but it was sluggish enough that I had trouble keeping it lit and still having the stove produce enough heat overnight. The harder a cat. stove is used, the longer the cat. will be useful. Of course the big advantage to a cat. stove, at least IMO, is that they can be used running low and slow while still burning very clean and efficiently; if someone pushes a stove fairly hard all the time, honestly I think a non- cat. would serve as well and be less expensive to use as there would be no cat. to have to replace in the first place.
    brenndatomu and Slocum like this.
  5. BDF
    BDF
    Great! You could do a little write- up on the changes if you want to kill some time and inform the rest of us unwashed masses (who do not yet have a newer type IS stove). :thumbs: Mebbe even a photo or two of the changed parts?
    brenndatomu, Highbeam and Slocum like this.
  6. Canadian border VT
    I like 16 load stove front to back.. then 2 larger pieces across front by glass stoves full.
  7. Canadian border VT
    BDF stove came back all new gaskets, sled basically everything except cat redone looked like new 63F44F52-0389-47DD-B766-60D9C38FC711.jpeg
    mine was hooked up and running in 2 hours so I forgot pics!! chance04 might have better ones he sent his ash pan they cleaned that too!!
    it Woodstock expect the best you won’t be disappointed
  8. Slocum
    Slocum
    North Central Indiana
    I like 16” loaded north south. You can still load longer splits east west but I think north south flames up faster on coals.
  9. chance04
    chance04
    Denton Md
    PXL_20201128_203603075.jpg PXL_20201128_203609624.jpg PXL_20201128_203647622.jpg PXL_20201128_203656721.jpg PXL_20201128_203757744.jpg PXL_20201128_203811366.jpg
  10. chance04
    chance04
    Denton Md
  11. Oldhippie
    Oldhippie
    Ashby Ma
    So they just put a whole new faceplate right over the previous one. The weld it on? and then weld new door hinges on the new plate?
    Wow! That is awesome! No doubt, Woodstock is a class act from start to finish from top to bottom. I've only known 3 comppanies in my entire life so dedicated to customer satisfaction.
  12. Canadian border VT
    Yes that’s what I would ascertain weld grind paint gasket.. Class act
  13. Canadian border VT
    me Too
  14. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Regretting not getting mine sent in sooner. Oh well, it shall get done next spring. Stoves are looking fantastic!
    Slocum, chance04 and brenndatomu like this.
  15. chance04
    chance04
    Denton Md
    They also installed a new "updated" sled and installed a new sled gasket.
    Mine was showing some age and I certainly wasn't looking forward to replacing that. Now I won't have to, at least a few more years!
  16. VTWoodchuck
    VTWoodchuck
    I did get my new IS installed over the weekend, with four of us and the dolly it wasn't bad at all.
    I did remember to snap some pictures of it as I was putting it back together. Pictures of the inside of the firebox, upper right and left corners with shielding. Secondary plate. Top down view with top and sled removed. Top of fire box with sled ramps. Top and bottom of sled. Bottom of the cat heat shield. And the first curing fire. installing in place.png firebox.png upper right shielding.png upper left shielding.png secondary plate.png top down sled removed.png top of fire box sled ramps.png top side of sled.png bottom side of sled.png bottom of cat heat shield.png first fire.png
    I've had it going (and the furnace off) ever since, and so far I'm impressed (especially in comparison to the old stove). After small fires Saturday and Sunday to cure the paint I loaded it to the top with mixed splits Sunday night at ~8, brought it up to temp, closed the bypass and damped it right down to the second notch. Let it sit and cruise (with the windows open upstairs at times, outside temps were up there) and went 24 hours with coals enough to light it right back off Tuesday night with no issues.
    I'm sure things will change when temps drop and I have to start pushing the stove a little to keep up, but if I can normally load at night when I get home from work, and again in the morning before I leave again, with out my wife having to deal with it much or having to light a cold stove when she gets home from work (3-4 hours before me, normally) It will be a vast improvement over the old stove and I don't think Ill have much of anything to complain about!
    Slocum, chance04, Highbeam and 3 others like this.
  17. Rich L
    Rich L
    Eastern Mass.
    Beautiful pictures and good to be up a running just before the real cold sets in.Hey is that dolly one of those Escelera stair climbers ?
  18. Canadian border VT
    VTWoodchuck 12 hours is no problem with that stove.. Half my family is in Bridgewater so your wife will be warm
    brenndatomu and VTWoodchuck like this.
  19. Warner
    Warner
    If you don’t mind me asking how many sq.ft are you heating?
    brenndatomu likes this.
  20. VTWoodchuck
    VTWoodchuck
    It was the stove guy's dolly, but I believe it was. I thought it was slick the way the winch was set up to lift/lower the forks of the dolly. we were able to use it to lift the stove out of the back of my pickup and wheel it straight inside... way easier than most of the schemes that I had envisioned.
    Rich L and brenndatomu like this.
