"Preppers"? are you one?
Discussion in 'Everything Else (off topic)' started by Beetle-Kill, May 20, 2015.
  1. FarmerJ
    FarmerJ
    Minnesota
    We live on a main rail line and a major US highway. Like half a block away.
    so a hazardous material accident like what happened in Ohio is truly a likely event.
    We also live 30 miles downwind from a nuclear power plant. Something I don’t think a lot of folks take into consideration.
    NRC Emergency Preparedness Maps
  2. In the Pines
    In the Pines
    Ditto, keep the truck tank full of fuel as well so there isn't much ducking around to scoot.
  3. NH mountain man
    NH mountain man
    WMNF N.H.
    My well pump casing got hit by lightning July 3rd evening, and I wasn't going to call anyone over the holiday. We have stored water so we were fine, on the 5th I called a local well company , I had a new pump installed by noontime. The well guy said he 8 had more lightning strike pump calls that day and he usually gets 1 or 2 a year.
  4. In the Pines
    In the Pines
    As I prep my camper for this weekend I thought back to this post and keeping water in the fresh tank.
    If anyone else does this, just remember to keep it fresh, fresh water tanks are not sealed. So they will need bleach/your chem choice to keep bacteria down,
    It's recommended to drain and refill every 2 weeks to a month. Dosing it with bleach can extend that duration. (sanitizing once to twice a year)
    I have a 3 stage filter setup for when I'm not filling at home and generally just use the tank for flushing toilet and washing stuff.
    my filter isn't meant to clean pond water, just clean up the "clean" water. I have other means to deal with pond water.
  5. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Composting toilets or an outhouse would be an add.
    Berkey water filters are the best. I bought their filters but built my own system out of food grade buckets. Its gravity fed, and holds 5G untreated, and 5G treated on the bottom.
  6. wildwest
  7. Highbeam
    Highbeam
    The RV tank is not sealed but neither are any city water tanks. It's okay so long as you can keep the chlorine residual up. We swap the RV tank out at least twice per year. Of the gallon per person per day that they say you need that also includes non drinking uses. Most of my drinking is coffee so boiled. My sealed water barrels are also chlorinated and replaced yearly.
    And of course, at home, we're on a well which is unchlorinated and vented so we'll use that first as long as we can power it.
    Last resort is my sawyer filters that are rated for 100,000 gallons each and will remove anything I'm likely to come in contact with from the local creeks.
    Softwood and LCBug like this.
  8. wildwest
    found an army file drawer that was buried in the garage, (one like the bottom right), what do you guys think for a faraday cage?
  9. wildwest
    drawer door has gaps all around
  10. wildwest
    I also have a Plano case like this but smaller, going to think on it instead of the army file box.
  11. wildwest
    Major glitch in my prepping plan regarding water storage. We'll be spending winters in town after next winter, water needs to be here and will freeze in the winter since we won't be burning wood and pellet stove. Likely freeze solid and likely bust the water drums and 5 gal bottles. Moving water from winter home to here for bug out is a bad idea. Any way to keep water from freezing and still be drinkable? (no city water or well here so not easily refillable unless we have the fuel to go get to/from the water plant at 400 gal per trip.
  12. Well Seasoned
    Frost free hand pump?
    Water Without Electricity – The Frost-Free Bison Hand Pump
    https://www.lehmans.com/category/shallow-well-pumps
    EODMSgt, wildwest and NH mountain man like this.
  13. Canadian border VT
  14. Eric Wanderweg
    What about a root cellar type structure for storage?
  15. yooperdave
    Sounds like a more costly situation to achieve. A few ideas:
    1. Keep place heated in order to prevent freezing. And hope electricity isn't interrupted.
    2. Drain all water lines and leave only cistern container (only one?) with water in. Buy a circulating pump which will turn on by temperature and circulate the water in the cistern.........moving water doesn't freeze. And hope the electricity isn't interrupted.
    3. Drain all water lines and heat only the cistern container to an above freezing temp. Some sort of insulated box and cover (maybe something like an outdoor hot tub?) would be required to help maintain the water's temps so the heater wouldn't have to be heating all the time. I'll bet WWW already knows someone that uses closed cell spray foam. And hope the electricity isn't interrupted.
    4. Speak with a water well company and ask them for ideas? Probably a lot more experience regarding this than a wood burning forum...:salute: And you'll probably still have to hope the electricity isn't interrupted!
  16. FarmerJ
    FarmerJ
    Minnesota
    A root cellar may be your best bet with the lines planned to be self draining when not used.
  17. Canadian border VT
  18. Warner
    Warner
    Thanks!
  19. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Maybe keep some there, let it freeze? Don't over fill containers.
    If yall show up there, and bring a bit of water for a day or two, the rest should thaw when wood stove is fired up?
    Stay up there for the winter?
    Water softeners add salt to water. Run stored water through a softener?
    Solar powered heating element run into the tank/cistern?
    No well? Even a shallow well could provide water. I'd use a Berkey or the like for "surface water". If it is tested water, perhaps unfiltered it would be ok for cooking and cleaning.
    LCBug and wildwest like this.
  20. RCBS
    RCBS
    Over here
    All firewooders are Preppers by default. The mentality spills over.
