Power surge!!!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Liam66, May 5, 2016.
  1. imacman
    imacman
    Denver, NC
    CleanFire, wildwest, jtakeman and 2 others like this.
  2. imacman
    imacman
    Denver, NC
  3. imacman
    imacman
    Denver, NC
  4. will711
    will711
    Pocono Mts.
    That's the one I got on my p43 :thumbs:
  5. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    One of the biggest Eff ups at the factory level is that the fuses they install in these boards will NOT protect the board from much.
    The fuse should go poof long before the board turns into a fuse itself.
    Even if a draft fan motor on some units shorts out the board will fry and not take out the fuse.
    Very poor thinking
    A simple overload breaker on the incoming side of the board would stop most issues.
    Now if the lightning itself comes a haulin on in, ahhhh, all bets are off.
  6. wildwest
  7. basod
    basod
    Mount Cheaha AL
    I admire the DIY attitude Liam66 . Welcome aboard:thumbs:
    Should be a standard 220V MOV. Little alcohol to clean up the tracking - that transformer is fine most likely, but you can ohm it out.
    Just a heads up for those of you with high dollar surge protectors, this very same part, a Metal Oxide Varistor (MOV), is what fails when your surge protector takes a hit;)
  8. basod
    basod
    Mount Cheaha AL
    No it's not.
    Your ground runs above the hot feeder, which should catch fingers of a lightening strike.
    All design standards are off when it hits a pole/line that's why MOV's are designed to drop surge voltages to ground.
    Think of an MOV like a pressure relief valve, but instantaneous - when it sees excess it dumps to ground...when it sees surge voltage it explodes
    Russell, CleanFire and bogieb like this.
