power out in 2 rooms but breaker not tripped.
Discussion in 'The DIY Room' started by BCB, Mar 28, 2015.
  1. basod
    basod
    Mount Cheaha AL
    you can play lightsabers with fluorescent bulbs in 500kv yards.
    Eric VW, wildwest and Stinny like this.
  2. Gasifier
    Phew. I thought you might of had a "wired" little friend living in your house. :eek:
    papadave, eatonpcat and Eric VW like this.
  3. jetjr
    jetjr
    Pa/Md line
    I've heard that. I thought about going ito transmission when i started here, but kind of glad i went the route i did. Good catch on the no load switch.
    Stinny likes this.
  4. basod
    basod
    Mount Cheaha AL
    It's been on the net since early 2000's
    You can see it's only one phase - one of the breakers on the ring bus had a bad(stuck contact)
    Stinny likes this.
  5. Stinny
    Only thing I noticed basod were the guys on the ground backing up... :hair::D
    basod likes this.
  6. basod
    basod
    Mount Cheaha AL
    I have to hand crank them open - you're not supposed to look up(potential flash burn) - but as soon as you hear the bacon frying you crank as fast as you can.
    There is a piece of grating grounded to the switch metal that you stand on so if things fail to ground you're at the same potential as the switch = no current flow.
    I had some backup opening the stuck one last week, with smartphone videos running - someday I'll be on Youtube
    Stinny likes this.
  7. Stinny
    :rofl: :lol::rofl: :lol::rofl: :lol: ... "but as soon as you hear the bacon frying you crank as fast as you can." ... :dex::rofl: :lol::rofl: :lol:... I'm sorry Basod, but you guys are crazy as chithouse rats... :loco: :crazy: ... Jeeeeeezz that's funny... :D
    basod likes this.
  8. jetjr
    jetjr
    Pa/Md line
    Yea I've seen it before. Never paid that much attention to it. Like I said the highest we work is 34. Even those switches when they fail can be impressive. Did they teach you guys not to inhale if you do look up?
    basod and Stinny like this.
  9. Stinny
    o_O
  10. jetjr
    jetjr
    Pa/Md line
    My understanding of it is if a flash occurs and you breath in you can burn your insides, lungs, esophagus, trachea and such.
    Stinny likes this.
  11. Stinny
    The kind of juice you guys deal with is spooky. There'd be no problem with me breathing in around that kind of stuff... cause I wouldn't be able to breathe anyway... :zip:
    basod and papadave like this.
  12. wildwest
    Can someone share where I can see this?
    Stinny likes this.
  13. Stinny
    wildwest likes this.
  14. basod
    basod
    Mount Cheaha AL
    Ozone & superheated metal vapors as well. For switching disconnects 115kV & 230kV, grounding etc, have to wear 10cal coveralls, hardhat w/arc face shield.
    You don't look up just because of the burn potential - think welders retina burn
    I have 100cal/cm suits for the actual dangerous stuff - racking breakers in/out of 4160V buses
    The arc flash potential on the secondary of a 230kv to 4160V transformer is crazy high - have a remote racking device so I can stay 25ft away.... never gave a second thought to racking them in/out in my younger years kneeling directly in front of them:eek:
    Stinny and wildwest like this.
  15. Stinny
    o_O
    wildwest and basod like this.
  16. basod
    basod
    Mount Cheaha AL
    It really isn't all that bad Stinny. Get into distribution voltages 480V 3ph where relays are limited at best and you get the below
  17. Stinny
    Well... that was fun. BzzzzzzzzzzzzAPPPPP... as I've said before, seems all you guys who play with fire don't seem to sweat much... :smoke::D
    basod and wildwest like this.
  18. basod
    basod
    Mount Cheaha AL
    I glisten:rofl: :lol:
    Stinny likes this.
  19. Stinny
    And, maybe a little smoke too... :whistle:
    basod likes this.
  20. Sam
    Sam
    Southern Minnesota
    The way I understand parallel wiring is that you're not supposed to use the outlet to pass the current to the next device. I thought you're supposed to pigtail all three (common, ground, and hot) in the box, to the input, output, and pigtail wires that go to the outlet itself. I think I was either told that or read it in a wiring book. Reason being is that half the outlet can go bad and cause this exact issue. Had it happen in my basement this past winter as well; the PO had used the push-in connections on the outlet for all the commons and hot wires and put both grounds to the same screw. I went ahead and replaced the outlet because it had burned the tab between the two sides on the hot side of the outlet.
