Poulan Pro 260 build
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Dec 31, 2023.
  1. Eggshooterist
    Eggshooterist
    Erff
    This is the finished piston and lower transfer grinding. Farthest I've taken a clammy. Guess we will find out what becomes of it.
    IMG_20240103_140513102~2.jpg IMG_20240103_140519866~2.jpg IMG_20240103_140523967~2.jpg IMG_20240103_140537314~2.jpg IMG_20240103_140805586~2.jpg IMG_20240103_140758308~2.jpg
  2. Eggshooterist
    Eggshooterist
    Erff
    Onto exhaust next. Its 20 mm wide. Im taking it to 26-27mm. 41mm bore x .65 is 26.65mm.
    Sawdust Man, MAF143 and Ohio like this.
  3. Eggshooterist
    Eggshooterist
    Erff
    Exhaust roughed in. Little bit more touch up then polishing. It's pretty much the shape and size its going to stay.
  4. Eggshooterist
    Eggshooterist
    Erff
    Progress...
    Finished exhaust after polishing. I see the symmetry is off a tad on the right side compared to the left. To late now. OCD...
    IMG_20240104_131822782~2.jpg IMG_20240104_131818525~2.jpg IMG_20240104_131810744~2.jpg IMG_20240104_131800535~2.jpg IMG_20240104_141359923~2.jpg
    Ohio, eatonpcat, Sawdust Man and 3 others like this.
  5. Eggshooterist
    Eggshooterist
    Erff
    Intake...
    Lowered from 66° BTDC to 75° BTDC. Widened a smidge. Matched the carb mount to the port.
    IMG_20240104_142900995~2.jpg IMG_20240104_131830583~2.jpg IMG_20240104_142849682~2.jpg
  6. Eggshooterist
    Eggshooterist
    Erff
    Silver removed off muffler and black installed. Matched the exhaust port and muffler. Forgot to take pictures.
    That's all for today.
    IMG_20240104_141833254~2.jpg IMG_20240104_141759329~2.jpg IMG_20240104_141837020~2.jpg
  7. Chud
    Chud
    NC
    Ah yeah that black can sets it off
    eatonpcat and Eggshooterist like this.
  8. Carbine
    Carbine
    Looks darn good from here! Following, bet you'll see big gains!
    brenndatomu and Eggshooterist like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Thanks bud. Hopefully it will liven it up. I've yet to have one have less power out of 9-10 different saws but I'm sure a real builder would have far exceeded my gains. I'm just board and experimenting. Lol. I did a green version of this 260 with a different 260 top end I swapped onto it. I wet to far and free ported it. It had more power than stock but it ran erratic.
    Ultimately, I'd like to get into porting large scale RC car engines. I know way more locals that would be interested in that type of thing.
    Carbine, eatonpcat and brenndatomu like this.
  10. Eggshooterist
    Eggshooterist
    Erff
    Sorry I haven't been posting here. Its in the teens and my garage isn't heated so I'm hibernating. Lol. It get back up in the high 20's or warmer I'll get back at it.
  11. Eggshooterist
    Eggshooterist
    Erff
    I have an update. Buttoned up the saw yesterday, went to fire it up and fuel started pouring out of the carburetor after using the purge bulb. I put a new diaphragm kit in the carb before rebuilding / porting it. I might need to put a new needle in it or adjust the lever.
    Buttermilk, eatonpcat and brenndatomu like this.
  12. brenndatomu
    I've had that happen randomly on diaphragm carbs...usually can pull it apart, blow everything off, reassemble, and its fine.
  13. Eggshooterist
    Eggshooterist
    Erff
    I'll be on that today. Something is either stuck in it that didn't come out when I cleaned it or the tip is messed up on the needle. This carb is a pain to remove too. 5 pounds of $#@& in a 2# sack. Lol
    MAF143, Buttermilk, JimBear and 2 others like this.
  14. Eggshooterist
    Eggshooterist
    Erff
    Well I got the pos running. Stiffest throttle I've seen in a saw. It will probably give ya Popeye arm if used regularly. :rofl: :lol:
    https://photos.app.goo.gl/q3GNFbtqWkytDHsX9
    There's a reason there's no chain on it in the vid. I was only using the bar to space the clutch cover correctly so I could use the break to ensure the clutch is tight. No sense in slinging out oil everywhere just yet.
    MAF143, Buttermilk, huskihl and 5 others like this.
  15. Eggshooterist
    Eggshooterist
    Erff
    I still need to put a chain tensioner in it. It's missing the clip that holds the adjuster bolt in the cover.
    MAF143, Buttermilk and eatonpcat like this.
  16. brenndatomu
    Doesn't sound like its crazy loud?
    MAF143 and Eggshooterist like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    It's not. Two stingers approximately 3/8" id.
    MAF143 and brenndatomu like this.
  18. Skier76
    Skier76
    CT and SoVT
    That sticker!
  19. Eggshooterist
    Eggshooterist
    Erff
    Lol. Thanks to John Wargo. 41FanForLife
  20. Ohio
    Not Ohio
    We need T shirts. Come to think of it ball caps as well. Thanks.
    Signed,
    The World
