Poll: How do you use your Hydraulic Log Splitter (H or V)?
Discussion in 'Chainsaws and Power Equipment' started by Machria, Oct 21, 2014.
Poll closed Nov 4, 2014.
  1. Horizontal ONLY!
    28.2%
  2. Vertical ONLY!
    12.7%
  3. Mostly Horizontal, except for the big'uns I can't lift!
    40.8%
  4. Mostly Vertical, with a few exceptions (bunch of small stuff... )!
    8.5%
  5. 50/50, I go both ways (pun intended)!
    9.9%
  1. clemsonfor
    Those splitting v article that complain about bending are you trying g to stand and split while bent over?
    Do like I do and pile a dozen or two rounds on one side. Then sit on one and grab them and split them while seated. I too am 6'2" and it works as best it can while your doing manual labor. I am not that strong bit can still manage to grab and move rounds up to about 20"s in a seated or just a bit off the seat and then set n place and split them while pulsing the splits on the other side. What would be nice is an auto return for the ram that stood at a predetermined position...not all the way up. Also my buddies splitter that I use the auto return feature is worn out so you have to manually return the ram.
    No way I could stand and split vertically either. I can't hardly stand for horizontal, the splitter needs to be 10-12"s taller to be able to stand up.
    Gasifier and UncleJoe like this.
  2. Gasifier
    I hear that clemsonfor . I also will get rounds close and get down on one knee and split a bunch in that position. That way my back stays straight for a while. I try to change up positions to keep from getting too sore. I will also try to do two or three different things to change up muscles I am working. Cutting, splitting, stacking, farting, I mean mowing grass, weed eating, tree trimming, brush hogging......
    Stinny likes this.
  3. clemsonfor
    And nothing says you have to so split for 4 hours straight or even 2.
    Split some. Go inside sit on couch for 15 mins. Go back n split for 30 mind s to an hour then cut grass then split etc.
    Stinny likes this.
  4. Gasifier
    You have 30 minds helping you with your splitting problems?
    Chvymn99, DexterDay and cnice_37 like this.
  5. Stinny
    "Cutting, splitting, stacking, farting, I mean mowing grass, weed eating, tree trimming, brush hogging......" ... I saw that... thought you could slip that out didn't cha? :D
    clemsonfor likes this.
  6. Gasifier
    :rofl: :lol:"Slip that one out.":rofl: :lol:
    Stinny likes this.
  7. cutforfun
    cutforfun
    Kevin is right about getting the splitter up in the air, my beam sits 30" of the ground and the handle is at "48. I put my hands down standing straight up and touch the beam with my finger tips. That's how I decided how high to build it. I can split for hours at a time and to this point the only strain has been on my left shoulder from pulling the handle so many times.
    Stinny likes this.
  8. Oliver1655
    Oliver1655
    Central Missouri
    If you have a H/V splitter, you can use car ramps for the tires & a block of wood under the tongue to raise it up.
    Another option is to determine how much higher you want the beam in horizontal position then weld extensions to the beam, not the axle, which will raise it up that amount. When you position it vertically it will still rest on the ground but will be further from the axle by what you raised it - which should be a plus. You may have to extend hoses depending on how it is designed.
    Chvymn99 likes this.
  9. Oliver1655
    Oliver1655
    Central Missouri
    I have a dedicated horizontal splitter with a tall wedge 4-way wedge (20") with sharp edges, log lift, & out feed tables. Has 4" cylinder with the pressure release set at 2,500 psi, 15,7 tons.
    For the type of wood I split, elm, hedge, oak, ... it works great.
    Fill up the log lift then start the splitter. Save fuel.
    On the right is my log bucking trailer. After cutting the logs, the rounds fall towards the splitter side & I can just roll the larger rounds directly onto the log lift.
  10. Gasifier
    Oliver1655. That is a really nice set up.
    Oliver1655 likes this.
  11. cutforfun
    cutforfun
    New wedge works great for the fir I cut, few picks of the wood that have drug home over the last few weeks :p
  12. Gasifier
    Wow cutforfun. o_OThat looks like you had some fun there!:dex:
  13. pappy88
    pappy88
    Missouri
    I'm all about horizontal. log splitter 014 (Medium).jpg log splitter 014 (Medium).jpg Picture 165 (Medium).jpg Picture 196 (Medium).jpg Picture 360 (Medium).jpg
    Deacon, Tiewire, cnice_37 and 7 others like this.
  14. DexterDay
    DexterDay Administrator
    Northeast Oh
  15. Gasifier
    What the ? pappy88 Are you in the business of processing firewood?
  16. HDRock
  17. pappy88
    pappy88
    Missouri
    Actually I only burn about 4 cord yr. I build these in my shop, spare time.
    Chvymn99, HDRock, clemsonfor and 2 others like this.
  18. pappy88
    pappy88
    Missouri
    Yes they are HDRock, & I wish I still owned 1 of them. I took a little speeco in on trade for the yellow one & thats what I'm stuck with at the moment.:confused:
    HDRock likes this.
  19. clemsonfor
    I hope they put cash with it!!!
  20. Machria
    Machria
    Long Island, NY
    o_O WHAT??? You kidding me?? Ok, I'll go get a brand spanking new Speeco tomorrow, and trade it for one of those with you!!! :D
    And in those first 2 pictures, are you splitting hay???
