Poles set for the new shed
Discussion in 'The Wood Pile' started by Smokinpiney, Mar 31, 2014.
  1. papadave
    Wow, nothing like a premade roof.
    Super cool.
    Mitch Newton and Stinny like this.
  2. StickBender
    StickBender
    Go with metal and don't look back, it goes on so quick.
  3. Stinny
    Pete's gonna love that roof too…
    And snow comes off so quick… ;)
    Pallet Pete, papadave and StickBender like this.
  4. StickBender
    StickBender
    Sure does! And doesn't need much pitch.......
    Stinny likes this.
  5. papadave
    Yep, I think if I hadn't had leftover shingles from the house reroof, I'd have done steel.
    Stinny likes this.
  6. Gasifier
    Awesome Piney! When I found this thread I was on my I-Phone and I had to switch to the laptop so I could see those awesome pictures. Very nice! Those are some serious poles and the pallets are great as well. Where did you get the poles?
    Chvymn99 and Stinny like this.
  7. savemoney
    If you go with a metal roof, that should last for as long as you might have a use for it! Best part is the snow moves off it with ease, and it won't curl up in the summers sun.
    Stinny likes this.
  8. Smokinpiney
    Smokinpiney
    "South" Jersey
    Thanks guys! Once we got the poles set, it came together alot quicker than i thought. I used 3 of those same skids for the floor (2 long ways and 1 cut in half). Had to do some fine tuning with the saw to make them fit as tight as possible. Someone didn't set the poles exactly square :whistle: . I finished the floor after dark tonight so no pics until tomorrow.
    Gas, A few years ago the power company was setting new poles in front of my uncles house. He asked if he could have some of the old poles, that were in good shape still, and they dropped 8 of em at his place. I got all four of those poles for the shed from two full length poles. They were 28ft long and i cut 4ft off the largest end of each pole, then cut two 12footers from each.
    Gasifier, savemoney, Chvymn99 and 2 others like this.
  9. weatherguy
    weatherguy
    central massachusetts
    I just picked up 5 ten foot pallets in great shape for free, now you got the hamster spinning his wheel in my head. What height are the front poles from the ground and the back? I could make a 10 x 12 with the ones I have.
  10. Stinny
    I see a new woodshed hapnin… :fire:
  11. Smokinpiney
    Smokinpiney
    "South" Jersey
    The front poles are roughly 96" to the top and the back is around 86". I can get exact measurements later if ya need em.
    Stinny likes this.
  12. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Great shed, great sub-roof, and it really came together quickly. :thumbs:
    Stinny likes this.
  13. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Nice and stout. I like it.
  14. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Very very cool! Funny you just did what I wanted to do only better.
    Stinny likes this.
  15. papadave
    My suggestion for anyone putting up a shed is to extend the low side roof overhang quite a bit to avoid splashback on the wood or siding when it rains and the snow melts.
    swags, Chvymn99 and greendohn like this.
  16. Pallet Pete
    Ovid
    Actually you just gave me an awesome Idea! Close in one side just big enough for my splitter and yard tools with a door into the covered area!
  17. savemoney
    I like the way you work. You used repurposed polls, culled lumber. Tossed out pallets and gave it all function. That is the kind of thinking person I would like to see representing us wether it be local, state or nationally. Good very practical thinking, and you followed through with your intentions.
  18. weatherguy
    weatherguy
    Close enough, thanks. I think if I do one I'lll use metal over the pallets.
  19. greendohn
    greendohn
    S.E. Indiana/Rush County
    ^^YEP, what he said^^^I installed my metal roof with 16" or 18" overhang in the front, 4" off both ends and 6" or 8" off the back,,the back overhang could stand to be longer. The more overhang the better. My shed has been a work in progress as money allows. I currently use a tarp I scored from the co-op(they use this stuff to cover the ground bins of corn) on the walls which has worked great. I roll the sides up in summer and down in the winter. I recently discovered "perforated" barn metal which I will use on the walls,,eventually.
    The pallets for the roof are a great idea. Whooda' thunk it!!
  20. nate
    nate Banned
    Palmer, AK
    Instead of a long overhang, putting a gutter would work.
    swags and Mitch Newton like this.
