Plumbing advice
Discussion in 'The DIY Room' started by Pallet Pete, Mar 4, 2017.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    IMG_1150.JPG Lights are done and now I have found more issues to fix in that half grrr..
    On the BRIGHT side I have a bulb with a Bluetooth speaker built into it installed:D
    Now to finish pulling all the wires hanging down and properly hang them. Some pretty bad stuff in that half of my basement.. fun times ahead:confused: and yes the drain pipe is holding up the duct work....:headbang:
    papadave, Thor, NortheastAl and 3 others like this.
  2. TurboDiesel
    :confused:
    A wha?!? o_O
    Pallet Pete and NortheastAl like this.
  3. Eric VW
    That's niiiice.....:eek:
    :doh:
    papadave, Thor, Pallet Pete and 2 others like this.
  4. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    I nominate TurboDiesel as our official FHC Plumbing "go to guy". Dude, I can tell you know your stuff.
    Eric VW, papadave, Thor and 2 others like this.
  5. Babaganoosh
    Babaganoosh
    Jersey Shore
    I'll take that yard roller....
    Eric VW, Thor, Gary_602z and 3 others like this.
  6. Pallet Pete
    Ovid
    It's um shall we say assimilated! Lol
  7. TurboDiesel
    Maybe I could trade that yard roller for plumbing advice...:rofl: :lol::rofl: :lol::rofl: :lol:
    Eric VW, Thor and Pallet Pete like this.
  8. Pallet Pete
    Ovid
    You c
    ome get it and I'll consider :rofl: :lol:
    Eric VW, Thor and TurboDiesel like this.
  9. Pallet Pete
    Ovid
    I have decided sir no manifolds. :D
    Eric VW, papadave, Thor and 1 other person like this.
  10. TurboDiesel
    Thank you , sir!
    But i should stick to commercial pipe fitting.
    Its way more fun
    Like this
    And this
    Chvymn99, Eric VW, papadave and 5 others like this.
  11. brenndatomu
    1/2" from the hot water tank to the fixtures is a great idea...warms things up pretty quick...no loss of flow or pressure with modern low flow fixtures
  12. Pallet Pete
    Ovid
    That looks about like some of the farms we service! What are the peristaltic pumps used for in this picture? We use them on chemicals most of the time.
  13. TurboDiesel
    Sodium Hypochlorite.
    We are replacing chlorine gas systems in water plants. A lot safer to handle and DHS thinks that terrorists will steal the 1 ton gas cylinders and use them for dirty bombs.
    Chvymn99, Eric VW, Thor and 1 other person like this.
  14. TurboDiesel
    What chemicals are the farmers using?
    Sanitizers ?
    Eric VW and Pallet Pete like this.
  15. MightyWhitey
    MightyWhitey
  16. brenndatomu
    We just ditched the 1 ton cyl. for a bank of 150# cyls...a lot less paper work involved too. Depends on your feed rate if you can get away with 150's though.
    Nice to see the M series pump being used...we recently switched to a peristaltic pump for fluoride feed...found out pretty quick we were sold a "cheap" pump...should have used the M series.
    Eric VW and TurboDiesel like this.
  17. TurboDiesel
    HHHmmm?
    like a liquid malted barley and corn flakes converter?:bug:
    Eric VW and Thor like this.
  18. TurboDiesel
    Any talk of adding ammonia there?
    Probably the next big thing. At least in the bigger plants. Say, 6-8 MGD and up.
    Your probably around 2-4 MGD if your using the 150# tanks?
    Eric VW likes this.
  19. Pallet Pete
    Ovid
    We sell Chlorine, various acids, sanitizers, detergents, laundry detergents, hoof bath and more. We install them All over the place in farms.
  20. brenndatomu
    Not that I've heard...we are 4 MGD capable but rarely see over 3...2 is a "normal" day
