Plugged chimney cap
Discussion in 'Modern EPA Stoves and Fireplaces' started by bushpilot, Nov 26, 2016.
  1. bushpilot
    bushpilot
    Eastern Washington
    I exppect to have one in the not so distant future.
    Eric VW and saskwoodburner like this.
  2. bushpilot
    bushpilot
    Eastern Washington
    I had to clean the cap again today. The chimney was very clean, though I brushed it while on the snow-covered roof.
    The wood is dry, seasoned 2+ years (douglas fir, pine, aspen), the Codar STT and Condar flue thermometer confirm I am burning hot enough, there is no smoke, I have quit very low overnight burns, and use no paper to light.
    I have no explanation, but I am now running screenless. I will look at putting a coarser screen when burning season ends.
    milleo, Eric VW, yooperdave and 2 others like this.
  3. fox9988
    fox9988
    NW Arkansas 72717
    The screen will be cold. Regardless of flue temp. Enlarge or delete.
    Chvymn99, brenndatomu, milleo and 2 others like this.
  4. thewoodlands
    thewoodlands
    We had a problem almost two years ago in the fall, we had it taken off for good. I clean the chimney from the bottom up so that could've helped it plug but the guy who took it off said they all plug sooner or later unless you clean the screen.
    milleo, Eric VW and bushpilot like this.
  5. bushpilot
    bushpilot
    Eastern Washington
    Installed the Condar flue probe.
    nobody, saskwoodburner and Thor like this.
  6. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Right there with ya, but you knew that. After I removed my screen on the 26th, I've seen a dramatic improvement In draft. Also double checking my wood and found some I thought to be ready was still close to 30%. Now I've got temp gauges and my own mm, so no excuses for not checking often until I have this figured out.
    Keep learning. The warmth is worth it!
    Chvymn99, nobody, milleo and 2 others like this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    You might want to experiment some more with over night burns; mine are getting better but I am making sure the stove and flue are fairly hot before shutting the damper down. I am not stuffing the stove; idea is to have some overnight heat and coals to help start the morning fire.
  8. Eric VW
    Sounds like you're getting on the up & up now Kimmie......:fire:
    Chvymn99, milleo and Kimberly like this.
  9. bushpilot
    bushpilot
    Eastern Washington
    Good to hear that your's are going better. :thumbs:
    I have been doing some "mild" overnight burns, not stuffed to the gills and not shutting down as much. Last night I went to bed with a mid-range STT and 4 splits on a bed of coals. This morning the house was at 67 and outside was 17, and there were coals for the relight, so that was quite fine. (I only slept 6 hours though.) Burning lodgepole pine and douglas fir, not known for overnight burns.
    Tonight I am going to try to fine-tune it a little more using the new Condar flue thermometer. New toy, oops, I mean new tool!
    Chvymn99, Thor, milleo and 1 other person like this.
  10. yooperdave
  11. saskwoodburner
    saskwoodburner
    You're on your way now.:)
  12. bushpilot
    bushpilot
    Eastern Washington
    So far the flue temp and STT pretty much mirror each other, so I am not sure why having both is useful.
    yooperdave likes this.
  13. oldspark
    oldspark
    NW Iowa
    During the whole burn cycle?
    bushpilot likes this.
  14. Kimberly
    Kimberly
    The Kangaroo State
    Where do you have the thermometers placed? Is the STT in the place recommended by the manufacturer?
  15. Kimberly
    Kimberly
    The Kangaroo State
    Not sure I am doing it correctly or not but from a cool start I let a small fire burn hot and watch the flue thermometer; once the flue is up to temp; I will add more wood; larger pieces and then shut the door tight and let the normal air flow feed the fire. The STT won't be in the operating range at all. From what I understand, you need a hot chimney to help the stove draft.
  16. bushpilot
    bushpilot
    Eastern Washington
    The flue thermometer is 19 inches up from the stove top. The installation instructions said to install it "slightly more than 18 inches" above, which I found entertaining. But I did exactly what they said.
    The STT thermometer is mounted on the hottest part of the stove top. There are no stove manufacturer's recommendations for placement, not even a vague one like provided for your Madison.
    Pretty much. But I only have a couple of days with the flue thermometer, more observation to come. And I haven't done a sustained HOT burn yet with it, that will be on Tuesday, according to the weatherman. :D
    What would you normally expect me to see between the two?
    nobody likes this.
  17. bushpilot
    bushpilot
    Eastern Washington
    BTW, when I say they mirror esch other, I am not referring to specific numbers. The flue temps are obviously much higher than STT! But their scale movements pretty much match each other, as well as the "burn zone" indications (too cool, good burn, too hot).
    The flue temperature probably is a little quicker at responding.
  18. saskwoodburner
    saskwoodburner
    Maybe different stoves and different climate, but mine makes it a lot easier to figure out what's going on, and how to get the best "gas mileage" so to speak. My stove temp and flue probe are not linear to each other. My flue probe can be registering say 400 f on a cold start with the door cracked a hair, while the stove temp has only walked up to 150 f. Then I might close the door completely and throttle the air back 25 % The flue temp will now hold or creep slightly, but within the next few minutes the stove temp goes up.
    I'll cut the air again, and the stove temp keeps walking up, while the flue might stay, or doddle up as well. I'm not sure I'm getting my point across, but basically you don't need to rage the flue temp to 800 f and the stove temp to 500 f before cutting your air. This is how the probe helps, as you know what's going to happen before it happens.
    Kind of like progressive shifting with big trucks, where you shift as soon as the next gear can keep you moving forward and you get going quicker and save fuel. As opposed to winding the truck out in every gear (raging the fire and blowing heat up the chimney).
    oldspark and bushpilot like this.
  19. yooperdave
    Therein lies the trick!
  20. bushpilot
    bushpilot
    Eastern Washington
    Thanks, very helpful. I haven't done a cold start with the probe yet, so I have yet to see all its magic.
    saskwoodburner likes this.
