Plaster of Paris
Discussion in 'The DIY Room' started by Grizzly Adam, Nov 9, 2016.
  1. Grizzly Adam
    Grizzly Adam Guest
    This one is pretty heavy, but when I make a nice level one and get a uniform thickness I will have a better idea about weight.
    papadave and Jeffrey Svoboda like this.
  2. stuckinthemuck
    stuckinthemuck
    Are you going to give the back side some texture or grooves so the adhesive has more surface area to adhere to? That's what it looked like the ones online had. Looks good!!!
    papadave and raybonz like this.
  3. Grizzly Adam
    Grizzly Adam Guest
    I hadnt planned too, the person that did this before me didnt so I dont think it will be necessary.
  4. ironpony
    ironpony
    Mid Ohio
    hand held orbital sander works great for eliminating air bubbles, hold it against the bench and vibrate the whole thing.
  5. ironpony
    ironpony
    Mid Ohio
    Also after thinking about it, the mesh will only be beneficial after the tile cracks, it will hold it together think about cement. if the tile cracks you will probably discard it anyway. might save some work and money in the long run skipping that step.
  6. Grizzly Adam
    Grizzly Adam Guest
    Maybe my cordless jig or saber saw can do that for me. Without a blade, of course.
    milleo and Jeffrey Svoboda like this.
  7. ironpony
    ironpony
    Mid Ohio
    also why not just change the 2x4 frame to 1/2 x 4 and screed the thickness, might keep it more uniform than relying on volume.
    as far as mixing the plaster, find a plaster weight/water oz and duplicate it for each piece, consistency helps to much water=shrinkage cracking
    papadave likes this.
  8. ironpony
    ironpony
    Mid Ohio
    OH and that tile looks really good, 200 more to go :rofl: :lol:
  9. Grizzly Adam
    Grizzly Adam Guest
    I am going to put a 1" x on one side of each form to guage thickness. I had marks on the 2"xs but they came off when I added the Murphy's. I am also going to make it so two sides can be removed from the top with just a couple screws for removing the tile from the mold.
  10. ironpony
    ironpony
    Mid Ohio
    I am throwing out all the things i tried/ learned when I was making concrete caps for my retaining wall. once i figured out how much filled the mold i repeated that measurement and saved a lot of material.
  11. Grizzly Adam
    Grizzly Adam Guest
    Thats the plan. It took 10 tupperwares to do the last one, but it is too thick on one end, so maybe six-seven next time and weigh it. Same with the water, it will get weighed.
  12. raybonz
    raybonz Moderator
    Carver, Mass.
    A good dildo should work lol ;)
    Pyroholic likes this.
  13. Grizzly Adam
    Grizzly Adam Guest
    Can you send me one from your private reserve?
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    Will send camouflage collection lol
  15. Grizzly Adam
    Grizzly Adam Guest
    I now have a total of 4 molds ready to go. Going to fill as many as I have plaster for when the old lady gets home in about an hour.
    papadave, Jeffrey Svoboda and raybonz like this.
  16. raybonz
    raybonz Moderator
    Carver, Mass.
    How many do you need?
  17. Grizzly Adam
    Grizzly Adam Guest
    I am estimating 44 in the first room. We are doing the whole downstairs.
  18. raybonz
    raybonz Moderator
    Carver, Mass.
    You'll be getting plastered for a while.. These are going on the ceiling correct? How are you securing them to the ceiling?
  19. Grizzly Adam
    Grizzly Adam Guest
    Unicorn blood.
    Nah, I am hearing that plaster on the back will hold them, but I am in the believe it when I see it category. Maybe I will end up using construction adhesive, but either way I will likely be using a deadman or some cripples to hold them up. Seems like we should have better terms for those things...
  20. raybonz
    raybonz Moderator
    Carver, Mass.
    My concern would be the paint separating from the plaster which the tiles will be adhered to.. Bet one of those tiles would give a decent headache! I would avoid construction adhesive as it is impossible to remove from the ceiling and the tile.. Someone secured paneling in my old house with construction adhesive and it was a nightmare to remove.. Lots of fancy language ensued..
    papadave and milleo like this.
