Pines, Pines Galore
Discussion in 'The Wood Market' started by T.Jeff Veal, Mar 5, 2025.
  1. SimonHS
    SimonHS
    Yorkshire, England
    Can you negotiate with the manager or owner? They must know that you only bring long logs.
  2. T.Jeff Veal
    I tried, he was in a pizzy mood.
    I'll see what plays out
  3. brenndatomu
    What if you volunteered to take those logs away for them?
    Doesn't the scale master have any say so in sending guys packing when they bring obviously way too short stuff in?!
  4. T.Jeff Veal
    I was gonna offer to haul it off, but it was gone.
    The scale lady started inspecting the dump loads after that was brought in. I think it was on a dump truck where she couldn't see it.
    The regular loggers are crafty with hiding short logs in the middle of there loads.
    Zoom in on the right side of the picture, that was a log truck they unloaded, see the bigger short logs on top... 20250317_100618.jpg
  5. brenndatomu
    High mount camera would fix that.
  6. T.Jeff Veal
    It would help, but it's easy to hide stuff if you want too. Just be honest would be the ticket.
  7. stuckinthemuck
    stuckinthemuck
    That’s a lot of weight for that trailer. Looks like a 10,000lbs rated trailer with two 5200 lbs axles. I’m guessing that having the logs stick out of the back helps in the dumping process to counterbalance the weight in the front. What kind of hitch are using between the truck and the trailer?
  8. T.Jeff Veal
    It might be a bit overloaded...:whistle::whistle:...
    We had an 2" Anderson weight distribution hitch on it. Got a 2 1/2" receiver hitch on it now.
  9. T.Jeff Veal
    A tiny bit of good news...
    Found 2 local young men that have a sawmill and builds pallets for the local sand plant. They wanted logs. They came today and got a load.
    Gave us $50, all we did was load them. So it's a little something, about 1/2 what the chip mill was doing. But this helps them and we don't haul. They want all the trees we can give them, 8-10" and bigger. Even said if we have a pile and our schedules don't match, they would load with their skidsteer.
    I knew GOD had a plan, we just need to be patient.
  10. jrider
    jrider
    Time is money so if you don't have to take time going to the mill, your per hour rate may have increased depending on how long a trip takes. Having them load would be even better.
  11. T.Jeff Veal
    Another beautiful day in the piney woods...
    Our friends have to have a new septic drain field installed, so the order of the day was to clear that area. We also cut a few around the burn pile for more room for stumps and tops... 1000019000.jpg
    Part of the area we got cleared, cut stumps high for easier removal 1000019021.jpg
    We got 19 trees done, I give JESUS glory for guidance on saw and trees.
    Heading back today to finish the drain field area. Got a few we need to pull with cable.
  12. T.Jeff Veal
    Another good day in the piney woods.
    JESUS kept us safe again.
    We only took down 9 today, but 5 had to be rigged with strap, block and cable... Messenger_creation_0A2E1127-920E-4FA2-B618-6C4DA7FCEDB6.jpeg
    Had 3 in this area... Messenger_creation_FA737AB0-1802-4D3C-9B52-1F65C6D97658.jpeg 1000019120.jpg 1000019122.jpg
    Our friend, Mr Souter, o his "String Bean" as he named it, moving logs 1000019125.jpg
    We had 4 regular drops... Messenger_creation_323DA883-0DEC-4D62-919E-A6A2F5E0C3D9.jpeg
    Log piles from 28 trees...
    We started another pile of cull/smaller logs to haul to off-site dump. We carried 1 trailer load already. 20250426_164602.jpg
  13. T.Jeff Veal
    The 2 brothers that run the pallet mill came yesterday, we loaded the trailers for them...had more logs on those piles than I thought.
    1000019224.jpg Top right side log rolled off the first time and initiated the new L4802...:(:(
  14. Krackle_959
    Krackle_959
    Coastal Maine
    Nice work, thats quite the pile of logs, glad you found an outlet for them. As for the tractor it’s only the first dent/scratch that hurts the most. After that they are just beauty marks on a machine.
  15. T.Jeff Veal
    After taking a summer break, we started back at our friend's place taking down more trees. Monday was a good productive day, 26 trees, I think hit the ground. Those XS saws by huskihl really get the job done...used the XS400 and XS4910 20251124_142928.jpg
    Started laying them down and bucking to 12' and 8' saw logs 20251124_100646.jpg
    Used the tractor for insurance to keep all the trees in the clearing 20251124_140452.jpg
    Our friend used his JD to help move saw logs to the stack, small logs and limbs to the burn pile... 20251124_161454.jpg
    Hope we made quota for the day...:)... 20251124_172002.jpg
    Mill guys will pick them up Wednesday.
    We thank JESUS for a safe day.
  16. MikeInMa
    A fine day's effort! Well done.
  17. T.Jeff Veal
    Thank you, sir:handshake:
  18. T.Jeff Veal
    The brothers came Wednesday to pick up the logs...they have a flat bed and a dump trailer, we loaded it 1st, but didn't get a :ithappened:...:(...
    While they were hauling the logs to their mill, we decided to play with the saws a bit more... 20251126_095322.jpg
    Dropped a total of 8 trees Wednesday while waiting between trailers... 20251126_122206.jpg
    Miz Carol said there were 74 logs in the big pile before the 8 trees were added. Probably 90-95 logs were loaded Wednesday.
  19. T.Jeff Veal
    We got back to the pines Wednesday.
    They wanted to get the side yard done first. Had 10 trees in this area to cut. Area was shaped like a long triangle, with powerlines on two sides 20260311_091000.jpg
    Had a breeze blowing back towards the tractor and top heavy towards line and house, used Orange Crush to put pressure against it... 20260311_093704.jpg
    We got that group of 5 on the ground, time to buck into logs... 20260311_095226.jpg
    Our friends, Voyne and Claire, helped out a lot. He moved tops and limbs to the burn pile, while Claire had her rake cleaning up the small stuff 20260311_095529.jpg
    Had to stop and move some logs, yep got the Echo pinched in a fork... 20260311_095541.jpg
    On to the next group of 5 trees. Had the first one hang up a little, then fall way left of where I wanted, it didn't hit the powerline...it's the bottom tree in the group. 20260311_111608.jpg
    I was way more careful on the next one, te best drop of the day. Between the cedar and short fence..
    right towards where the JD is sitting
    The last tree in the group was the toughest, it was on the point of the triangle, lines on each side, with back lean. 20260311_131136.jpg
    We could only get the corner of the grapple tight against it 20260311_131610.jpg
    Made sure to have a good hinge and steady pressure from Orange Crush guided it safely down... 20260311_131701.jpg
    Miz Carol got some seat time in as well, she moved logs for awhile... 20260311_135458.jpg 20260311_135522.jpg
    The log pile from the side yard...mostly 12' logs, a few 8' to the side... 20260311_163610.jpg
    We then moved to the back yard and cut 8 more, these were on the smaller size, some only had 1 or 2 12' saw logs.
    I was helping Voyne with a couple trees/stumps, I was trying to get this tree pushed up and loose, when I found the other stump hole...yep, it was deep... 20260311_124522.jpg
    He was able to grab the log and I cut off a section. We then used a chain and the JD to help us out... 20260311_124618.jpg 20260311_124915.jpg
    Got the front tire a bit muddy...:rofl: :lol:
  20. T.Jeff Veal
    Back to the pines on Tuesday. We started with 2 big pines in the backyard...one on the right had to be pulled with the cable... and then we did the one on the point. 20260331_092350.jpg
    Got 8 8' and 2 12' logs from those trees Messenger_creation_71AF56F7-8540-4060-962E-98D5BC64CD19.jpeg 20260331_152540.jpg
    There are more in the back to do, but they wanted us to start on the front yard. Big boy on deck... Messenger_creation_67A8FEB9-CA17-4CBF-B2A0-238699FF25B8.jpeg
    It went a bit more right than I wanted and took out a dogwood, but it missed the 2 water facets to the left... Messenger_creation_ED2D28BA-7E68-4F1F-B56A-2D4BD5C8D74E.jpeg
    Another one heading down Messenger_creation_91EA7F78-6ADD-44A9-97D5-FB54536C4703.jpeg
    The skinny one had to be pushed... Messenger_creation_1C1FF319-6BBF-4FFC-9A1A-392D557A7DAF.jpeg
    Kubota gets it done Messenger_creation_5713C33A-A7AF-419A-A371-E5210E03EF31.jpeg
