Pine clearing for the new garage build
Discussion in 'The Wood Pile' started by thewoodlands, Mar 7, 2018.
  1. thewoodlands
    thewoodlands
    By the feel of it, the cold front is coming in so watch out east of us.
  2. MikeInMa
    Yup severe weather forecasted for late tonight.
    About 7 inches of rain here, in a week's time.
  3. papadave
    Maina, Well Seasoned, Chaz and 5 others like this.
  4. thewoodlands
    thewoodlands
    We had a quick 10 degree drop from 70 degrees with some wind and then it stop, we have been getting rain but we need it.
    savemoney, Hammy, yooperdave and 4 others like this.
  5. thewoodlands
    thewoodlands
    I was wondering what length screws you would use to screw through a 1.5 inch thick board and then through some OSB (0.40 inches thick) and into the 2 x 6 in behind the OSB. This will be the back support for the workbench in the garage.
    I'll be using exterior rated screws, is 2.5 inches long enough or would 3 inches long be better?
    Hammy, Well Seasoned, Chaz and 2 others like this.
  6. Eric VW
    3” :yes:
    Maina, Hammy, Marvin and 6 others like this.
  7. thewoodlands
    thewoodlands
    Thanks, I figured that would be the answer since I have some 2.5 in stock. :whistle:
    savemoney, Hammy, yooperdave and 5 others like this.
  8. Eric VW
    Well, how much weight do plan on loading the shelves with?
    You could counterbore in a 1/2” as well....
  9. thewoodlands
    thewoodlands
    I'm not sure on the weight but the work tables are heavy enough, I want something that will last.
  10. thewoodlands
    thewoodlands
    Maina, Hammy, yooperdave and 4 others like this.
  11. Eric VW
    All the force on a shelf(not too deep) is typically 90° to the shelf, so as long as you don’t load the front of the shelf too much, the 2.5” screws + 1/2” deep counterbore setup will be quite robust.
  12. Eric VW
  13. thewoodlands
    thewoodlands
    Hammy, Well Seasoned, Chaz and 3 others like this.
  14. thewoodlands
    thewoodlands
    We have drywall type screws the length we need but they're not exterior rated, it's inside the garage but I still like exterior rated screws.
    Hammy, Maina, Well Seasoned and 3 others like this.
  15. Eric VW
    Who doesn’t...:yes:
    But I don’t believe even in a partially conditioned space you will ever see those drywall screws degrade to any point near failure. :handshake:
  16. papadave
    Ah, I thought since it was insulated, you'd be heating.
  17. thewoodlands
    thewoodlands
    Not all the walls are and none of the ceiling is. Getting the cement blocks waterproofed on the outside is my next job, I'm hoping I can get two coats on it.
    I will have a small portable propane heater in the garage.
    Hammy, Marvin, Well Seasoned and 3 others like this.
  18. Well Seasoned
    We had some decent winds for a few hours- then some heavy rain. Any thunderstorms missed us. The temps are really cooling down now, expecting mid 40s tonight.
    Chaz, Hammy, Maina and 7 others like this.
  19. thewoodlands
    thewoodlands
    They're calling for 44 tonight in this area so the wife wants a fire, I'll get one going in about an hour.
    The wood we're burning is stuff we didn't burn from the shoulder season wood last year.
    Chaz, Hammy, Maina and 6 others like this.
  20. savemoney
    The new Avatar, what is it. All I can see is some white with brown lumps. my macrodegeration sometimes makes it hard to interpret some things. I was thinking cinnamon buns.
