Picked up my Woodstock Absolute Steel
Discussion in 'Modern EPA Stoves and Fireplaces' started by westczek, Oct 8, 2019.
  1. Eckie
    Eckie
    Westczek, have you gotten to use your AS yet? Interested in thoughts from a new AS user in Va...
    T.Jeff Veal, Chazsbetterhalf and Chaz like this.
  2. T.Jeff Veal
    Welcome to the club. Lots of great folks here sharing knowledge and humor.
    Chaz likes this.
  3. Eckie
    Eckie
    Thanks T.Jeff. I should clarify though, I am a new member here, but I dont have an AS. I'm still looking, reading , researching and wanting. Wanted to get Westczek's thoughts on his new stove if he's run it yet.
    T.Jeff Veal and Chaz like this.
  4. Canadian border VT
    Great company and a pretty stove but we need :ithappened::D
  5. T.Jeff Veal
    We dont have one either. We have a Drolet Blackcomb
    Chaz and brenndatomu like this.
  6. Nitrodave
    Nitrodave
    Grayling Mi.
    I am a first winter AS stove owner also. Dry Dry wood is a big factor in these stoves. I have oak and ash that is 20-22% ... it makes good heat, but is finicky and dirties up the glass. I thought that I may not have enough chimney, so I borrowed an arm full of good dry oak from a friend... Holy Moly will this put out the heat !!!! Nothing wrong with the install... :dennis:
    Maina, Chaz, NVhunter and 5 others like this.
  7. Oldhippie
    Oldhippie
    Ashby Ma
    My findings as well.
  8. NVhunter
    NVhunter
    Northern Nevada
    Yeah I have had my Ideal Steel for 4 years and the first year was a struggle. I didn't have the best wood and it was a learning curve for sure. Dry seasoned wood is a must for these hybrid stoves. Once you figure them out they are great heaters. Last night I had 3 big pieces of pine in the stove and it was 82 downstairs in the basement where the stove is, and 77 upstairs. Too hot in my opinion but it shows these stoves can pump the heat. :coldfire:
  9. Chaz
    Chaz
    Southwestern NY
    Actually heard the Oil furnace this morning.
    :faint:
    I shut the primary down too much last night, Chazsbetterhalf said it was charcoal this morning.
    Still enough hot coals underneath that she just cracked the door for a bit and it was burning hot again.
    Just goes to show, you can starve these stoves of air.
    :whistle:
  10. Eckie
    Eckie
    Im sure this stove can heat you out of a room, but compared to a 'standard' steel stove, is it more controllable? Dont want ro highjack the thread, but trying to figure out if the AS (or any hybrid that's steel) can be run to give a 'gentler' heat like a cast iron or soap stone stove if needed.
    T.Jeff Veal, NVhunter and Chaz like this.
  11. Chaz
    Chaz
    Southwestern NY
    Can't compare it to many other stoves, as I've limited experience with others.
    This is the second wood stove I've owned/operated in my life.
    But it is immensely superior to the old stove we had.
    EDIT.. We have an IS, and not an AS stove.
    T.Jeff Veal and NVhunter like this.
  12. Nitrodave
    Nitrodave
    Grayling Mi.
    I have not had one of the other stoves...
    but I find this very controllable....
  13. NVhunter
    NVhunter
    Northern Nevada
    The IS is very controllable in my opinion. My father in law has a Kuma Ashwood steel stove. I can easily move the air control with the IS and watch the flames grow and die, the Kuma Ashwood I'll move the air control and see nothing... That stove is full blast the whole time and it seems like your throwing wood into it every 2 hours. I can reload the IS (and assume the AS is very similar in operating) every 8 to 10 hours if I load it up full.
    Maina, T.Jeff Veal and Chaz like this.
  14. westczek
    westczek
    Our Absolute Steel is finally in place. We are building the house it is going in (my dad and I are doing everything ourselves), and had to get the floor down before we could position it. Mudding drywall seemed to take for ever. Now I need some single wall stove pipe to reach the chimney about 15 feet above the stove.
  15. Eckie
    Eckie
    Woo hoo getting there! Do you think you will have it running this season? Really looking forward to hearing how it performs for you and how you like it. Can you narrow down some what part of Va you're in?
  16. Chaz
    Chaz
    Southwestern NY
    I hate mudding drywall.
    :hair:
    Like you said, it seems to take me about 3 days to sand it out.
    Hoping all the while that I don't get overly aggressive in spots.
    :faint:
    Good luck with the build and install.
    :yes:
    Maina and T.Jeff Veal like this.
  17. T.Jeff Veal
    Have you thought of using double wall pipe from the stove to the ceiling? Will be safer and last longer.
  18. brenndatomu
    And makes cat stoves work better too...
    Maina, T.Jeff Veal, papadave and 2 others like this.
  19. Canadian border VT
    I didn’t know that... why
  20. brenndatomu
    Cat stoves tend to run low flue temps at low burn rates...doublewall helps keep the temps up for more consistent draft and cleaner flue...and as Jeff mentioned...will last a lot longer too because most DW is stainless on the inner layer...Ive seen regular steel stovepipe with holes in it after only 2 seasons.
