Picked up an Englander NC30 today...
Discussion in 'Modern EPA Stoves and Fireplaces' started by Marvin, Dec 9, 2018.
  1. saskwoodburner
    saskwoodburner
    Feel free to respond or not it's your choice, but stating...
    ..like the people who built the stove didn't do any of that research themselves. :picard:
    is saying what exactly then?
    brenndatomu and Marvin like this.
  2. bushpilot
    bushpilot
    Eastern Washington
    I think you misread papadave, he actually tried the mods, and was pleasantly surprised that the stove was pretty well designed.
    Gracious reply.:yes:
    Chvymn99, HDRock, Maina and 3 others like this.
  3. Highbeam
    Highbeam
    I tried blocking off some ports but I run my nc30 hard and I was worried that without a large flow of cooling air passing through the secondary tubes that they might melt so I unblocked them.
    I think a place where most of us could gain some efficiency with this stove is by slowing the draft using a damper. I like to sweep the chimney without taking it apart so I am resisting a damper but maybe some day.
    The nc30 pukes lots of heat and exhaust flow up the stack. I think that’s why it burns so clean.
    saskwoodburner and Marvin like this.
  4. HDRock
    That is exactly the reason I don't have a damper on my set up, With my Lopi ,But then again don't think I need it either , Never had to stop burning because of high winds .
    Highbeam and Marvin like this.
  5. Marvin
    Marvin
    Huntingdon, Pa
    I have a damper installed but haven't really messed with it since installing the nc30. We've been getting some pretty good wind gusts today but I haven't felt the need to tinker with it yet. Maybe tomorrow. I think it is supposed to be windy again.
    HDRock likes this.
  6. HDRock
    With my old stove I would have Burned the house down without a damper
    Marvin and brenndatomu like this.
  7. brenndatomu
    SootEater will go right past a manual damper...
    Chvymn99, Maina, Marvin and 1 other person like this.
  8. HDRock
    Oh , now you tell me :D , First time I shoved a brush down my chimney , I got it stuck on damper , had to take the pipe apart to get it out , bent the hell out of it , had to put in a new one, Cleaned the chimney many times after that Needless to say I didn't F it up and again :headbang:
    But then SootEater didn't exist then
    Chvymn99, Thor, Marvin and 1 other person like this.
  9. brenndatomu
    I forgot to remove my temp sensor probe before cleaning...Sooteater kicked it out, but no damage...:emb: :yes:
    Chvymn99, Thor, HDRock and 1 other person like this.
  10. HDRock
    In case you don't remember, I did that too with a brush , son of beotch :headbang::picard:
    Thor, Marvin and brenndatomu like this.
  11. DexterDay
    DexterDay Administrator
    Northeast Oh
    No backpuffing here. The only issue I've had is in the beginning of the burning season the flue reverses its draft when the stove is cold for a few days.
    But that's not a big issue. A couple candles in the stove, or a butane torch for about a minute and it gets the draft corrected pretty fast.
    papadave, Maina, brenndatomu and 2 others like this.
  12. saskwoodburner
    saskwoodburner
    I'm curious if you observed a reduction in secondary flame speed or weird angle of flame such as I did (different stove of course)?
    I totally agree with the damper, as that's exactly what I found out on both accounts.
    Maina, brenndatomu and Marvin like this.
  13. saskwoodburner
    saskwoodburner
    I have 2 chimney brushes, a steel one and a synthetic one. I trimmed the bristles slightly on the synthetic one so I can back n forth like cleaning a muzzleloader barrel, as opposed to all the way down, all the way up. I'd probably be in a world of hurt using the steel one with my damper installed!
    brenndatomu, HDRock and Marvin like this.
  14. Marvin
    Marvin
    Huntingdon, Pa
    Since we're on to talk about chimney brushes...
    I bought a synthetic brush for my ss liner. I still have the tool I used for knocking out the clay tile. Could I use a 6" brush hooked to a drill to make a redneck sooteater or would that risk damaging the liner? Just a thought for the next time I clean :whistle:
    saskwoodburner and brenndatomu like this.
  15. chris
    chris
    SE WI
    It could be done provided you make sure you have it spinning in the the right direction to not uncouple- no fun taking a flue apart to recover stuck or lost tool. The sooteater will never lodge tightly due to what it is. if you wanted to try to make your own some weed wacker line of the thickest available would be a better choice. not sure but i think .105 is the thickest, or 10-12ga stranded electrical wire.
    Marvin likes this.
  16. Marvin
    Marvin
    Huntingdon, Pa
    Yeah that would definitely be a no go for me since I have a masonry chimney. Not fun indeed.
  17. Highbeam
    Highbeam
    Yes, the secondaries were less jetlike and more yellow. Dropped into the fuel more than shooting along the roof like usual. It was apparent that the air was flowing slower and the flames lingering which made me worry about overheating those tubes.
  18. chris
    chris
    SE WI
    Never had a problem with the tubes on a NC30 and I have had them glowing red+ on more than one occasion. Generally if all 4 tubes are in full after burner mode you are likely in the 650 deg F+ stove top wise at the step, I wouldn't leave it run like that though, nice clean flue after that though.
  19. Marvin
    Marvin
    Huntingdon, Pa
    Lately I seem to have been having an issue with the stove burning awfully hot (got up to 800* STT last night on the overnight load) and leaving a bunch of big chunky coals. So today I did the dollar bill test. Total failure :picard: No problem. Fluffed up the gasket all around the door. Gooder to go now :thumbs:
    It's amazing since the problem developed over a period of time, I didn't even realize how much control I had lost over the burn. Since fluffing the door gasket it's like a whole new stove. I'll be replacing that this summer.
  20. chris
    chris
    SE WI
    Yikes!!!!
    Chvymn99, brenndatomu and Marvin like this.
