Phase 2 logging
Discussion in 'The Wood Pile' started by T.Jeff Veal, Jun 10, 2022.
  1. T.Jeff Veal
    We're going to cut them lower, but the homeowner is going to get them ground down.
    Rich L and jo191145 like this.
  2. jo191145
    jo191145
    Ct
    Maybe you should consider buying a stump grinder ;)
    Rich L, T.Jeff Veal and buZZsaw BRAD like this.
  3. T.Jeff Veal
    I looked at a few...lol...it would take all the $$ from this job and then some to get a nice one. Even looked at a 3 pt one for the tractor. He could lease one for a week and we could do that for him...
    jo191145 and Rich L like this.
  4. The Wood Wolverine
    Lookin' awesome! Makes me what to fire up a saw...
  5. T.Jeff Veal
    Thanks, my friend. Hope to be back there next week. Come on down, supposed to be cooler temps and we have a few tricky ones to drop...
    buZZsaw BRAD likes this.
  6. T.Jeff Veal
    After a 2 1/2 week delay (work schedule and weather), we finally made it back to logging site. We got up a big top, 2 trees that we had dropped before and then cut 2 smaller oaks. Got a big load, had to use pry bar to help start it dumping.
    Hope to go back Thursday. Can't haul that size load then. Had to order a consumable part for the Andersen hitch, anti-sway sleeve that goes in the hitch.
    We will have the regular hitch on the truck.
  7. Stinny
    You make bringing down trees look easy T.Jeff Veal ... nice job!
  8. T.Jeff Veal
    After night shift and equipment repairs Tuesday, we made it back to the site Wednesday morning. Decided to take down some more oaks for our woodyard. 25846.jpeg
    Another oak we took down...
    We also dropped a water oak too.
    That evening, we dropped 4 pines
    This one was a leaner, only time I've ever had the saw get pinched in a bore cut. Went ol' skool and used the axe, some good whacks and it finally popped loose 25855.jpeg
    For some reason, the saws sound seems to attract the cicadas. I've had several land on me while I was cutting... 25935.jpeg
  9. thewoodlands
    thewoodlands
    Nice work T.Jeff Veal , the yard must be full of logs.
  10. T.Jeff Veal
    Thursday was another good day on the site. We had several sweet gums to take down, each one had at least 2 - 10" or bigger logs for the mill. 25928.jpeg
    When I was talking to the timber buyer, I mentioned we had some smaller pine and gum that we would probably have to put on the burn pile. He said to take it to the chip mill down the road from the saw mill, he could get us in there also. They agreed to take 12' lengths, so we loaded up the pine we cut Wed and dropped another by the pool.
    This was some of the tightest grain pine I've seen in awhile. Too bad they weren't big enough to mill some boards... 25858.jpeg
    This load net weight was 9700#.
    Since we still had time and I hate to pull an empty trailer home, we dropped 2 more red oaks and 2 water oaks.
    We just used the tractor as a precaution, the wedge was all that was needed... 25931.jpeg
    This big girl was using this oak and the pump house as anchor points for her web. Banana spider 0831221217.jpg
    The 2 water oaks were a bit more tricky. Bad leaners towards the house, didn't have much room to maneuver the tractor on the 2nd one, fence right behind the tractor 25917.jpeg
    And it started raining about the time that tree went down, but we got 2 logs bucked off the biggest water oak to finish the load. 0901222045.jpg
    Left the site about 8:45PM. Got home safe.
  11. T.Jeff Veal
    Yes sir, it is. We might can get a few more on the stacks, probably have to find another dumping area.
    WinonaRail and Chvymn99 like this.
  12. T.Jeff Veal
    We were blessed with an easy site. We have had a few that made us scratch our heads for a bit.
    This is the front yard, the beginning of this job...
    Our biggest logging job yet.
  13. MikeInMa
    Entertaining videos! A whole lot of wedge pounding in that last video.
    T.Jeff Veal and Chvymn99 like this.
  14. buZZsaw BRAD
    Nice job wedging that one over. I like using a steel wedge for felling.
    Maybe the cicadas thought you were cute and you were serenading them??? :whistle:
    T.Jeff Veal and Sirchopsalot like this.
  15. T.Jeff Veal
    Yes sir. That tree had a bad lean towards the house. Had several wedges in it to help the cable pull as much as possible
    Chvymn99 and buZZsaw BRAD like this.
  16. T.Jeff Veal
    I have a big steel wedge too. Sometimes the chain hits the wedge and the plastic doesn't hurt it.
  17. T.Jeff Veal
    After our anniversary trip the week of Labor Day and work week after that, we made it back to the site on the 19th.
    Decided to tackle one that had me troubled for awhile. It was big, had some lean towards the pump house, and a long way to the first limb. 0919220957_HDR.jpg
    Since we had cut all the trees to the left of it, we decided to use notch and wedges to get it in the safe drop zone.
    We loaded the water oak logs from the last time we were there first, then some of the big logs from this tree. Had this load by lunchtime
    We came back that afternoon, took down 3 more nice oaks and 2 small ones.
    We cleaned up the tops and hauled that load to an older friend that needed some wood, loaded 4 pallets of bricks on our pastor's trailer and hauled it to his house and started cleaning up some older tops/limbs in the back yard Tuesday. Sorry, no:ithappened:of all that.
    Getting ready to burn the 4 limb piles Saturday morning and then drop the trees around the pool next week.
  18. sirbuildalot
    sirbuildalot
    Mass
    Your half ton pulls some impressive loads Jeff. What engine does your truck have?
    Chvymn99 and T.Jeff Veal like this.
  19. T.Jeff Veal
    4.6L with a torque cam. It has been a great truck. Gets worked like a rented mule...:thumbs::thumbs:
  20. T.Jeff Veal
    With the approaching storm, Ian, possibly coming thru our area soon, we went over Monday morning and dropped the 11 trees in the pool area. 7 red oaks, 4 sweet gums.
    Several just used a wedge to turn them. Had the tractor as a backup plan. 26681.jpeg 26683.jpeg
    Then we had a couple sketchy ones left. We used the pulley and cable on that long leaner over the pool
    Notched and did a partial back cut on it. Then used the tractor to nudge it towards the dirt pile. Made an ugly stump, but made it go in the right direction. 0926221112_HDR.jpg
    Giving GOD all the praise for HIS protection on the property and safety for us. I'm happy to report that all the trees around the house are now down safely. We have 1 more with a hanging limb to drop in the backyard and 12 along the driveway. Almost done.
