Pellet stove help needed
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Well Seasoned, Jul 17, 2016.
  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Ya gotta snoop more be nosey.
    CleanFire, slvrblkk, wildwest and 3 others like this.
  2. Old Fart from Eganville
    Eganville, Ontario
    If it is a multi fuel you may want to check on corn or rye seed. I am going to use rye seed this year and have 4 ton ordered.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Burning food.... food that makes perfectly good whiskey.... i cant talk to you anymore.
  4. Well Seasoned
    I noticed that the OAK isn't hooked up. Is this a big deal? They must have used it this way for years.....
    There is a Co meter
    CleanFire and wildwest like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    It should really be connected on a pellet stove. They have a combustion blower that needs unrestricted flow. That is achieved by pulling from directly outside.
  6. will711
    will711
    Pocono Mts.
    This has been debated before , I don't have an OAK on either of my stoves , they both work fine and my house stays nice and warm , in some cases the OAK is required , by manufacturer or code install in a mobile home ..... and when I bought my 1st stove I asked about the OAK dealer said not needed so that's the way I went , and it works for me , plenty will disagree with that and that's OK :cheers:
    CleanFire, slvrblkk, wildwest and 5 others like this.
  7. jtakeman
    Let the great OAK debate begin!!! :D
    My vote is OAK and I'm stickin to it. Far less negative in using the oaks than not. Negative house pressure that is. :p
  8. will711
    will711
    Pocono Mts.
    Do we really have to :hair: I'd rather just drink Beer :thumbs::pete:
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    OAK and beer for me!!!
  10. Well Seasoned
    I did have an oak on my previous jotul. The previous owner left it in the shed, but the flue goes right up the chimney. I'll have to investigate this..... thx
  11. IHATEPROPANE
    IHATEPROPANE
    That stove requires an oak per the manufacturer.
    I too would vote oak. However, in the really cold they can cause some issues in my experience.
  12. Well Seasoned
    What kind of issues have you had?
    Dipping to 42 tomorrow night...... tempting isn't it! :):fire:
  13. imacman
    imacman
    Denver, NC
    The typical pellet burner uses up between 3-4 tons, depending on severity of winter, how well the house is insulated, and what temp you like to keep the room the stove is in. Could be more, could be less.
    bogieb, CleanFire, slvrblkk and 4 others like this.
  14. imacman
    imacman
    Denver, NC
    You should get the OAK hooked up immediately before burning season. Otherwise, you're using already heated air to feed the fire and send it up the exhaust. Also helps eliminate cold drafts. There is no down side to having an OAK hooked up. And Englander requires it in the owners manual of ALL it's pellet stoves.
  15. IHATEPROPANE
    IHATEPROPANE
    There has been some frost build up on the oak itself. But the biggest issue is the ash kinda cakes up and the stove requires more cleaning. This only happens when we are in the low teens or colder.
    imacman, CleanFire, slvrblkk and 2 others like this.
  16. wildwest
    We put on OAK in the only place suitable to avoid snow drifts, pellet stove still has problems.... Don't ask STB as its a different brand and different stove, but, he's in the know on mine anyway.
  17. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    should i buy more than that ?
  18. slvrblkk
    slvrblkk
    Northampton, PA
    Oak it.....I believe, per the manual, it's a requirement. Plus you don't want to sent out air you just heated up the flue....just my $.02
  19. CleanFire
    CleanFire
    "but most keep 12-16 tons on hand just in case."
    :rofl: :lol: That stash would be bigger than our home.. Although Steve, Will, JT, and Bogieb are close to that. :D
  20. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    OAK it.
    ive burned up to 6 ton keep it warmmer.
    TS inbound.
