  1. bogieb
    Good job!
    imacman, savemoney, ttdberg and 3 others like this.
  2. bogieb
    :jaw::bug: - those look nasty
    imacman, ttdberg, jtakeman and 2 others like this.
  3. jtakeman
    :whistle:
    :zip:
    Thanks Smoke. I was going to try and repair the TB(pull the cover and clean the contacts-Add some no ox to the contacts ect) . My luck I'd only fudge it up. :emb:
    Why go used when new will do! :D
  4. smoke show
    smoke show
    Pittsfield, Wi
    Not real familiar with Fords but GM didn't make the harness any longer then needed and the stress would raise hell with the terminals.
    imacman, ttdberg, gbreda and 3 others like this.
  5. jtakeman
    My outboard had a PCM issue(no power) couple seasons ago. Dealer couldn't find the issue. Nearly stranded us on the lake. Popped the bonnet and happened to lean on the cable with key on and saw the PCM light up. Wiggle the harness and they went off. Located the nearest connector and there was a wire that so nicely slipped out of the connector. Cut one of the wire ties to give it some slack to get back to the ramp. Ended the day early. A lil snip-solder and a tuck had it going. And zero dollars except for my time.
    imacman, gbreda, smoke show and 4 others like this.
  6. badbob
    badbob
    yep one of the first tests on cars is the "wiggle test"
    imacman, gbreda, IHATEPROPANE and 3 others like this.
  7. jtakeman
    :D
    1998 F250 idle air valve sticking. Wouldn't idle without keeping you foot on the gas. Grab a wrench and whack it. Good to go for couple of months. Finally changed it after missing it with a pizzed off whack and busted the connector. :emb:
    :doh:
    imacman, gbreda, IHATEPROPANE and 2 others like this.
  8. badbob
    badbob
  9. gbreda
    gbreda
    NH
    78 degrees today and same forecast for tomorrow. Not complaining one bit here :thumbs:
    savemoney, slvrblkk, ttdberg and 4 others like this.
  10. Earl764
    Earl764
    CT
    Bring back the cold.
    savemoney, bogieb and IHATEPROPANE like this.
  11. gbreda
    gbreda
    NH
    No thank you. Glad to keep it down in CT, but J might have something to say about that
    savemoney, slvrblkk, ttdberg and 5 others like this.
  12. jtakeman
    Hit 81 and opened da winders when I got home to let in some freshness! Top ten day for sure. To bad I hadda work.
    Just hope we get one good en for da weekend!! :seasoned:
  13. gbreda
    gbreda
    NH
    I burned a vaca day for tomorrow and have Monday off as a floater holiday :thumbs:
    savemoney, slvrblkk, will711 and 4 others like this.
  14. IHATEPROPANE
    IHATEPROPANE
    Took the air conditioners out of the windows and set up the west point to go on/off on the stat as needed to go along with the Englander. Guess I am ready for winter
    savemoney, slvrblkk, imacman and 4 others like this.
  15. gbreda
    gbreda
    NH
    Yeah, I eyed the ac as I was grilling some burgers tonight. That will be coming out tomorrow.
  16. Dpopps
    Dpopps
    MI
    77 today, had the central a/c on. Cold coming this weekend. Guess it's pumpkin picking and apples this weekend..
    slvrblkk, imacman, gbreda and 4 others like this.
  17. bogieb
    Where? it was 60's at work (near Manch) and the high at my house was 63 according to my weather station.
  18. gbreda
    gbreda
    NH
    Barrington. I went to pick up lunch at 1:15 yesterday and the truck temp said 77 degrees. Came down to about 74 as I drove. It was tough to go back to work.
    The temp drops like a rock as soon as the sun starts going down though. I think it was in the high fifties at home by 7:30 last night.
    If we could have this weather all year, I would be a happy camper. Mid/upper 70's by day and 40's/low 50's at night. :yes:
  19. jtakeman
    Joeys got the day off from school. Was surprised to see him up before I left for work. Because the car is down. He's dropping mom off at work and going fishing. I was shocked mom let him use the truck.............
    I just hope he doesn't forget to pick mom up. :whistle:
    :heidi:
  20. gbreda
    gbreda
    NH
    Top 10 day for sure !!
    AC is out and window is cleaned up. It always looks funny after the unit is out and the window is wide open again.
    1:20 temp of 73 and loving it
