  1. artc
    artc
    Rocky Hill, CT
    wildwest, CleanFire, bogieb and 3 others like this.
  2. PelletHound
    PelletHound
    SE Ma.
    Time for some of these.:cheers: P1010741.JPG
    eatonpcat, imacman, jtakeman and 8 others like this.
  3. IHATEPROPANE
    IHATEPROPANE
    I am a Steelers fan today! Wish Brown was playing though.
  4. Ambient
    Ambient
    Northern New York
    I had that for years. Then when I had the OS software update issue, that froze the screen on start up, I had to work with the Genius Bar folks and the Apple forum. It became clear that the AV for Mac was part of the problem, I was directed to remove it as it was contributing to the issue. Even after I did, there were more files that had to be painstakingly removed individually. That was last Spring, Apple tech's insisted the AV program was totally unnecessary. After so many years of Winblows I feel naked without something at least looking like it's protecting the computer.
  5. Pete Zahria
    Pete Zahria
    New Hampster
    I wish we did the same as you....
    where I live, the mere forecast is enough to bring out the salt...
    In a short while, the roads look like the ones in Florida. WHITE!
    Dan
    eatonpcat, will711, gbreda and 8 others like this.
  6. smoke show
    smoke show
    Pittsfield, Wi
    Vehicles here disintegrate before they quit running.
    eatonpcat, imacman, gbreda and 7 others like this.
  7. Ambient
    Ambient
    Northern New York
    I had posted about my project to restore the Farms truck. These U bolts that hold the axle to the rear suspension looked like they needed replacement right off. Notice the rear post on the left side is completely gone. I recently received a frame from Oklahoma to replace the original, which had begun to have rust through spots. Salt sucks! I plastered the under carriage with a product called FluidFilm, I'm testing it this winter. You have to apply it yearly at about $40 a gallon. It took about 1/2 a gallon. Won't wash away and stops any oxidation of the existing rust...so they claim.
    Farm Truck Frame: Here
  8. smoke show
    smoke show
    Pittsfield, Wi
    POR-15 Rust Preventive Coating
    will711, ivanhoe, 343amc and 5 others like this.
  9. CleanFire
    CleanFire
    That's what I've used here Smoke, gooood stuff, takes a beating and lasts. :yes:
    will711, ivanhoe, wildwest and 3 others like this.
  10. Ambient
    Ambient
    Northern New York
    I was on to that until I got the replacement frame, as it has a great reputation. I will however be starting with everything apart as there's only surface rust, so I will sand blast it off start with bare metal and use a product/System I got from Eastwood:
    Eastwood Internal Frame Coating Green Unreachable interior areas
    Eastwood After Blast - Metal Prep
    Epoxy Primer Black w/Catalyst Quart Kit
    Extreme Chassis Black Satin Quart
    Tank Tone Metallic Coating Aerosol 13 oz (
    Fuel Tank exterior)
  11. Dr.Faustus
    Dr.Faustus
    Hudson Valley
    its an '08 subaru legacy with 160,000 miles. Doesn't do much to excite me, never has but it always gets me where i'm going. Its easier to take care of a car that you actually want. I am in the market for a new car probably sometime this year or early next. The salt actually hasnt done anything to it yet. no rust spots. I use dedicated snows on steel rims and this car has been out in the nastiest weather. Been through floods, overflowed rivers, hurricanes. used to commute 1.5 hrs each way to work with it in blizzards.
    They use so much salt here I joke about deer following me down the road trying to lick my car.
    eatonpcat, will711, ivanhoe and 4 others like this.
  12. Ambient
    Ambient
    Northern New York
    That is what I would have used if I wasn't replacing the frame.
  13. DexterDay
    DexterDay Administrator
    Northeast Oh
    Furnace is cleaned, driveway is salted (a lot) :( , and now it's time to relax and have an ice cold beverage! :)
    eatonpcat, ivanhoe, CleanFire and 3 others like this.
  14. dylskee
    dylskee
    Central MA
    Well, went to TSC today and this is what they had for pellets. I burned some of these last year and if I remember correctly they weren't too bad, but I honestly don't remember.
  15. Ambient
    Ambient
    Northern New York
    I like mine at room temperature more flavor! :thumbs:
    ivanhoe, IHATEPROPANE and CleanFire like this.
  16. smoke show
    smoke show
    Pittsfield, Wi
    This should hold me for a few minutes.
    wildwest, ivanhoe, schoondog and 8 others like this.
  17. CleanFire
    CleanFire
    Nice. Sounds like you are going to do it right. :salute:
    When I did the Sportage 4x4 frame here w/ POR, I didn't sandblast, but it was a multi-day marathon of scraping, wire brushing, sanding, wiping/degreasing, and painting w/ POR - like anything, proper prep is the key. That it's held up this long (7+ years now) and protected so well is a real testament to the product.
    POR isn't cheap, some consider it expensive, but the stuff works, takes hellish abuse, and lasts for years.
    It's on my list of things-to-do for Summer of 2016, to fully POR the undercarriage of the '00 Camry here.
    wildwest, Ambient, ivanhoe and 2 others like this.
  18. CleanFire
    CleanFire
    :drool: Dammit Smoke, you made me hungry, again. :picard:
    Looks very tasty! :thumbs:
    :cheers:
    wildwest, Ambient, ivanhoe and 3 others like this.
  19. imacman
    imacman
    Denver, NC
  20. imacman
    imacman
    Denver, NC
    wildwest, jtakeman, Ambient and 4 others like this.
