  1. savemoney
    I've been getting from Amazon delivered for cheaper than I can buy it at the pet store. It get delivered right in my enclosed porch so I don't have to do a lot of lifting. From Amazon, it comes as prime so there isn't any big delay. I try to stay a couple bags ahead.
    upload_2015-12-20_15-19-57.png Cat Litter Brands and Reviews
    gbreda, CleanFire, ivanhoe and 3 others like this.
  2. jtakeman
    We've got 2 of those and also the Catit Design SmartSift. And a clay box as we are just converting to the scoopable litter. Still have one kitty that doesn't seem to like the new stuff. I'll use the scoop litter in the old box for a while and get another Omega paw to replace it.
    Even the dog got in on the act. Our little princess abby. Such a cute lil chit!!
    imacman, ttdberg, brokenwing and 7 others like this.
  3. CleanFire
    CleanFire
    Tip: If you would prefer not to alter the workbench.. cut and size some 2x4 lumber to the same size as the bottom bench supports, counter-sink the casters flush in the 2x4's and use some U-Bolts U-Bolts - Bolts - Fasteners - Hardware -  The Home Depot
    to secure the 2x4 rollers to the bench supports - this way you can easily remove / reattach the casters, depending on need.
  4. wildwest
    What happens to them on concrete floors?
    bogieb, CleanFire and ivanhoe like this.
  5. savemoney
    Absolutely nothing if your floor hasn't got standing water on it. I've got 2x4 untreated spruce on cement 40 years with no signs of deterioration.
    gbreda, bogieb, CleanFire and 2 others like this.
  6. ivanhoe
    ivanhoe
    Northern Ontario
    All depends the humidity from the floor. Water and wood not a good mix, sponge to decay.
    bogieb, CleanFire and wildwest like this.
  7. wildwest
    I had no idea how hard humidity is for so many til I joined FHC. Most the basements in Colo never get wet, and are finshished, with carpet and the whole 9 yards. I guess that explains the water stains in her earlier post that couldn't identify.
  8. bogieb
    My basement floor wicks up water easily - I am feet from a swamp. The reason I have ripped out walls and the built-in workshop cabinets was because they were nasty with rot from being wet. Also why I will have to cut down the shelves (earlier post) and try to save the upper portion. Even the pressure treated lumber at the bottom of the wall framing was crumbling from the moisture. Here are pics of a couple of walls I took out last year - and these were good compared to the workshop I just ripped out, since they were in the "dryer" part of the basement.
    ivanhoe, CleanFire and wildwest like this.
  9. bogieb
    That is a good idea!
    ivanhoe and wildwest like this.
  10. bogieb
    My last house was 600' higher than my present house. On the side of a ridge and the basement stayed dry so we finished it. This basement will never be completely "finished" as it is too low, close to the water table, and is dampish in the spring-early fall. I also have some water infiltrate from the garage during heavy rains, but I'm close to solving that issue (I think - I'll see next year). But, regardless, it is damp, and no amount of mitigation is going to solve that unless I can magically lift the house and put another 5-10 feet of fill underneath.
  11. gbreda
    gbreda
    NH
    I am across from a river but on the side of a hill that higher than it is. My foundation walls have several cracks that are vertical and non structural where one would leak during heavy rains due to the walls being below grade and no gutters on the roof. I put up with it for years but it kept getting worse. I finally tried this and its been bone dry for 7-8 years now. Easy as can be and took maybe an hour and a half to complete. Most of the time is waiting for the epoxy to set up after installing the ports. I used the polyurethane kit without the easy peel. That means the epoxy is still on the wall but that doesnt bother me one bit
    RadonSeal Do-It-Yourself Foundation Crack Repair Kits
  12. wildwest
    :eek:
  13. bogieb
    Water comes in my garage door from the driveway. Although there is a small channel to carry the water to the back of the garage, where there is a sump pump, if it rains hard the water overflows the channel and comes into the basement under the entry door. I had the driveway torn up and redone last year and they sloped it toward the low part of the yard, but "low part" is not saying much.
  14. gbreda
    gbreda
    NH
    Ouch....that's a cost these days. My driveway needs to be torn up and redone but I dont even want to know how much that will cost.
  15. wildwest
    I havent had a driveway, sidewalk, or paved road since 1993:rofl: :lol:
    Stinny, bogieb, eatonpcat and 2 others like this.
  16. smoke show
    smoke show
    Pittsfield, Wi
    Is your last name Ingalls?
    will711, Stinny, bogieb and 6 others like this.
  17. wildwest
    Call me Laura.
    bogieb, eatonpcat, ivanhoe and 4 others like this.
  18. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    Is this posted at the beginning of your driveway!
    Stinny, bogieb, ivanhoe and 4 others like this.
  19. wildwest
    My long time previous home in the mountains, YES, falling rock, here it's flat:)
    bogieb, ivanhoe, CleanFire and 2 others like this.
  20. brokenwing
    brokenwing
    That is a beautiful pic! Someone is having a white Christmas!
    Stinny, bogieb, ivanhoe and 3 others like this.
