  1. gbreda
    gbreda
    NH
    I just noticed your join date. Welcome aboard to another com-padre- the more, the merrier !!!! :)
    ivanhoe, will711, CleanFire and 5 others like this.
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    37 F out this morning.
    The big Whit is happily churning away on a lovely diet of hazelnut shells this morning.
    First night last night to run the big Whit through the night.
    Been chilly, but the little Whit has been handling things OK until now.
    Below 45 F the little guy just can't hack it at night trying to heat 24oo sq ft
    Been struggling the past week and I finally said ENOUGH and stoked up the Big stove yesterday afternoon.
    We get down into the low 30 F or below then the Little Whit will be back up to help out.
    I don't run either of our stove above the #1 setting for more than a short time, as the heat output on the shells is higher than pellets.
    Just add another stove when it gets colder.
    If I had my way, we would have a stove in every corner :D
    wildwest, gbreda, ivanhoe and 9 others like this.
  3. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Save money
    We used to have just one Big Earth Stove pellet burner.
    The house was roasting or freezing, so we added a Quadrafire 1000 the second year we were here after we built the place.
    We used the Quad most of the time on pellets and when it got cold we used the Earth on nut shells.
    Was impossible to keep the house at an even temp with the big Earthy.
    Ended up running the Quad most of the time except if it was COLD
    Finally in 2009 I got tired of the high cost and decided we needed several stoves.
    We kept the Quad as a backup and a helper and added the little Whit in the living room (Opposite end of room from Quad)
    This really helped during the "Shoulder season" but still left us wanting.
    Finally yarded out the old Earthy and built a raised hearth then added the Whit Adv 2 T in the family room (opposite end of the house)
    Now we're railroading.
    A perfect combination that covers all the weather conditions.
    The little stove is great down to upper 40's F and then we trade off to the big Whit.
    When temps drop into the 20's F we fire off both Whits and this works well until we get into the LOW temps F outside and then the Quad will likely help out at night.
    A great combination.
    Nice part is, if one stove quits, we are not really fouled, and can limp along until repairs can be made.
    The more the merrier eh
    wildwest, ivanhoe, will711 and 5 others like this.
  4. savemoney
    So glad to have you here. Last time we wrote, you had a health battle going on. I hope you are able to get some help with your nut shell gathering. I changed out my stove. Now run a p68 which heats this place very nicely. If the temps go below zero, our new furnace will back the stove up. Things changed a lot here for me. I fell nearly two years ago and haven't recovered. My son and his family now live in half this house, we have the other half. Works out good for both of us.
    Welcome over to FHC. Hope you continue to participate in the fun we have here.
    wildwest, gbreda, ivanhoe and 6 others like this.
  5. imacman
    imacman
    Denver, NC
    :drool:
    wildwest, ivanhoe, slvrblkk and 3 others like this.
  6. IHATEPROPANE
    IHATEPROPANE
    Finished the leaves today, what a PITA.
    wildwest, gbreda, bogieb and 6 others like this.
  7. jtakeman
    I had the stat set at 71°F, Must have got some decent solar as the house was at 70°F. Felt a bit chilly so I reset the stat to 72°F and fired the stove.
    I prolly wodda been OK but the beer is really really cold tonight so! My excuse and I'm stickin to it!! "BURP"
    House should run up to 73°F before it kicks the stove off, I got a bit of swing set in it. Good on one end not so good on the other. Be nice if we could tweak the swing on each end/ I don't mind it running up past the setting on the higher end, But wish it would kick on a bit sooner on the lower end!!
    wildwest, gbreda, bogieb and 4 others like this.
  8. 343amc
    343amc
    Northeast Lower Michigan
    Got an updated combustion blower impeller for the furnace today. Thanks don2222. I'm hoping it will help move a bit more air through the furnace and help the burn.
    Now I've got to try to get the old one off. I hosed down the lock screw with penetrating oil and it's sitting now.
    If that doesn't work I may have to go medieval in it.
    wildwest, gbreda, bogieb and 7 others like this.
  9. ivanhoe
    ivanhoe
    Northern Ontario
    Will be firing up mine when I slap it back together. Upgraded my fan and made some adjustments on the fire pot. Take your time on the stubborn nut they say:thumbs: you want him to suffer:cool:
    wildwest, imacman and CleanFire like this.
  10. 343amc
    343amc
    I ended up going medieval. After digging more crud out I noticed it was a torx head, not an Allen head on the set screw. I managed to snap off my torx bit inside the set screw. Out came the cut off wheel and I had the old impeller off in less than two minutes.
    New impeller is on the motor. I'm going to clean everything out before putting it back together. Sounds like highs in the 30s this coming weekend, so maybe I'll get to test it out.
    I figure a couple more nights of tinkering and cleaning and I should be ready to go.
    ivanhoe, wildwest, bogieb and 4 others like this.
  11. DexterDay
    DexterDay Administrator
    Northeast Oh
    Been missing your posts Snowy Rivers!! Glad to have you here!
    Hope all has been well with you in the 2 years that some of us have not seen or talked to you.
    Welcome to FHC.:thumbs:
    will711, wildwest, gbreda and 7 others like this.
  12. CleanFire
    CleanFire
    My wife says that all the time.. :rofl: :lol: Way to go medieval w/ the cut-off wheel 343amc, no messing around there ! :thumbs:
    wildwest, imacman, 343amc and 2 others like this.
  13. 343amc
    343amc
    This is the aftermath/remainder of the original and the new one.
    Looks like it should help move a bit more air.
    wildwest, bogieb, CleanFire and 3 others like this.
  14. subsailor
    subsailor
    Winthrop, Maine
    That is the reason I run in stove temp when I'm home.
  15. don2222
    don2222
    Salem NH
    Hello
    Here is a sure fire way that I got the old blades off using my Air Cutter!
    The combustion blower's impeller blades that are enclosed in an exhaust plenum or housing seem to be almost welded on from the heat!
    I finally got the the impeller off with the Air Cutter! Looks nice when done with the new impeller blade! Changing these impeller blades can be more of a challenge!
    Here is what I tried.
    PB Blaster, Wire Brushing and then the wrench did not crack it!
    Drilling it out did not work very well either.
    It finally took the air cutter making 2 cuts!
    Click to Enlarge
    wildwest, ivanhoe and CleanFire like this.
  16. don2222
    don2222
    Salem NH
    After the two cuts, I poped it off with the claw of a hammer!
    Last pic - is
    Ta Da!
    wildwest and CleanFire like this.
  17. imacman
    imacman
    Denver, NC
    You might want to get some dry Graphite or moly spray and give those new blades & the surface of the motor housing a good coating......seemed to stay much cleaner when I did it on mine in the past.
    ivanhoe, 343amc, will711 and 5 others like this.
  18. gbreda
    gbreda
    NH
    Same here last weekend...and my back is paying for it more than usual :confused:
    ivanhoe, wildwest, slvrblkk and 5 others like this.
  19. gbreda
    gbreda
    NH
    It sounds like any combustion impeller that has years on it will most likely need this type of removal :saw:
    imacman, ivanhoe, 343amc and 4 others like this.
  20. jtakeman
    That's just a tune up for when the sn****, Err sn****! :confused:
    S**W gets here!! :wacky:
    :doh:
    imacman, ivanhoe, wildwest and 5 others like this.
