  1. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    I like the cool little tractors.
    A short drive from us ...the folks have a little tractor raceway....."Dirt track" The guys take the little tractors and stuff Small block Chevy V8's in them.
    These things are insane..........
    IHATEPROPANE, bogieb and Dpopps like this.
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    With the great weather...been getting work done on the cat project.
    Ripped the old bench seat out of the cab and too the scrap heap.
    Getting the bucket seats from the Blazer (Donor for the rear cabin) bolted in.
    Some small modifications needed to mount them......I salvaged the inner brackets off the Blazer floor pan
    Had to modify the passenger inner front mount....
    Getting ready to mount the new cable shifter.....
    Yesterday was build day for the base for the mount.
    Lots of work.....Imagineering.....Cutting parts and welding.....
    I wanted a simple easy to use shifter that was rugged and adaptable.
    The plastic console that came with the shifter is relegated to a closet....Just going to mount the shifter bare......
    Just a side note.....The screws holding the seat mounts to the floor will be replaced by large steerl pop rivets when they get here....So for now....POLE BARN SCREWS...
    The one piccy is a view from the command chair looking down and forward.....55" from the seat cushion to the ground....
    Great view.....
    IHATEPROPANE, bogieb, Dpopps and 2 others like this.
  3. imacman
    imacman
    Denver, NC
  4. imacman
    imacman
    Denver, NC
    Uhhhh.....hmmmm.....not recently. 1 win out of last 15 in Cup series. Not a stellar record. My neighbor up the street works in Roush/Yates engine dept. Their scratching their heads trying to find power. And you can't blame the chassis.....their all identical.
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    No such thing.
    IHATEPROPANE, gbreda, imacman and 2 others like this.
  6. smoke show
    smoke show
    Pittsfield, Wi
    The same but different...
  7. imacman
    imacman
    Denver, NC
    If you saw what they do to make sure they are, you'd change your mind. I've been in the Joe Gibbs headquarters, including their "room of doom" laser machine......they all have to be the same.
    IHATEPROPANE, gbreda and smoke show like this.
  8. smoke show
    smoke show
    Pittsfield, Wi
    Yeah but not the setup...
  9. imacman
    imacman
    Denver, NC
    No, not that, but parts/body-wise, they have to be identical.
    IHATEPROPANE, jtakeman and smoke show like this.
  10. jtakeman
    Yep, We stink this year. Do most years, So i'm used to it.
  11. smoke show
    smoke show
    Pittsfield, Wi
    Loose is fast!
    IHATEPROPANE, jtakeman and imacman like this.
  12. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    More work done yesterday on the Cat
    Got the rest of the parts made to mount the shifter.
    THIS IS INDUSTRIAL GRADE STUFF :D
    Had a piece of 3 inch tube formed to make the mounting stand.
    Fabricated and machined the actual bracket that the shifter bolts to.
    These shifters are designed to be used with the plastic console that can fasten to the floor ....or mount using several. different sheet metal plates (Universal) that Winters sells in their extra parts stuff.
    Nothing really suited the need for this project......So decided to make our own parts .....
    The setup allows the cable to be aimed right at the floor (RED DOT for access hole) and be able to loop gently down and connect to the transmission..+ (8" minimum radius on the cable bends)
    I wanted the shifter up within the operators normal eye line to allow grabbing the shifter without having to reach down towards the floor......
    The mounting does allow a bit of adjustment up and down as well as back and forth .....Mainly to allow ease of mounting and connecting the cable to the shifter.....
    The entire assembly can be easily removed from the cab if the need for work in the dash should come about.....
    FUNCTION IS THE BIGGY.....
    The steering Joy stick will mount right close to where my hand is in the one piccy..
    IHATEPROPANE and bogieb like this.
  13. jtakeman
    Schatz sweeps weekend in Ohio
    :dex:
    IHATEPROPANE and savemoney like this.
  14. imacman
    imacman
    Denver, NC
    Even a blind squirrel finds a nut once in a while. :coffee:
  15. scajjr2
    scajjr2
    Kingston, NH
    A chilly 42 when I got up at 6am. But a nice cup of coffee and the cat on my lap as I do my morning web surfing with the sun coming thru the east windows makes a nice start to my Friday.
    We've had quite the menagerie in the back yard around the feeders the past few days. Porcupines, a big fat woodchuck, skunk, rabbits, turkeys. Lots of hummingbirds, the usual dozen or so varieties of birds at the feeders and a few red tailed hawks circling above the trees .
    sam
  16. jtakeman
    We haven't seen any this year yet. But with all the chipmunks and squirrels that are around. I'm sure he/she will be around. We have 3 ravens hanging around this year, Wonder if it might be why the hawk isn't coming? Some of the birds we saw last year have also yet to show, But we have plenty of others to keep us amused. 2 of the field boxes have bluebirds nesting and 1 of the wren boxes has a male building a nest.
    IHATEPROPANE, imacman, bogieb and 2 others like this.
  17. smoke show
    smoke show
    Pittsfield, Wi
    Did spring cleaning at the cabin last weekend and closed up for the year. Could have used it last night. 33° overnight.
  18. imacman
    imacman
    Denver, NC
    Nice! You lived up to your name. :yes:
  19. jtakeman
  20. bogieb
