  1. bogieb
    Ive been misunderstanding what the local forecasters were saying. For some reason, I understood the troposphere to be the 2nd layer, but looking it up, that is the lowest layer. Could have been that they explained it just fine and it had to do with I was also reading while listening to the news.
  2. bogieb
    High yesterday was 30* (at 2am), low was -8 (about 7pm - didn't look before I turned in for the night). Actually impressed that it has only reached -14 so far. It's been 4-5 years since my area has seen that low of a temp, but we've had warm winters and negative teens used to be fairly routine for a couple of weeks in the dead of winter.
    I put the P43 at #1 feed rate and have it chasing the thermostat (the way the thermostat is set up, it messes with the way the stove functions if I put it in manual or constant burn). That keeps it about 73* in the living room and in the high 60's for the rest of the house. In the evening, when the temp dropped to 72* in the living room, instead of turning up the feed rate for the stove, I set the boiler thermostat for 73* so it would run off and on thru the night, but at least the pellet stove takes most of the load.
    The wind was so bad it was bowing in my garage door, making the temp in there fall from 44* real quick. So I ran the new boiler a couple of times to circulate water in the FHW pipes. I also threw some insulation above the overhead door. When I found that it would just blow out, I laid a couple of 2x4 on top to hold it in place.
    This morning the garage was down to 33* (wind has either died back some or changed direction enough not to mess with the overhead door), so I opened up the basement door and let the P61a do some heating of that too.
    For whatever reason, my thermguard isn't working, which is what I would normally cycle the boiler with. I took the cover off and it "looks" as if the wires are still attached. I didn't want to tear it apart and check and just screw everything up and have no boiler during the cold snap (which would be how these things normally work for me). Next week, once the garage is keeping a higher temp, I'll trouble shoot. Eh, maybe the thermguard itself developed an issue.
  3. gbreda
    gbreda
    NH
    The P68 has been firing on high since lighting it around 5:30 pm yesterday helping the boiler that has been going full time as well.
    This weather reveals the house insulation shortfalls as it still felt chilly on the first floor even though thermostat shows 68 degrees (normal for me). As the stove is in the basement, that in itself lends to extra time to get the heat upstairs along with having to warm the cement.
    The front door which is the side that is taking the wind is letting cold in but with no storm door and a glass pane that is not unexpected. In normal winter cold its fine but in this, it cant hold up to the bitter blast.
    House was making some big noises at times as the cold winds beat against it but overall, I cant complain as its been comfortable enough inside.
  4. jtakeman
    -14ºF when I got up at 6:00, Dumped the 4th bag of sets in. So it was at least a 3 bagger yesterday if not closer to 4. Bag #1 went it at 11:00 AM.
    Stove has been balls out all night and I have had to assist with some oil every now and then. I set the oil stat to 66ºF in case the pellet eater had an issue. Left the pellet stat set to 72ºF and the house temp was 67ºF when I got up. Not sure, but the oil heat may have came on and helped the pellet eater at some point! I fired the oil again to get the temp back to 72ºF.
    Dis place is freakin drafty and needs help! Feels aweful cold in the front of the house. And thats after a R15 upgrade. originally there was 0, zitch nada! r19 addition in the attic didn't do much either!
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Did not I say r60 in the attic meanwhile hunt down the drafts and fill the oil tank:doh::dex::dex::picard::picard::picard::picard::wacky::wacky::headbang::headbang:
  6. gbreda
    gbreda
    NH
    -14 deg F here as well but by tomorrow afternoon it can be 50 deg F warmer :cool:
    Only in New England. Dont like the weather, wait a minute :rofl: :lol:
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    A cold mamma results in :heidi::heidi::heidi::heidi::heidi:
  8. scajjr2
    scajjr2
    Kingston, NH
    -14 when I got up at 7. P43 ran full blast all night, 69 downstairs when I got up. used 2 bags of doug firs yesterday, easily 2 more today.
    Accidentally turned off the downstairs bathroom faucet I had left trickling before I went to bed and ended up having to use a hairdryer for 5 min to unfreeze the water inlet pipe from the well this morning.
    Heard trees popping from frozen sap when I went out to feed the birds this morning. Bluebirds made quick work of emptying the mealworm basket, may have to give them more later on.
    sam
  9. jtakeman
    Yep, I'll get there! But its not the only issue. Wierd how the attic was never warmer than 36ºF. So the r19 was doing something compared to the nada it had!! This place has sooo many air leaks its crazy!
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I won't disagree with you but I'll bet there are some who would.
  11. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Well ya got your castle now re-point it (seal it up):doh:and :zip: it.:p
  12. ChandlerR
    ChandlerR
    Seacoast NH
    When I turned in at 1am, the temp was -9. The Accentra was cranking and it kept the living room at 68. 1 1/2 bags in 24. Funny, the stove never ran so well. Window stayed crystal clear and much less ash. I'm going to leave the settings as they are and let the thermostat do its thing.
    About midnight the lights went out. They came back 10 seconds later. Just long enough to wonder if my generator in the motorhome would start at -9. Thankfully I never had to find out!
    It's 13 out now :D
    IHATEPROPANE, bogieb, imacman and 3 others like this.
  13. Earl764
    Earl764
    CT
    A coworker lost power at 2am and it came back hours later. Thankfully not his first rodeo and just had to fire up the generator. Much different situation at these temperatures.
    IHATEPROPANE, imacman, bogieb and 2 others like this.
  14. bogieb
    High yesterday was 10*. Not as windy as Friday but still, at those temps, the garage was getting down towards freezing. So opened the basement door every couple of hours until the temp was at 38* or so then shut it up again. Had lots of sun and later in the afternoon the garage seemed to be keeping mid 30's. Just in case, before I turned in for the night I did a last heat up until it hit 41*. This morning the garage is still at 37* :thumbs:
    Still had the main floor pellet stove set at a low burn with the boiler set to make up any drop. What a PITA - need to get the thermgaurd figured out. - I used way too much brain power getting the temps balanced out between the P43 and the boiler. But, at the same time, I wasn't one of the many people that were on the town FB page looking for someone to come thaw out pipes (or who lost water altogether, so probably had a main freeze).
    This morning's low was 12, so temp started rising before midnight. Right now it is 18 and supposed to be headed for 30. Pretty soon I should be able to give the P43 a break and place it back on thermostat control.
  15. bogieb
    May not be a classy fix, but hang up a quilt or blanket over the door. You can just use two nails so it can be swept out of the way if you need to open it. Had to do that at a couple of apartments way back when.
  16. jtakeman
    I feel your pain! I was up half the night friday keeping an eye out on the pellet eater and cycling the oil to assist. So worried it would continually drop temps in the shack. About 1:00 am I had had enough and reprogrammed the oil stat to be just under 2ºF of the pellets stat. So much easier!
    I saw your post in the TG thread. Hope you get it sorted. Doesn't sound like the TG is at fault. May just need to play with the control wiring to cycle the boiler. If I get a minute today I'll download the TG manual and check the wiring diagram. What boiler do you have?
  17. jtakeman
    We do that on the real cold days between the kitchen and the old laundry room(we call it a porch now-its where the kitties hang out to watch kitty tv). Except we use a heavy curtain and curtain rod. I rolled up a few towels and stuffed them in the window sills of the front window. You could feel the cold air just blowing in!! :(
    Not classy but it worked/helped!!
  18. Earl764
    Earl764
    CT
    My front door area currently has some towels at the base with books on them to keep the cats from flinging them. Should be able to remove today.
    bogieb, IHATEPROPANE and jtakeman like this.
  19. corncob
    corncob
    Somewhere in Lower Michigan
    Up to a balmy 37 here presently. Quite a change from the single digits we have been having for the last 2 weeks. Time to clean the stove today and empty the ash pan and install a clean burn pot and agitator. I have 2 pots and agitators for each. One in the stoves and the other soaking in water so the hard carbon flakes off. Still have a couple skids of pellets in the barn and 3 skids of corn. I see I'm going to have to replace part of the 4" venting, it's rusting out from the nitric in the corn.
    Our cats like to sleep on top of the stove in the greatroom (and leave hair everywhere.
    bogieb and SmokeyTheBear like this.
  20. corncob
    corncob
    I like the cold actually. Kills the bugs and allows me to use much less pesticide on my hayfields. Inputs today have become extremely expensive.
