  1. corncob
    corncob
    Somewhere in Lower Michigan
    Still running cheap propane. What is up with the TSC pellet stove recall anyway? Chinese junk?
    IHATEPROPANE likes this.
  2. imacman
    imacman
    Denver, NC
    Hit 65* today.....mid 60's beginning of next week too. :dex:
  3. corncob
    corncob
    Not over until the fat lady sings.
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It didn't hit 50 here but I did go out and took three suet cakes and the new "tree rat proof feeder" with me and pulled down one of the older feeders for refilling tomorrow if it doesn't get carried off like the one that held five lbs. of seed did.
  5. jtakeman
    Very went below 40ºF last night. 41º for our low up on the hill. The valley was 38ºF when I got up.
    Had a stove mishap last night that was a bit scary. Woke up at 2 am and felt rather warm. Noticed the furnace blower was on for more than usual. Got up and looked at the stat. Temp was 74ºand should have been 69º for the overnight setback. Headed down to the basement and saw the stove was idling(low fan speeds), But the fire was huge in the burnpot. Auger was running no stop and not the usual 3 seconds on 18 seconds off! Stove control was unresponsive to the off button?? Hit the auger buttons auntil the auger stopped running continuesly. Hit the off button and the stove shutdown.
    Let the stove cycle off and then did a power reset to see if it was just a fluke. Nope! After the restart and cycled through the start up, The auger started its run normally and then the auger started to run continues again. Again tapped the auger feed button until the auger stopped. Hit the power off and I let it cool off. I think the auger relay on the board is sticking. Won't know for sure, But will test at a later date as I will need to repair as the boards are now over $400 clams!!
    I put the only board I had left in it, Which is the original board that came with the stove that has a bad relay on the ignitor. So I have to manually ignite the stove with this board in. But at least the stove is making heat and I avoided the oil monster!
    I'll start a thread/post stepping through the repair and pic's if ya all are interested?? I think I have 2 that need repair in the stash now. So the one that was in the stove and doesn't power on plus this one. I'll use the one that doesn't power on for parts. And then I'll repair the board thats in the stove now with the bad igniter relay. I may test why the other board doesn't power on as well. And order the parts I rob from it at a later date. Should be a fun winter project!! Got to go and look for all my soldering chit and my solder sucker heat station. Their out in the mess in the garage somewhere!!
  6. corncob
    corncob
    Sure it's not a failed Variac?
  7. jtakeman
    Triac? Most likely wouldn't be able to get a response after cycling the auger button. Generally that is a stuck or sticking relay IIRC. We will see once I dig into the test stage.
  8. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    Yes, I will like to see the repair procedure, posted as a separate thread.
    It would be good if we can accumulate and document all of the service procedures
    of Harman stoves. Someday, someone can publish a Harman Stove Service Manual.
    Looking at your signature, I guess you do not own a Harman. In any event, we can use more Service manuals on any pellets stoves.
  9. jtakeman
    I have the Omega service manual. It goes over a few tests of the board, But thats about it. Most techs just replace the board. Some send back to manu for refurb, But thats even rare. I've done a few harman boards for friends/neighbors. Mostly the Potentiometers and thermistors.
    Whats needed is the board schematics. Along with a parts list. Hard to see the mini part numbers on those componenets and Having to ring out the circuits is a PITA!! I've gotten my way around the Applied Control Electronics boards only because I own them myself. I even have a programmer for the main chipset if I need to reprogram the chips on the DHC 4041 boards.
  10. IHATEPROPANE
    IHATEPROPANE
    Ran the genny for an hour and had just enough fuel left to top it off.
    Hoping it stays that way along with the snowblower.
    imacman, PelletHound, bogieb and 2 others like this.
  11. jtakeman
    I had the genny still hooked up as we had a tree accroosed the wires down the road. I was afraid it might take out paower again. But they took care of it yesterday. So I finally put it away. Also played in the shed garage a bit looking for my soldering irons/kit! But gave up cause I got hungry. So dragged out the pellet grill and did burgers for lunch. :D
    Like a spring day out there!! Almost don't want to take my usual mid day nap! :banana:
  12. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Things were sweet last night....Weather was pretty benign..... Then about 10:30 the power went off again....
    I crawl out of the sack and drag the Genny back out.....Get the Two Quads up and flying......
    Then we jump in the rig and head out to see if we can locate the issue......
    We run into a fire engine/crew out looking for a reported transformer explosion.....They had the area....Street and such..
    THERE ARE NO TRANSFORMERS WITHIN A HALF MILE OF THERE.....
    Daylight brought good visibility and NOTHING WAS AMISS...
    Power company said a crew would be on it at first light.......
    At 8:40 am power was back and no power co rigs in the area......
    I called the Pwr co and got the skinny on things....A "recloser" on a feeder line close into town had failed.....
    Some clown had called it in as a blown transformer.....Likely thought it would get things fixed quick.....Just wasted the time of an engine company and some cops chasing around......
    The power was back up at 8:40 am......
    I have seen the reclosers fail before....The past few storms have given that equipment a good work out....
    Not sure how many trip cycles they can stand before they croak
    PelletHound, IHATEPROPANE and bogieb like this.
  13. jtakeman
  14. Earl764
    Earl764
    CT
  15. bogieb
    A continuous running auger would be scary! Is there a safety that would have shut ist down if the stove got too hot? Or maybe, since you couldn't get the stove turn off that wouldn't have done anything anyway.
    Glad you were home to attend to the issue and that nothing bad happened!
  16. jtakeman
    The stoves high limit would have tripped if it got to 250ºF. I must have caught it before it got that hot. I had to replace the high limit a while back as it went fluky and wouldn't reset. I had it jumped until the new one came in. I'm glad it happened after the new one was installed. Could have been real bad! But this might be why the old high limit quite??
    I ordered another as a spare so I wont need to risk it with a jumper. Also ordered a low limit to have on hand. I will also be ordering several other spares so I won't have to mess around. Soon to be our only source of heat until we can swing the heat pump system. After calling around not many places near me carry spares on hand. So its not as easy to just go run and grab them. Some items are odd like the 3 rpm auger motor. And the ignitor(which I already have a spare for). Plus pricing is high at the local shops. ESES and some of the online shops are more frugal friendly.
    Now I just need to repair my control board to work correctly again. I may even go as far as making the board relays socketed for easy replacement.
    imacman, Rich250, bogieb and 3 others like this.
  17. imacman
    imacman
    Denver, NC
    Gleason-Avery has the 3 RPM
    Rich250, bogieb, PelletHound and 2 others like this.
  18. schoondog
    schoondog
    Dutchess County N.Y.
    The new auger motor came in Thursday, and I put it in Thurs. night after work. Thought it strange that motor and igniter would not begin working until I shut the unit down by lowering the temp. on the remote, and then allowing to shut off. But things are working again and no more $5 oil. Much more comfy 68 -70 deg. house instead of 63 on oil.
    Happy New Year folks !!
    Doggy
    imacman, bogieb, PelletHound and 2 others like this.
  19. jtakeman
    They are my 1st choice for sure! :)
    imacman, PelletHound and IHATEPROPANE like this.
  20. smoke show
    smoke show
    Pittsfield, Wi
