  1. bogieb
    Holy cow, that is more than what both my stoves are using altogether presently. You definitely need to get that think more blankets.
  2. jtakeman
    We hit the teens up on the hill last night. Good bit of wind too. Stove needed to be bumped up a feed level this morning. :shiver:
    Sky is spitting white stuff too, Luckily its just flurries and the sun is peeking through!! 27ºF currently. To me, Fall has said see ya and winta is sneaking up on us already!!
  3. corncob
    corncob
    Somewhere in Lower Michigan
    Balmy 18 here presently and we have a nice coating of white on the now frozen ground. Shoulder season was about 2 days long. I fibbed, just checked the outside thermometer, it's up to 20 now.
    I'm roasting about 1.5 bags every 24 hours too but the entire house is at 70 (upstairs as well). I need to start mixing in corn, once the garbage cans are empty. Don't want to deal with it when it's this cold because I need to start one of the diesel tractors and take my cans to the barn to mix in the corn and as cold as it is, I'd have a devil of a time firing up one as they aren't plugged in. No electricity in the big barn, besides, neither have block heaters anyway. Diesel fuel in both are treated with Power Service winter additive and Archoil cetane additive and I run 5-40 Rotella T6 synthetic in both of them. In the cars and truck as well. Only time I run the biomass stove in the shop is when I out there and I keep the floor heat at 50 all the time.
    bogieb likes this.
  4. jtakeman
    So close to single digits last night. 11ºF for our low. Its an awesome 17ºF at 7:00 am Woot! At least the wind settled, I must of woke up in the wrong month cause this sure doesn't feel like November!!
    IHATEPROPANE, corncob, bogieb and 3 others like this.
  5. corncob
    corncob
    Feels like January. it's global warming...lol Kind of like the frigid temps as the kill off over wintering bug larva so I can use less chemicals on my crops and chems have become very expensive like everything else has.
    bogieb and SmokeyTheBear like this.
  6. corncob
    corncob
    Finally got my RH under control, went to the grocery and bought a number of gallon jugs of distilled and fired up the humidifier. The RH in here is now 50% and it 'feels' much better now. Was down to 35 which is way too low. 50% is about right
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    ONE MINOR CORRECTION IT'S Gorbal not global.
  8. corncob
    corncob
    Gorbal??????
    IHATEPROPANE and SmokeyTheBear like this.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Do you not remember the Al Gore, Pete does.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    What does it do in your state anytime after September? :doh::dex::picard::picard::thumbs::whistle::whistle:
    IHATEPROPANE and imacman like this.
  11. corncob
    corncob
    I make a concerted effort to forget people like that.
  12. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Got up this morning at 4 and decided to lite the small Whitfield in the living room to get the shack a tad warmer.
    Only ran the big stove last night.
    After a bit I went out to get more coffee...Stove was out...cold....still cycling the auger.....Hmmmmmmmmmmmmmm
    Hopper full..
    Checked the auger motor fuse...OK
    Took the back off the stove.....
    AUGER JAMMED HARD.......
    Cleaned out the hopper to check for a stick in the auger at the inlet....OK
    Loosened the auger set screw on the auger drive collar.
    Removed motor..... Turned on the power and set the auger on PRIME
    Motor ran fine.....
    Auger loose now. HMMMMMMMMMMMMMM ?????????????
    Cleared the fire pot.....Rotated the auger many times....Fire pot full of shells......
    Emptied the auger completely......
    Removed the fire pot and dumped it into a bucket.......
    PLUNK......OH MY....Should not hear a PLUNK NOISE
    Sorted through the handful of shells.
    ARRRRRRGH
    Found a #2 Phillips hex bit in the bucket......
    Little tool had likely found its way up to the upper reaches of the auger and then finally got stuck in the drop tube opening......Rocking the auger dislodged the drive bit and it fell out.....
    I had a new auger motor....IT WOULD NOT RUN
    After helping the armature a few times by hand....it took off.....Still pretty weak
    Decided to put the old one back on.....IT IS RUNNING FINE....STOVE is feeding well......
    I am going to order some heavy duty auger motors for spares.....
    Can't be 100% sure...but my bet is I own this FUBAR.......Either the tool fell in during a booster fan chamber cleaning...
    OR the tool was left on one of the barrel lids in the basement and fell into the shells and was not seen....
    Ah well....
  13. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Yup, you own it.:doh::dex::headbang::picard:
    :whistle::zip:
    IHATEPROPANE, imacman and jtakeman like this.
  14. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Don't ever use virtual machines if you plan on updating your software frequently you'll go bonkers with your passwords and I haven't hit the big jump yet.
  15. Dpopps
    Dpopps
    MI
    Never seen these before, I'm betting there not good though.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Hey folks see Dpopps found some EASY HEATs.
    IHATEPROPANE, imacman, bogieb and 2 others like this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
  18. Dpopps
    Dpopps
    MI
  19. jtakeman
    Can't believe we've burned 45 bags so far!! Had to count the bags 2x to be sure. :faint:
    :doh:
  20. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Widdle stove doing fine after the repairs....
    Chugging away this morning just fine....
