  1. wildwest
    Hi, thanks, bizarre huh? Yes, Heartlands again this year.
  2. corncob
    corncob
    Somewhere in Lower Michigan
    That logo on the truck should say.. 'Empty Wallet on Wheels'.. instead.
    IHATEPROPANE, bogieb, gbreda and 2 others like this.
  3. wildwest
    Morning J :), I'm not aware of any settings to change feed rate except the bottom right red arrow. On level one the augers turn slow, on level six they turn fast. I have 60lbs in the hopper at the moment but I'm 99% certain there is just a rectangle hole on the bottom of the hopper without a slide door, you can actually see the first auger through it (~~2" x 3" ) when it's empty, and I don't find anything in the manual. ivanhoe , do you have a feed trim?
    I also found this, I've not seen it before so I wonder if they added it to the manual since my first stove.
  4. jtakeman
    Another though is not so great pallet mixing if there isn't a feed trim adjustment. Grab some not so hot pellets and mix them with the good ones 50/50 to start. If still to hot mix in more % of not so good stuff say 60% not so hot to 40% heatlands.
    I'll down load the manual later as I need to get some shack todo work done or momma gonna :heidi:I've promise to get an outside outlet installed so she can run a power cord to the chicken hut for the heated water dish.
    IHATEPROPANE, bogieb and imacman like this.
  5. corncob
    corncob
    I am noticing that the Michigan Hardwood pellets I'm using with my corn are in random lengths this year and some are quite long. I assume the auger is cutting them down to size as I have not had any feeding issues.
    Just noticed that actually. Usually I don't pay any attention to the pellets or corn. Just fill my trash cans in the barn and set them on the deck. 4 cans equals about 2 weeks of roasting. Not sure what I'll do with the shop stove far as fueling it. Maybe a couple of trash cans in the shop in the corner and I'm in a quandry about running it too. It's an old non igniter stove so it has to run 24-7 on low fire. Maybe I'll refit it to electric ignition but I will have to machine the firepots. No big deal
  6. corncob
    corncob
    I would have to assume that the shorter the pellet is, the more pellet volume can get in the auger flighting, consequently more fuel is getting burned because the flighting will only convey a set amount of fuel volume, least I think that is a correct assumption.
  7. Cash Larue
    Cash Larue
    Pine, CO
    Can you just buy a bag of something else and run it through? See if that’s your problem. I have to admit, I’m a bit skeptical.
  8. wildwest
    What a clever idea J, seems Rocky Mountain Pellets are always way too long, I've seen some like some up to 3" corncob .
    Good idea Cash, I don't go to town but I'll see if I can lasso my husband to pick one or two up. I'm a bit skeptical it's short pellets too...
  9. imacman
    imacman
    Denver, NC
    Great idea. That will 100% answer your short pellet question.
  10. Rich250
    Rich250
    Berks County PA.
    Found this for your stove WW apparently you can make adjustments to the factory presets
    Extended Programming for the Eco 65, firmware version 1.09
    Press + and – keys at the same time to start the programming – will display “DEFAULT”
    Press the auger key to cycle through items forward, fan key to go back
    EXH1-6 are the exhaust fan settings (factory settings for EXH1-4 are 68v, EXH5-6 are 105v)
    CVL1-6 are the fan blower settings (change these via normal programming per the manual)
    CMB1-6 are the combustion blower settings (factory settings for CMB1 is 65v, CMB2-6 are 85v)
    AGA1-6 is bin feed auger (factory settings for AGA1 is 8, AGA2 is 16, AGA3 is 19, AGA4 is 24, AGA5 is 31, AGA6 is 38)
    AGB1-6 is front auger (needs to stay at 100 for all, runs constant)
    OVRT is over temperature (factory set to 325F)
    WRMT is when the stove turns to “on” from “ignition” (factory set to 130F)
    CLDT is cold temperature when the stove turns off (factory set to 100F)
    PILT (factory set to 1)
    EDLY (factory set to 10)
    Press reset button to save once you go through the whole menu.
    Update for v1.17 firmware.
    Extended Programming for the Eco 65, firmware version 1.17
    Press the auger key to cycle through items forward, aux key to go back, and use mode key as enter.
    WRMT is when the stove turns to “on” from “ignition” (factory set to 115F)
    EDLY (factory set to 20)
    IHATEPROPANE, imacman, gbreda and 4 others like this.
  11. wildwest
    :eek:, WOW, thank you very much! What a wonderful Christmas present, I'll get into this tomorrow! I just used - + to see which software I have, v.1.17 :yes: I use - + to reset my augers after power outages when they stop, I never tried to press them once, always held them down for reboot. Might I ask where you found this (and also curious why tech support did not share this with us?)
  12. imacman
    imacman
    Denver, NC
    Typically, stove manufacturers don't want homeowners "fiddling" with settings. Most of the time, it's a whole legal thing where they don't want you to burn your house down & then file a suit against them.
    IHATEPROPANE, badbob, bogieb and 4 others like this.
  13. corncob
    corncob
    Not on subject but we have tornado warning for tonight and it's raining cats and dogs and the outside temp went from 22 to 55 in about 5 hours. Must be global warming....
    One thing about Michigan weather, wait a half hour and it will change.
  14. corncob
    corncob
    Very good synopsis.
    Like my USSC 6039. The owners manual never mentions the fact that every setting on the control board is 100% user programmable. You have to obtain the USSC technicians manual to program the algorithms. Not something the average buyer can do and there is an inherent liability issue. Programming in incorrect setting could cause a stove fire and a possible lawsuit so USSC is very tight lipped about that stuff, with good reason.
  15. wildwest
    I totally get that, liability. And heck, don't serve hot coffee from a McDonalds drive through window or neglect to put the warning sticker on the top rung of a step ladder.
    BTW, not a lot of threads stay on subject at FHC :rofl: :lol:.
    This emojie is was here when I got here and it's true :Yar: lol. Stay safe in the tornado warning Corn. We got ~5" snow yesterday/last night. 10* here.
    IHATEPROPANE, imacman, badbob and 2 others like this.
  16. Rich250
    Rich250
    Berks County PA.
    There was a video at one time about it on you tube but it's no longer there but found some one that converted it to written form. And yes liabilty is why tech support won't share that info publicly. Had the same thing with my Harman but found out how to get in.
  17. bogieb
    Hope you stayed safe! A little after 5am there was a breaking news report on my local TV station about the deadly tornadoes. They are saying one of the tornadoes was on the ground for 240 miles.
  18. imacman
    imacman
    Denver, NC
    :eek:
  19. badbob
    badbob
    Looks like Kentucky got hit hard. Possible 100 dead.
    IHATEPROPANE, imacman and bogieb like this.
  20. jtakeman
    Wife decided to get some holiday cheer going. So we went out and grabbed a tree. Her and the kitties decorated it once I trimmed and got it straightened up in the stand. Excited to spend our 1st Christmas.
    Not the best looking, But it has a story behind it. Someone did a cut your own but decided it was too prickly, So we kind of saved it from just sitting there. We need a good prickly tree to help keep the cats out of it. Happy its not going to waste!!
