  1. scajjr2
    scajjr2
    Kingston, NH
    Had a good 30 min long thunderstorm here last night. Had a couple real close lightning strikes (had a couple breakers pop during the resulting flickering and surges), lots of house shaking thunder and a ton of rain.
    Sam
  2. jtakeman
    Happy Birthday CleanFire
    Hope you had a great day!! :)
  3. ttdberg
    ttdberg Pellet Pig
    CT
    X2!!!
  4. wildwest
    X3 CleanFire :)
  5. slvrblkk
    slvrblkk
    Northampton, PA
  6. Rich250
    Rich250
    Berks County PA.
  7. bogieb
    X6!
  8. IHATEPROPANE
    IHATEPROPANE
    X7
  9. imacman
    imacman
    Denver, NC
    X8!
  10. jtakeman
    Off to the lake, Hoping we don't melt! :dennis:
    Haven't had much chance lately to fish with my boy! He's been experimenting in fly fishing and seems to have that mastered. Might have to see if I still fit in my waders??:doh:
    This is just a small sample of the good chubs he's caught so far!! Wow!!:jaw::bug:
    107020802_2576749722586276_988995887618612395_n.jpg 90991295_2490324264562156_6341789499130904576_n.jpg 104599958_2564091913852057_6525019796138993243_n.jpg 110121375_2586628254931756_6701657751178823125_o.jpg 109712638_2585013868426528_7287296232887766693_n.jpg
  11. slvrblkk
    slvrblkk
    Northampton, PA
  12. MikeSs
    MikeSs
    new have county, ct.
    so, did you melt?
    If no reply, then we will assume you did ;0
  13. BHags
    BHags
    Massachusetts
    Please spare us the trying to fit into the waders photos...
  14. jtakeman
    :picard::doh:
  15. jtakeman
    No, But we did call it early. Way to hot for this old fool................
  16. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Hey there troops.
    Working on the snow cat project the other day and had a real bummer happen.
    Tapping one of the gear cases together using a Urethane dead blow hammer.
    I swatted one of the dowel pins that aligns the case cover with the case....OMG
    The dowel went in flush....the pin is hardened and can't be drilled and tapped to pull it out.....
    Decided to try an old trick.
    I GUESSED at the depth of the pin and drilled a hole behind the pin.
    Tapped the hole 1/4-28 and screwed in a small grease zirk.
    3 pumps on the grease gun and the pin was back out where it belonged.
    A very lucky shot...This pin must be in the case to locate the cover.....this assures that the bearing bores are located properly...
  17. Earl764
    Earl764
    CT
    Anyone order their pellets yet?
  18. bogieb
    After picking up the ton of rebagged Cubex off CL a couple of weeks ago, I have about 4 tons on hand. Will probably get another ton in the early fall when TSC has, in the past, a pre-order sale and I'll probably get 1 more ton. After that I'll just get pellets as I whittle down my stock.
  19. Pete Zahria
    Pete Zahria
    New Hampster
    Already stacked...
    Dan
  20. Pete Zahria
    Pete Zahria
    New Hampster
    Kind of like taking out a pilot bearing from a crankshaft..
    :yes:
    Dan
