  1. IHATEPROPANE
    IHATEPROPANE
    Merry Christmas!
    God Jul!
    To all you FHC folks!
  2. vtktm802
    vtktm802
    Hyde Park, Vt
    A good ole nor'easter would be the ticket....
    wildwest, BHags, savemoney and 6 others like this.
  3. imacman
    imacman
    Denver, NC
    :faint::picard:
  4. CleanFire
    CleanFire
    You too IHP!
    Merry Christmas FHC folks!
    wildwest, imacman, savemoney and 6 others like this.
  5. Dpopps
    Dpopps
    MI
    Merry Christmas all.
    wildwest, imacman, savemoney and 8 others like this.
  6. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Merry Christmas and a happy new year to all the folks here at FHC
    It's been a good year.....
  7. Earl764
    Earl764
    CT
    were you trapped in Chicago? I saw something about a lot of groundings from fog.
    CleanFire, wildwest, imacman and 5 others like this.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    [​IMG] may the force be with you's :D:cheers:
    Thor, CleanFire, wildwest and 10 others like this.
  9. jtakeman
    Burning in my xmas present! :D
    Luneyburg, Thor, schoondog and 16 others like this.
  10. bogieb
    No fog when we landed at 2, nore when we took off at 5
    Dpopps, Luneyburg, CleanFire and 6 others like this.
  11. IHATEPROPANE
    IHATEPROPANE
    Dpopps, CleanFire, wildwest and 7 others like this.
  12. jtakeman
    Lemme practice first. :D
    Dpopps, Thor, CleanFire and 9 others like this.
  13. ivanhoe
    ivanhoe
    Northern Ontario
    You'll have all the practice when you get to the 100th mouth to feed :D
    Us, the smoothie drinkers will be safe 'cause we'll be the at the end of the line :pete:
    Dpopps, Thor, BHags and 10 others like this.
  14. Pete Zahria
    Pete Zahria
    New Hampster
    You need to let us know how it does...
    Dan
    Dpopps, Thor, ivanhoe and 6 others like this.
  15. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    All my parts I had ordered finally arrived and I was able to get a drive shaft back together.
    Gotta do more shells soon and I did not want parts getting lost...
    Grabbed my bag of pieces and headed to the shop.
    Took maybe 30 minutes to gitterdone.
    A perfect text book R&R JOB.
    The text book was written by someone who was working with new parts both ways...
    Getting all the used parts clean, rust free and making sure there are no burs on the critical surfaces is also not in the book....
    Having the special tools makes it possible too.
    Machined up a little adapter for the ball joint tool made life very sweet.
    Marking all parts prior to disassembly is paramount to keeping the shaft in balance upon reassembly...
    The special tool is THE ONLY WAY to get the worn out ball off the stub easily.
    The ball is not supposed to be pear shaped...ROUND IS THE WORD HERE....
    Cutting it with a die grinder and a cutoff wheel can be done, but I found the tool on ebay for $20
    New the tool is nearly $300...
    Yesssssssssssssss...STEEL STAMP EVERYTHING SO WHEN ALL THE NUMBERS ARE LINE UP...YA BE GOOD.
    All pretty and can be set aside for a bit, and then it's time to do the other end...
  16. ChandlerR
    ChandlerR
    Seacoast NH
    Good for you Snowy. I have done many constant velocity universal joints and although I got good at them, I dreaded every one.
  17. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    This particular set up came from an S10 extended cab truck
    I am using it in my project rig.
    The 3R series Saginaw type are easy to rebuild and very forgiving.
    The centering ball is pressed onto the yoke and is easily removed and replaced.
    If ya got the tools they are a breeze..
    Trying to manhandle them on the floor with a hammer is a real nightmare.
    I had this one in my large vise at waist high level.
    Very easy to get after it with the tools.
    The joints are held in on these with injected plastic..
    Warm the thing with the torch until the plastic pukes out the holes....good to go.
    A couple sharp whacks with a good club to dislodge the joints and then push things out with the u joint attachment on the ball joint pusher and my 18 volt impact wrench.
    I like the 18 volt tool as it's not as harsh as the air impact.
    Easy does it seems to be better and does not break stuff ....
    Clean everything and then stuff in the new parts.
    Not my favorite job....but not all that bad either.
  18. ttdberg
    ttdberg Pellet Pig
    CT
    It was 50 degrees outside yesterday, so took the opportunity to get out on the roof and do a mid-season cleaning of the P68 flue. Looks like we have a relatively mild stretch of weather for the foreseeable future, mostly 40s days and 30s nights.
    ivanhoe, vtktm802, bogieb and 10 others like this.
  19. jtakeman
    I did my 1 ton(ish) cleaning yesterday. Also did a dump run to ride the rest of the demo from the bath remodel. Plus sanded the drive and roadway so we could get back up it once we came home.
    Back to doing the bondo to the drywall. Maybe try out the new grill after my afternoon geezer nap. Wifey is hitting the supermarket, Hope she picks up some steaks?? Heck, I'd settle for a good burger. :D
    She knows I work for food and beer!! :pete:
    ivanhoe, IHATEPROPANE, bogieb and 7 others like this.
  20. Luneyburg
    Luneyburg
    Hills of Central Mass
    Refused to work this weekend after the 30 hours in 2 day fiasco last weekend soooooo time to catch up on what I have not done in the last 2 weekends. So much for resting today but heh it had to be done so I was getting low on pellets and all it takes is a 2'-3' snowstorm to make my life miserable meaning it really becomes a Biatch to get pellets into my cellar.
    So today I had the mission of replenishing my pellet supply to where I felt comfortable and that I did . Grabbed and loaded down to the cellar 2 tons of pellets one which I have never burned Easyblaze Super Premium softwood pellet and the other would be my first ton of Matra.
    ivanhoe, imacman, Thor and 11 others like this.
