  1. ivanhoe
    ivanhoe
    Northern Ontario
    That's good, not a good time for another setback.
  2. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    Man it was cold lat night, and not looking much better tonight. Supposed to have 5 plus inches of snow moving in tomorrow! You all stay safe out there, it is dangerous! This was from last night:
  3. subsailor
    subsailor
    Winthrop, Maine
    Are you sure your hopper isn't bigger than 72 lbs.? I can't come close to fitting 2 bags in mine not matter how small the pellets are.
  4. slvrblkk
    slvrblkk
    Northampton, PA
    I think hers is 125lbs.
    IHATEPROPANE, ivanhoe and wildwest like this.
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    125 pounds nominal
  6. subsailor
    subsailor
    Winthrop, Maine
    THAT would explain it.
  7. wildwest
    :rofl: :lol: code ID10T :rofl: :lol:
    I just looked up the brochure, it's 125 lbs. Guess the 72 lbs was the other stove I was considering before buying this one.
    Thanks Sub :)
  8. DexterDay
    DexterDay Administrator
    Northeast Oh
    My Enerzone is rated at 70 lbs and I can get 2 bags in it.
  9. IHATEPROPANE
    IHATEPROPANE
    Well it is -10℉ here this morning. Normally I would have the West Point set hi/lo at level 3. But, I had to get cute. Figured I would Set it to two, leave the bonus room open with the 55-TRPEP set on level 3. Only problem, the Englander shut down some time during the night due to low fuel. I had filled it at 6pm and it was out sometime before 5am. Growing pains I guess. The house was 60-65 and the bonus room was 50:shiver:.
    Cranked both stoves and was quickly back to normal......now off to snow blow.:mad:
  10. Smokinpiney
    Smokinpiney
    "South" Jersey
    Burnin down some coals in the volcano so i turned up the hastings to take up the slack. This thing has been a life saver! :banana:
    ivanhoe, DexterDay, wildwest and 2 others like this.
  11. gbreda
    gbreda
    NH
    Pellet bags are 40lbs. Why on earth any manufacture makes a hopper rated for anything other than a weight that is divisible by 40 is the real ID10T
  12. eatonpcat
    I guess if they can't make the hopper big enough to fit 80lb I would rather it hold as much as possible which in my case it's 60 lb. If the hopper was larger, the insert would not fit in my fireplace!!
    ivanhoe, wildwest and IHATEPROPANE like this.
  13. Smokinpiney
    Smokinpiney
    "South" Jersey
    My hastings claims to have a 42lb hopper. I can't fit a full bag in it. There's always about 2-3lbs left in the bag, go figure :picard:
  14. IHATEPROPANE
    IHATEPROPANE
    Inserts are a different breed. You don't really see many bigger than 60. But that would be my minimum.
    As I just finished my snow blowing the machine started to sound like it was going to die under load:headbang:. Hope that's it for snow this winter. It may need a check up.
    ivanhoe, eatonpcat and wildwest like this.
  15. PelletHound
    PelletHound
    SE Ma.
    The P68 is rated at 78lbs. Why they didn't just make it a tiny bit bigger is beyond me.:picard:
    ivanhoe, wildwest, gbreda and 2 others like this.
  16. krooser
    krooser
    Waupaca, WI
    Remember every pellet weighs a little different… I can put 1 1/3 bags of Marth hardwoods in my St. Croix but only 1 bag plus a smidgen more of Uncle Jed's softwoods.
  17. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    My endurance says 112lb , I can't fit a full 3 bags. Maybe 2.5
    It's good marketing to oversize.
  18. jtakeman
    Mine is rated for 130 pounds, But I too can only get 2 1/2 bags round a bouts.
  19. IHATEPROPANE
    IHATEPROPANE
    Mine is rated at 130. It can just fit three bags. But about a half a bag or more hangs up on the side.
  20. smoke show
    smoke show
    Pittsfield, Wi
    If you carefully arrange the pellets in rows end to end like DexterDay they will hold the rated capacity...
    343amc, eatonpcat, ivanhoe and 12 others like this.
